Reply
Thread Tools Display Modes
Old 08-26-2013, 10:11 AM   #1
BLUDICE
BLUDICE's Avatar
Default Harbour Freight Welder
90 Amp Flux Wire Welder 120V
to be used for very small jobs on car - filling holes, etc
anyone have one of these - opinion please - thx
__________________
Why does everyone ask me if my car is a Tucker or Studebaker??
offline   Reply With Quote
Old 08-26-2013, 10:13 AM   #2
louisb
Alliance Member
Default Re: Harbour Freight Welder
Friend bought one and had to return it three times to get one that worked. (sorta) Really cheaply put together and hard to use.
--louis
Old 08-26-2013, 10:18 AM   #3
madmak95
madmak95's Avatar
Mine was temperamental. Welded good one minute bad the nexts. Never could figure it out. Finally nutted up and bought a millermatic 180. Best thing I ever done.
Old 08-26-2013, 10:20 AM   #4
bgaro
Senior Member
bgaro's Avatar
i wouldn't bother, not worth the aggravation.
Old 08-26-2013, 11:47 AM   #5
fsae0607
Alliance Member
fsae0607's Avatar
I have one. To make it acceptable, replace the puny ground clamp with a good one and pop in some Lincoln NR-211 wire.
Don't weld anything over .125" thick, regardless what the manual says (mine says it can weld 1/2"... yeah right). Even at .125" thick, you gotta bevel the joints.
__________________
"If man built it, you can fix it." - My Dad
"I'm tired of F***ING AROUND!" - Some guy named Terry
Old 08-26-2013, 11:52 AM   #6
hugh m
Senior Member
hugh m's Avatar
Buy an American Miller, even a used one, and be done.
__________________
www.waterwheelboatcarts.com
Old 08-26-2013, 11:54 AM   #7
fleetside66
Senior Member
fleetside66's Avatar
I had nothing but good results with mine, although thin sheet metal can be a challenge. You just have to up your grinding skills, that's all. At the risk of a total shit-storm, I'll admit that I did my whole build with one (not the frame). Here's a before & after on my doors, although I must admit that pictures always make things look better.
online   Reply With Quote
Old 08-26-2013, 11:57 AM   #8
Alliance Member
Mr48chev's Avatar
This is probably the 100th time the question has been posed since I joined the HAMB and the answers are always the same. They just aren't that good and service and service parts are non existent. The easiest way to get a welder service tech at a real welders supply store to laugh until he hurts himself is to carry in a Harbor Freight welder and ask if he can fix it. After he recovers from rolling around on the floor the answer will be NO take it back to Harbor Freight.
I'd much rather see you save a bit more and buy either a new or used Miller, Lincoln or Hobart mig welder. Then you can take it in and get it serviced and they will all need service if you use them and you can get parts for them. Quite often you can find a Hobart 140 on sale for around 400 or less at the local "farm and ranch" store or a Lincoln at Home depot or Lowes on sale for a reasonable price or one on Craigslist where a guy bought a 110 V unit and then decided he needed a bigger welder.
If you do buy a HF unit buy the extended warranty so you can take it back when it craps out and go again.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 08-26-2013, 11:58 AM   #9
55 dude
Old School HAMBer
55 dude's Avatar
I purchased one to fix a harbor freight wagon I had a engine sitting on,total junk!
Old 08-26-2013, 12:13 PM   #10
Timberbeast
Newbie
Timberbeast's Avatar
I bought a Lincoln Century 140 from an on line store for about $350. Welds very well it does everything I need it to do including an occasional frame repair. For heavier jobs I still use my stick welder.
Do not use the cheap welding wire, it just dosen't weld properly. I use only Lincoln or Miller wire it is worth the few cents more that it costs.
Good luck.
__________________
Semper Fi
Jerry
Old 08-26-2013, 12:29 PM   #11
Crazy Steve
Crazy Steve's Avatar
HF stuff is throw-away.... Not to say there aren't some decent values to be found there for the lo-bucker, but when it fails, throw it away. It will cost more than it's worth to fix, assuming you can get the parts (unlikely). I buy their air tools, and those $20 4" grinders aren't bad either, but when they go bad I pitch 'em.....
And run shield gas, not flux-core wire. You'll just make a mess on sheetmetal with flux-core.
Old 08-26-2013, 12:30 PM   #12
gimpyshotrods
Old School HAMBer
gimpyshotrods's Avatar
Disposable. One minor part failure, and it is a total-loss. Save your money for a good used real welder.
__________________
Ala Kart had air bags in 1957. Traditional? Yes!
Old 08-26-2013, 12:34 PM   #13
BLUDICE
BLUDICE's Avatar
That's why I ask first - thanks guys!!
__________________
Old 08-26-2013, 12:43 PM   #14
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Get the replacement extended warranty- 70% of them are junk in a few uses or DOA.
30% give some good use.
You'll be getting $90.00 worth of a 500.00 machine, so don't expect much but you could get lucky.
Your mileage may vary, and I'm not saying you could ever do the same-
but after the 4 returns of their plasma cutters, i did get a good one that has yet to let me down. It's paid for itself many times over, but the first 4 were junk within a few days.
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 08-26-2013, 12:50 PM   #15
jazz1
jazz1's Avatar
Keep in mind the Lincoln welders sold in retail shops such as Menards or Farm and Fleet are not the same units sold in shops who cater to welders Price dictates quality!..The retail store Lincolns are cheap knockoffs and parts are unavailable.
Old 08-26-2013, 01:13 PM   #16
patmanta
Alliance Member
patmanta's Avatar
If you absolutely need a way to stick metal right now for less than $100. Sure, but keep it for light stuff and don't do anything structural.
It's messy, but if you get one that works, it will stick metal together as long as you set the wire in the feed just right.
When you get a quality machine, this thing will likely become a nuisance to trip over.
__________________
First Build Thread
Old 08-26-2013, 01:34 PM   #17
bryceaugustine
bryceaugustine's Avatar
Location: Gardner Kansas - Transplant...Orgnially Hays America
find a used miller or lincoln. probbaly pay a bit more. but worth it.
__________________
Auggie
Dont scratch my rust!
Help finding this old Gasser!
Old 08-26-2013, 01:44 PM   #18
56PontiacPiano
Well, you're first problem is that you're purchasing from Harbour Freight....
They should rename that place "Palace of sh*tty tools"
Got a dolly from there to move my big upright player piano. The thing wouldn't even roll. I got a multimeter from there, thing was cheap. Only thing I got from there that was good was sand paper, and a soldering Iron. I'm sure they probably have some okay tool sets, but...quality seems to not be a priority in that place.
Old 08-26-2013, 01:47 PM   #19
fsae0607
Alliance Member
fsae0607's Avatar
They give those multimeters away for free with the mail coupons! That outta tell you something. They tried so hard to give me one by saying, "Are you sure? It's free!". I cut that short by telling them, "No thanks, I have a Fluke meter at home".
__________________
Old 08-26-2013, 02:06 PM   #20
tfeverfred
Old School HAMBer
tfeverfred's Avatar
I'm taking welding classes and last semester a student brought one in to show the instructor. The instructor laughed and told him to share his wealth with everyone, since he was throwing money away. A friend asked me to use one and the damn thing was like welding with hot rocks and a stick. It just isn't any good.
__________________
My avatar is Candy Barr.
https://www.youtube.com/watch?v=HmhXdqajVaQ
Old 08-26-2013, 02:28 PM   #21
iroc409
Newbie
Quote:
Those meters, for using on cars checking voltage and stuff, are actually pretty accurate. There have been several people that have tested the results against higher dollar meters and had the same results.
I have a couple because they were free, and have tested them against my $60 (not a high-dollar Fluke by any means) older Craftsman and they have been consistent (reading DC volts and impedance).
I've been wanting to learn to weld and thought about going with a HF welder, but from everything I've read I think I'll get a gas blanket capable MIG from one of the big names, or at least Northern or Eastwood. Northern has one that comes with a regulator for a little over $300, and it gets decent reviews. Still no Hobart.
Old 08-26-2013, 02:34 PM   #22
56PontiacPiano
Sometimes you gotta spend more money, but over time you'll see that it was worth it.
Old 08-26-2013, 02:36 PM   #23
Crazy Steve
Quote:
I have a couple because they were free, and have tested them against my $60 (not a high-dollar Fluke by any means) older Craftsman and they have been consistent (reading DC volts and impedance)..
Yep, those meters are better than you think. I picked a couple up to throw in the glove box and my 'mobile' tool box, and it checked good against my $200 Fluke. Note that they don't like damp conditions, keep 'em dry....
Old 08-26-2013, 02:40 PM   #24
33sporttruck
Grenade Inspector
Miller Blue !!! You will never regret it. Buy it from a welding supply shop. Good Luck, Jeff
Old 08-26-2013, 03:13 PM   #25
studebaker eric
studebaker eric's Avatar
From experience. Do not waste your time or money.
Old 08-26-2013, 03:31 PM   #26
don-vee
don-vee's Avatar
Funny thing is, even though their welders are junk, the flux-core wire from HF is pretty damned good. It's made in Italy, not China, and it welds pretty nice and smooth with very little spatter, especially for flux-core. It's cheaper than the Lincoln wire I was previously using, and in my opinion it welds far better in both my little Craftsman buzz-box and my Lincoln 180. Go figure.
Old 08-26-2013, 03:40 PM   #27
fsae0607
Alliance Member
fsae0607's Avatar
I agree, those little multimeters have their place. I actually have one in our kitchen's "utility" drawer for when I'm too lazy to go out to my garage to fetch my good DVOM. They always got beat up in my DD truck toolbox, so now I just keep a test light in there.
I bought that HF flux core welder to learn wire feed welding. I can lay a decent (functional) bead with it. I've fixed a few items around the house and made a few brackets and fixed the broken parts on my HF manual tire changer. It's a decent welder for doing non-structural, mickey-mouse stuff. But if you're going to be welding frames and what not then yes step up to a good US made welder.
If you have one of those 90 amp HF welders the best upgrade you can do right off the bat is to get a good ground clamp. The difference is night and day!
__________________
Old 08-26-2013, 03:51 PM   #28
tommyd
Alliance Member
tommyd's Avatar
That much difference in the ground clamp? really? I have a nice ground clamp that I salvaged when my NAPA stick welder bit the dust. I may switch them out.
__________________
When I grow up, to beeee heee a man. Will I dig the same things that turned me on as a kid? Will I look back and say, I wish I hadn't done what I did? B. Wilson.
Old 08-26-2013, 03:55 PM   #29
fsae0607
Alliance Member
fsae0607's Avatar
Quote:
Yes. I ran a bead before and after to compare. Before my beads looked like bird caca. After it looked a lot better! Honestly, I think the ground clamps that come on the welder are for a battery charger; very little contact area.
__________________
Old 08-26-2013, 04:08 PM   #30
Dueced Up!
Dueced Up!'s Avatar
I pick my share of stuff at Harbor Freight. I did not have much luck with their wire welder. I was looking for the same thing...an inexpensive wire welder for smaller jobs. I ended up getting one from Eastwood. No problems with it and they are a sponsor of the H.A.M.B. Hard to beat that...!
__________________
"Get To High Gear And Hold It Till You Run Out of GAS, TRACK OR SACK!"
Old 08-26-2013, 04:23 PM   #31
elba
Grenade Inspector
Save your money and get a brand name WITH GAS !
Old 08-26-2013, 04:30 PM   #32
frankie3555
FNG
frankie3555's Avatar
I will throw my $.02 in..I got one and changed wire to Lincoln flux, to use on a some sheetmetal repairs on a 69 Cougar restoration I'm doing. It takes a little practice to get the speed setting right and to do sheetmetal I just stitch it all around and then fill in the spaces. Time consuming but it does work well. Haven't tried to weld anything over 17ga yet, like was said earlier 1/8" is probably the limit. I got mine for $70 on sale. I did have a much better gas mig several years ago, so I do know what a good welder is like, but for what I needed to do it works just fine. HF sells some crap but if you know what to buy you can get a good deal. So, far sand blaster-good, welder-good, powder coater-good, powder coating powder-bad, HVLP spray gun-good, wagner type electric painter-good, car bluffer/polisher-good. It helps to read the reviews for sure.
Old 08-26-2013, 05:07 PM   #33
cobalt333
cobalt333's Avatar
pay more now and get a good one...i bought the one your talking about..it did my car..BUT never looked like those nice weld dimes laying on dimes look...thats where its at
Old 08-26-2013, 05:16 PM   #34
tonyimpala
tonyimpala's Avatar
I had the same question, did not buy a HF welder.
Check out this post.
http://www.jalopyjournal.com/forum/s...d.php?t=784871
__________________
I cut it twice and it's still TOO short.
Old 08-26-2013, 06:17 PM   #35
LSGUN
Alliance Member
LSGUN's Avatar
Hobart or Miller.
Old 08-26-2013, 06:29 PM   #36
damagedduck
Senior Member
damagedduck's Avatar
I've been welding (sticking metal together) for most of my life & gotta say-do not buy one of those welders! my brother-n-law has one & damn~ that thing sux! check C/list or other trading places or even pawn shops, just save your money & buy a name brand welder~Chuck
__________________
my 30 year love affair-
http://s946.photobucket.com/albums/a...1949%20hudson/
Old 08-26-2013, 06:33 PM   #37
Hemishovel
Buy name brand I have had my miller for 15 years never had a problem tried cheap welders before that never worked right I tried HF wire to save money you get what you pay for never again only use miller wire now plus get one that uses gas I use co2
Old 08-26-2013, 06:35 PM   #38
SuRfAcE_RuSt
SuRfAcE_RuSt's Avatar
Just about everything from harbour freight is a POS.. Constantly replacing sanders, grinders, and other misc tools. Every air tool we've got their had to be replaced a month later. But their cheap soo...
__________________
Doubting you'll ever restore it.
https://www.facebook.com/monstrosity.rodncustom?fref=ts
Old 08-26-2013, 06:40 PM   #39
Hemishovel
Friend of mine just bought a miller new from welding shop he paid little over 500 it can he used with either 110 or 220with the plug they give you
Old 08-26-2013, 06:46 PM   #40
gimpyshotrods
Old School HAMBer
Even a bulky old Miller would be better than anything at HF. Infinity serviceable. The old ones are just bigger.
__________________
Old 08-26-2013, 09:41 PM   #41
Tinbender
Old School HAMBer
Tinbender's Avatar
Why is it so many guys want to use the worst tool available and the worst choice of welding processes? Body work is hard enough. Buy a torch
__________________
I weld, therefore I am.
Old 08-26-2013, 10:42 PM   #42
bonechop
FNG
bonechop's Avatar
My dad has never bought new tools! All of them are either from garage sales, swap meets or flea markets. Working in the mechanical field for 20+ years, I still hate going to his place to work on stuff while I have 2 fully stocked boxes of professional tools at home!!
Old 08-27-2013, 07:34 AM   #43
911 steve
Grenade Inspector
911 steve's Avatar
you get what you pay for, if you do buy it make sure to buy the extended warranty. I bought a pancake air compressor, it crapped out on day 95 and no, I hadnt bought the warranty.
Old 08-27-2013, 08:09 AM   #44
cuzncletus
FNG
I've owned both Lincoln and Miller equipment. The Lincoln stuff was fine, but my nod goes to Miller. I use my Miller welder and plasma several times a week. They've both got lots of hours and have never given a second's trouble.
The comments about buying at a welding store are also correct. Lowe's (pushing HF in the race to the bottom), Home Depot, etc. all have products with brand names on them from ceiling fans to welders. They ARE NOT the same products you would buy in a specialized supply store. Ask any plumber about the faucets, for example. Delta faucets from Lowe's have plastic parts that quickly break; Deltas from a plumbing supply house are all metal. The big box stores have the manufacturers cut corners so they can get the price down. Surprisingly, the price often isn't any different, even more, than from a reputable supply house.
If I ever buy anything from Harbor Freight or Northern Hydraulics I consider them disposable products.
Old 08-27-2013, 08:56 AM   #45
54rat210
Grenade Inspector
54rat210's Avatar
Its good to start with then graduate to a much better quality welder. I have a friend that swears by his. I still have my flux core hf welder but I use my HTP MIG 120 now.
__________________
54rat210
Old 08-27-2013, 08:59 AM   #46
64Cyclone
Senior Member
64Cyclone's Avatar
For an amateur builder a Hobart unit should be fine. I've had the HF flux unit and liked it...it's just not good for automotive fab work. You can shop around and find pretty good prices on a Hobart online. I think my 140 was $425 new free shipping.
Used would be cheaper, but I just have a fear of buying someone elses problems when I buy something used. A $250 $300 used welder might not be a good deal if you have to replace parts that are worn out like the liner.
__________________
Old 08-27-2013, 12:13 PM   #47
gimpyshotrods
Old School HAMBer
Buy a used one, from your local welding supplier, if used worries you.
Liners are under $20.
__________________
Old 08-27-2013, 12:18 PM   #48
falconvan
falconvan's Avatar
Not sure on HF but I bought a $300 140 amp Clarke welder at the local feed store over 10 years ago and it just keeps on going. I keep saying when it breaks i'll buy a good one but it refuses to quit.
Old 08-27-2013, 12:30 PM   #49
rokkett77
Alliance Member
rokkett77's Avatar
I have been looking for a good quality MiG welder myself. I had been considering one from Sears that looks nice. Im not a welder so I couldn't tel you if its a POS or not. It gotta be better than any welder from HF though.
http://www.sears.com/craftsman-mig-w...p-00920569000P
My cousin is a welder by profession and suggested a Hobart - they are American made and the internals are pretty beefy.
http://www.sears.com/tools-welding-e...R&viewItems=50
I know he has a Hobart, I don't remember if it is the Handler 125 or 140. I do know its a nice unit.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
