Technical ***August 2020 Banger Meet Thread - More of the Same***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2020.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    Everything is cancelled
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    TrailerTrashToo likes this.
  2. Checking in.
  3. poshdbs
    poshdbs
    I'm here.
    winduptoy likes this.
  4. dmdeaton
    dmdeaton
    August already?
  5. Thanks Jiminy
    I wish the coupe went as fast as this year seems to be
    J
    Jet96 and winduptoy like this.
  6. winduptoy
    winduptoy
    Welcome to August. A lot less than I hoped for. I planted my feet firmly in mid air when I jumped on this one. Well maybe I can use the 5 speed in the '29 Roadster. IMG_20200717_161136399_HDR.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    burl, Binger, railcarmover and 2 others like this.
  7. railcarmover
    railcarmover
    90 plus? no problem,pulls hard..back flushing junk radiators with an industrial hot water pressure washer with degreaser works,saved a few that way,including this one..
    camcrusher, winduptoy and Old Dawg like this.
  8. rwrj
    rwrj
    from SW Ga
    I'm here. Posted this on my speedster thread, just to wrap that build up, but I guess I'll post it here too. Just a little morning drive to test out my ridiculous looking but fairly effective head-mounted GoPro.
  9. In response to the conversation concerning rear end suspension; mine is a shortened torque tube, with external radius rods rotating on the frame rails (inline with the universal joint! The geometry of this setup is such that there are two 15 to 20 inch moment arms (crosswise on the frame) on either side of that torque tubes forward universal. , In roll. it places a twisting moment all along the tube as well as the radius rod wanting to bend. Something's gotta give! In a race down at the Coronado NAS it finally broke the flange on the differential housing. This allowed the torque tube to spin around the driveshaft. Quite a fibration with that spinning between my legs! Some of the early race cars like mine were built exactly how Henry's engineers designed'um! NOT MINE! millermaint001_zps2aab5d11 (2017_06_30 15_13_08 UTC).jpg All I can say is be careful!
  10. Jet96
    Jet96
    from WY
    Re cleaning out a radiator, this particular one was scaled nearly shut at the inlet. Several soaks with CLR and backflushes later I got about a pound of calcium and rust out but ended up with four cells leaking for my trouble...
    Hey the receipts that came with the pickup said it cost $216 new when it was installed in 1976!
    winduptoy and railcarmover like this.
  11. railcarmover
    railcarmover
    '76?..it still has its cherry..
  12. denis4x4
    denis4x4
    from Colorado
    Checking in
  13. Binger
    Binger
    from wyoming
    I am here too. Not much going on in my banger world. working on a gokart for my daughter and hope to get to mechanically freshening up my roadster after we are done painting her Kart. I am truly saddened to hear about the cancellation of the Hill Climb in Colorado. Hate to say it but its probably for the best. Need to Keep everyone healthy so we can see you all there next year.
  14. V4F
    V4F
    from middle ca.
    same ol banger here
    Steves46 and winduptoy like this.
  15. winduptoy
    winduptoy
    So, that was the noise I heard
    Jet96 likes this.
  16. V4F
    V4F
    from middle ca.
    probably as it is loud ............
  17. 7EACAA6A-9E20-4D5A-B129-D2B6B3CE9A36.jpeg Just a boring day here..........
  18. V4F
    V4F
    from middle ca.
    john , i thought you never got bored or stroked
  19. railcarmover
    railcarmover
    Girdle is feminine ,its smacks of a fat old lady... calling it a truss is manly,men use it use to support and reduce fatigue..
  20. Shutter Speed
    Shutter Speed
    Watching...listening.
    @rwrj - thanks for the ride!
    Curious what type wood you bored and split for your grab handle. Looked translucent?
    Art
  21. On some Men it should be a girdle.................
    Old Dawg and Jet96 like this.
  22. V4F
    V4F
    from middle ca.
  23. Steves46
    Steves46
    from Florida
    Checking in and getting a little smarter each day with these Bangers.
  24. railcarmover
    railcarmover
    Definitely admire you putting enough through it to need it..
  25. Brendan1959
    Brendan1959
    Basic easy home made banger valve spring compressor.
    IMG_5680.jpg IMG_5681.jpg IMG_5682.jpg IMG_5684.jpg IMG_5685.jpg IMG_5686.jpg IMG_5687.jpg IMG_5690.jpg
    winduptoy, Jet96, Old Dawg and 5 others like this.
  26. Dustyp489
    Dustyp489
    Just checking in. Hope you all a great August, stay safe
  27. V4F
    V4F
    from middle ca.
    nice DIY tool
  28. rwrj
    rwrj
    from SW Ga
    Shutter,
    It's Longleaf Pine heartwood. We call it lightered down here. Other folks call it fatwood or fat lighter. I have a back door made of Longleaf, and the sun glows through one of the panels if it hits it just right. It's really wonderful stuff. burns like it is soaked with gas.
  29. Johnny Nitro
    Johnny Nitro
    from Chicago
    Just checking in.
    Went to a 32 grill for the A. Been to a few shows. Glory Days at Byron was fun. Thinking of you all. Stay safe.
  30. V4F
    V4F
    from middle ca.
    i see a good deal . clean it up & take it apart , it is a "B" after all
