History Moon Tank Mystery
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Aug 13, 2021.
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    J.Ukrop submitted a new blog post:
    Moon Tank Mystery
  2. Dig back in the HAMB archives, many good stories and threads about hydrazine. I think we first talked about it 20? years ago?
    Sparky57, AHotRod and seb fontana like this.
  3. oldcargary
    oldcargary
    from devore, Ca
    Always liked the look of a moon tank. Still have a few in the shop.
  4. KevKo
    KevKo
    from Motown
    Cool find. Hydrazine? Naaasty stuff! IIRC it is rocket fuel and will self ignite. Bad.
  5. dreracecar
    dreracecar
    from so-cal
    Racers would often add DYE to the fuel to change its color to mess with the other races, The Surfers team of Skinner & Jobe were famous for doing this. You cant run on 100% Hydrazine , too dangerous and volatile to handle. When the racers did experiment with it, it was only a beaker full to 5 gal, pour it in, cap and shake the tank--- get the hell out of the way
    Deuces and Budget36 like this.
  6. big john d
    big john d
    from ma
    the last space capsule that was recovered and put on the deck was not openedd for 10-15 minutes so the hydrazine vapors could disapate they use it in the small steering jets ( rockets?)
  7. Budget36
    Budget36
    I like the “shake it up and run” !!!
    catdad49 likes this.
  8. DDDenny
    I imagine those ears on the cap were not removed for saving weight but so it couldn't be overtightened, as per the warning.
    A bit of a pressure relief I assume.
    catdad49, Kevin O'Connell and Deuces like this.
  9. yellow dog
    yellow dog
    from san diego
    I don't believe the DYMO tape labels have much credibility. The "100% " label is ridiculous.
    The "Do Not Tighten Filler Cap" is another question as UDMH absorbs atmospheric moisture
    quite readily. UDMH BP is significantly higher than even gasoline, so that's the least of other
    safety concerns.
    Lots of fuels were experimented with in the 50's maybe 60's until finally NHRA
    squashed. I still like propylene oxide w/ nitromethane used at whopping 3%, but NHRA made a big issue out of it. In my later career I utilized 20K gal railcars monthly w/o ESH issues.
    Kevin O'Connell likes this.
  10. dreracecar
    dreracecar
    from so-cal
    Forgot to add---- at the end of the run, immediately drain the tank of the remaining fuel
  11. Truck64
    Truck64
    from Ioway
    Hydrazine was used for spacecraft thrusters as one component of what are known as hypergolic propellents, usually paired with nitrogen tetroxide.
    They wanted something simple and reliable, the two components pretty much mind their own business till they are mixed. One of the lesser known "features" of the Apollo lunar module, there could be no actual testing of the actual engines used in the spacecraft because these particular chemicals are so corrosive. So every liftoff from the Moon was the first, and only, instance where that particular engine had ever been fired. If they didn't work for any reason, the Astronauts would be marooned.
    Nick32vic, Driver50x, rod1 and 2 others like this.
  12. Speed Gems
    Speed Gems
    kidcampbell71 likes this.
  13. Truck64
    Truck64
    from Ioway
    I thought the Moon was on topic? :)
    Sorry if any delicate sensibilities were offended. /s
    Nick32vic likes this.
  14. Okie Pete
    Okie Pete
    Very Kool buy . What’s the story on the belt buckle with the roadster on it !
  15. Rramjet1
    Rramjet1
    F-16’s use a form of Hydrazine to operate the Auxiliary Power Unit.
    Deuces and Truck64 like this.
  16. Kevin O'Connell
    Kevin O'Connell
  17. Kevin O'Connell
    Kevin O'Connell
    Cool hydroplane- yours? Still got it?
  18. Kevin O'Connell
    Kevin O'Connell
    I’m a nut for anything vintage Moon. Even my 6 volt positive ground has a voltage inverter and a Moon tach. And all their finned aluminum I can find!
  19. It was labeled like that as a joke… I’m sure the other racers laughed. FWIW, that pwrformance automotive shop was the sole supplier of race fuel at Bonneville for decades.
    Nick32vic and J.Ukrop like this.
  20. Kan Kustom
    Kan Kustom
    I thought I was the only guy in the world that lopped off the cap wings. I got my Moon tank soon after they started putting the different caps on and I lopped the cap wings off and polished it to look less old. Funny the the things we do to change with the times only to think how silly it was , looking back.
    41 GMC K-18 likes this.
  21. Atwater Mike
    Atwater Mike
    Talked to an older feller at Pomona a few years back. He was a machinist that contracted with Dean Moon in the mfg. of the Moon tanks.
    He laughingly referred to himself as a 'retired Moonspinner'!
    Nick32vic and catdad49 like this.
