Technical ***May 2020 Banger Meet Thread - 4 are Essential***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2020.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    Everything is cancelled
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. denis4x4
    denis4x4
    from Colorado
    Checking in from an undisclosed location.
    Jet96 and winduptoy like this.
  3. Checking in.
    winduptoy likes this.
  4. wheeltramp brian
    wheeltramp brian
    Checking in from ca
  5. I'm in......or out in the shop
    J
  6. noboD
    noboD
    I've had more then enough of all the events being cancelled. What has happened to life?
    bali-rod likes this.
  7. Doug, Brad is holding his swapmeet in Commerce tomorrow- c'mon down :D!
  8. klawockvet
    klawockvet
    Checking in. Every Friday night in Kanab Ut is cruise night. It’s like the old days dragging main
  9. Crazydaddyo
    Crazydaddyo
  10. noboD
    noboD
    I hope Brad has a good turnout, let us know.
  11. winduptoy
    winduptoy
    Crazydaddyo, barrnone50 and poshdbs like this.
  12. sanitary napkins don't need duct tape................J
    winduptoy, Jet96, Crazydaddyo and 2 others like this.
  13. poshdbs
    poshdbs
    I'm here too!
  14. barrnone50
    barrnone50
    from texas
    Checking in trying to get a little Giddy Up and get the body blasted for some primer.. Roadster t.jpg
  15. luckylou
    luckylou
    from canada
    I'm here a new month hope we get over all this shit so we can attend some shows, but at least I'm get some old projects finishe out of all this mess, hope everyone is staying safe
  16. Crazydaddyo
    Crazydaddyo
    Seams a shame to cover all those pretty rockers
    The oil pan has been a trooper. So far it has managed to retain the pieces of 2 crankshafts.
    Sent from my SM-J337P using The H.A.M.B. mobile app
    Shutter Speed, burl, Old Dawg and 5 others like this.
  17. Gary in MN
    Gary in MN
    upload_2020-5-1_22-59-17.png Clear valve covers ? upload_2020-5-1_22-59-17.png Gary in MN
    Shutter Speed, burl, Old Dawg and 4 others like this.
  18. railcarmover
    railcarmover
  19. V4F
    V4F
    from middle ca.
    off topic : has anyone rewired there car & soldered every connection ? i do not recommend it unless your in lock down ................ steve
  20. klawockvet
    klawockvet
    I always did till I started desert racing two stroke bikes and found that proper crimps were better. Crimping correctly with proper tools is the way to go.
  21. V4F
    V4F
    from middle ca.
    when driving truck , i found that they collect corrosion , therefore they break at the crimp . really bad in winter . went to Boise in January , what a crock . so much damage from snow , ice , cinders .
    lock down gave me time to try it . WOW very time consuming .
  22. Jet96
    Jet96
    from WY
    -Checking in for May-
    Local guys put together a Thursday night Main Street Cruise. I didn't make first one, but looked like turnout was good.
    Going to install my Brierley head this weekend. Trying to do one thing at a time to see what each mod contributes to driveability.
    When I did my roadster I put the hi comp head on stock motor. Drove it like that all summer while I stockpiled the rest of my stuff. Next step was cam, dual downdraft, headers, mallory, and lightened flywheel...To say driveability was improved would be a fair understatement.
    When I first got my (all stock) CCPU I thought the parking brake was on ha-
    -Klawockvet-
    That's interesting. I had a similar experience on my dump trucks a long time ago. I've pondered how to do the molded rubber around the connections like factory.
    burl, Old Dawg and winduptoy like this.
  23. Bigcheese327
    Bigcheese327
    Well, color me intrigued. I can read a wiring diagram just great, but I SUCK at soldering. What are the tools you use?
  24. Jet96
    Jet96
    from WY
    I use the non-insulated heavy duty terminals (I think Lawson maybe?) they have double crimps. Good heatshrink tubes stay somewhat flexible, but I can't remember what brand I've got.
    Old Dawg likes this.
  25. Dustyp489
    Dustyp489
    Checking in, hope all is well
    Skip
  26. fourd
    fourd
    from Colorado
    Cleaning up and throwing out junk in the shop. 3B8BC66F-1E89-4F8C-8DC1-3CF8C448C6EC.jpeg CFCDB0E8-4864-435D-9BF5-70426301F9A6.jpeg 3A531E06-079A-4654-91EE-4E848F6A2E86.jpeg
  27. guitarguy
    guitarguy
    It's the only way I do wiring. I will admit of you have a proper crimper and terminals, it is just as good. I don't and have done it my way for so long I just keep doing it.
    And yes, good heat shrink is a must. I seal all my connections. I am a fan of the 3:1 ratio adhesive lined shrink tubing.
    Jet96 and Old Dawg like this.
  28. winduptoy
    winduptoy
    Yes,
    On my 1953 Travelall Binder.
    I'm not very bright but the lights are
    Jet96 likes this.
  29. winduptoy
    winduptoy
    Nice and indented firewall to boot for a late '31. I see it looks like you put a plate over the terminal box opening.
  30. fabricator john
    fabricator john
    from venice fl.
    "The oil pan has been a trooper. So far it has managed to retain the pieces of 2 crankshafts."
    CRAZYDADDYO
    QUOTE OF THE YEAR FINALIST
    Fabricator John
