Technical *** June 2016 Banger Meet - Time for Crickets and June bugs***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 31, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. denis4x4
    denis4x4
    from Colorado
    Checking in.....32/36 Weber is great image.jpeg may have lost some power as I did not replace the chrome head nut covers when I replaced the head gasket
    40 Ford Tudor, waxhead and Jet96 like this.
  3. BCCHOPIT
    BCCHOPIT
    Thanks for the link !!!
    Holy crap it's June!!!! How did that happen
  4. june, june, june,,,,,,,,,,,,,,,,,,,,JUNE!! Already!!
    August will be here before I know it.
    sorry, back to the regularly scheduled program.......
  5. checking in with daily running of the last bangers....
    Just been enjoying my stocker. When I get back from the east coast I hope to start on the T for real.
  7. 97
    97
    August!?...does August have a special significance? ;):cool::rolleyes:
  8. The37Kid
    The37Kid
    Grandson is now 4, just added five powder coated wheels to his A chassis project. Can he join 4Ever4 now? Bob
    Tiny likes this.
  9. OK now the 4 year olds are showing me up. Time to move faster on my project.
    Tiny likes this.
  10. At what point do you start to need billet rods?
  11. Binger
    Binger
    from wyoming
    Checking in for the month! Hopefully within a week I will start priming my coupe. I will post up some pictures when I get to spraying.
  12. Bonneville Speedweek.
  13. The37Kid
    The37Kid
    How does the salt look this year?
  14. V4F
    V4F
    from middle ca.
    what carb ? any more pix . nice car
    Tiny likes this.
  15. denis4x4
    denis4x4
    from Colorado
    It's a Weber 32/36 on a manifold available from Bert's Model A in Denver. Had to machine the manifold to get it to fit under the hood. image.jpeg
    This is the second Zipper built by Darrell in 2000 and the only one I know of with a banger.
    burl, Jiminy, Tiny and 1 other person like this.
  16. V4F
    V4F
    from middle ca.
    the weber is different than mine . cool car !!!!!!!!!!!!!!
  17. fourd
    fourd
    from Colorado
    1243
  18. Crazydaddyo
    Crazydaddyo
    Plug the 1/4" hole with a 5/16" set screw. Thread the hole with a 5/16" - 18 tap but don't tap it all the way through. Use a set screw that will bottom out and sit below the top surface of the block. Then fill the remaining hole with JB weld and file it flush when hard. Do all of the 1/4" holes.
    fourd likes this.
  19. wright
    wright
    from illinois
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg Finally finished up my pickup enough to drive around more than the neighborhood. I had the engine rebuilt from Rich in Skokie he did a touring engine for me with a counterbalanced crank and a Bill Stipe cam. The head is a Charlie Yapp Riley 2 port along with his Y headers running to the dual exhaust. I installed a 904 automatic trans from a slant 6. The trans swap led me to add ladder bars and make a few new cross members. I swapped out the original steering box for a 1956 ford pickup box and added the 39 banjo. The truck had hydraulic brakes when I bought it,while redoing the brakes I went with the Lockheed style front brakes. While test driving around the neighborhood the last couple of months working out the little kinks, I found my radiator was bad. I had it recored last week by my wife's cousin who is 70 he still runs his dad's radiator shop although I don't know how much business he still does. He let me watch him take it apart and called me when the core came in so I could see th process of swapping in the new core. Let's see if these pics work ?
    mcyunger, 29bowtie, waxhead and 3 others like this.
  20. wright
    wright
    from illinois
    It looks like the pictures worked now let me try a video.
  21. wright
    wright
    from illinois
    Nope. Well one for two is not bad. I have a couple short four to five second videos of it ideling in the drive.
  22. Crazydaddyo
    Crazydaddyo
    A freshly machined head and block don't always mean you will have a joint flat enough to use a solid copper gasket. Many people believe you need to lap the head to the block to get the surfaces flat enough.
    fourd likes this.
  23. winduptoy
    winduptoy
    What Crazeedadyo said
    I would suggest that you do not use anything on the Best gasket
    65 ft lbs is pushing the upper envelope of the range. I do not like to go above 55 ft lbs on the head torque. You will start to draw the stud out of the hole.
    Make sure you follow the thermal cycling of the engine. I will let the head set for hours and re torque cold
    Operate up to temp turn off and let sit until ambient temperature and re-torque
    Go for a drive and let cool to ambient temp and re-torque
    I keep re-torqueing until I get no more tightening of the nut
    Let us know how the fire rings work out
    fourd likes this.
  24. V4F
    V4F
    from middle ca.
    I believe you said "solid copper" . if so you need to "O" ring the block . it will never stay sealed unless you do . we ran a drag bike with solid copper head gasket because the are reusable . but the "O" ring is a must . hope you get it fixed ................. steve
  25. fourd
    fourd
    from Colorado
    Regarding head gasket:
    Thanks guys! Hot Rod Dirt Drags is June 10th-12th so 9 days is plenty of time for me to break something else.:)
    ROCKER77 likes this.
  26. same as every other year at this time, under water.
    The conditions will not show for another month or so and then there will be all the speculation.
    "we are racing, up until the event is cancelled" there are also two rain date applications with the BLM.
    J
  27. I am not sure about the lapping process, I would think the decks move too much to be effective.
    I do agree with the 55# torque figure, and use the best studs available. I think the 65# number came from a time when the studs were NC threads on both ends, that would make the clamping force about the same.
    As for Best gasket sealant, I have not seen a need for it, however, I don't leave them on for too long a time.
    Solid copper gaskets need to be annealed every time you take one off and reuse. I have copper orings in decks and use silicone to seal up the water. The first time I used one without sealant looked like a sprinkler when the pump came on.
    J
  28. 97
    97
    Yeah mate, I was really being a bit facetious , I hope for your sake there is enough salt and good weather, however once again I won't make it this year, still sorting Dad's estate, can't leave farm and animals to fend for themselves.... I like to make it a 3 month visit when I do get to the USA in summer.
  29. Check in! I didn't post much!! Just this year I purchased an smart phone!!! So Now I can post in any time!!! [​IMG]
    Enviado desde mi XT1068 mediante Tapatalk
    Tiny and ROCKER77 like this.
  30. [​IMG]
    Tiny likes this.
