Technical *** July 2016 Banger Meet - Look for banger parts while on vacation***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. Checked in, thanks Jim
    Just alerted that the survey crew visit to Bonneville resulted in what looks like 3 courses for SpeedWeek.
    Now if Mother Nature would just cooperate.....
    John
    Dannerr likes this.
  3. Bluto
    Bluto
    We won't be at B'ville but we have been hoping for the best..... good luck
    My Dr's still don't want me flying for 15 hours
  4. V4F
    V4F
    from middle ca.
    good luck on the salt
    jimski take care !
  5. denis4x4
    denis4x4
    from Colorado
    From time to time, the guy that maintains a small muscle car collection for a major speed equipment manufacturer vacations in Durango and I'm fortunate to have him work on my A's. Finished up the '29 CCPU with the B motor and original CRAGAR yesterday. He'll do the Zipper today so it's ready for the FAST hillclimb in Utah on the 16th and 17th
    Dannerr likes this.
  6. Bluto
    Bluto
    Open heart surgery takes a little time to get over.
  7. 97
    97
    We better all come to visit instead of going to Bonneville! :D Get well soon...
  8. Bluto
    Bluto
    Thanks I'll be OK .... I've lost nearly 50lbs since the surgery...... about 20 to go.
  9. Crazydaddyo
    Crazydaddyo
    Good to hear you doing better Jim!!!!!!!
  10. jerseyboy
    jerseyboy
    I don't post much on here, but I've had a subscription for years and I lurk a lot.
    First, Jim, keep getting better.
    Second, I am going to make some rocker arms for the Ford B fuel pump. Ford stacked three pieces of .080 steel and riveted them together. I am going to make them the same way. Question, what type of steel might be best for this purpose. I know a bunch of you guys fab stuff, so I thought this is a good place to ask.
  11. Bluto
    Bluto
    Thanks guys........ I just go on ....... it's not a straight line but it's up more than down. Even when I can't use my hands I still stay active in design and solutions for our projects and sometimes for others. There's always a project around here
  12. 97
    97
    Not a huge load on them, probably just made from mild steel , maybe with a hard pad for wear surface . Quite a few pumps are the same as B Ford.
    In fact there are a bunch of AC pumps with the same body , mount and internals where only the lever changes for different applications. ANd some other makes use the exact same pump as the B.
    http://www.fordgarage.com/pages/bfuelpump.htm.
  13. V4F
    V4F
    from middle ca.
    good for you jimski . I'm havin a bad month also , but I think its the heat here . keep on keepin on
  14. Binger
    Binger
    from wyoming
    Checking in for the month.
  15. After sitting for a month waiting on basic gaskets from one vendor, I cancelled the order and got a set from Snyders within a week. Got it back together and fired up. Just idled in the driveway as it got late. Now onto syncing the carbs and timing.
    Dannerr likes this.
  16. orangeamcs
    orangeamcs
    green73, which vendor were you using?
  17. With reluctance, I'll admit it was Mac's with the delay on the gaskets. No clue why the delay, and I didn't ask. Simple engine gaskets... That said.
    Success!!! I can now drive the Banger powered A! After a tuning session and a few trips to the local hardware store and having a new end crimped to a fuel line, It is drive-able! Today was the first time I have driven the car without stumbling, falling on it's face, backfiring, etc... Will it need refining? Possibly. Is it fast? Well having never driven a stock Model A, I can't say. It's is okay for around town and possibly to and from work. I am planning on a GPS recorded run tomorrow on a long, straight, flat patch of road (Rosamond Bvd) over the lakebed on Edwards AFB. No matter what happens there I am giddy to have it back up and running and not a nuisance to other drivers. Now onto non engine related changes, (Chop Top, bumper and fender removal, etc...) but that's for another thread.
  18. Well, Had it up to verified 65 on the flat road entrance to Edwards AFB. It had more but I was okay with that. At 60 it was quite comfortable and I'll be fine with that for the commute occasionally to and from work. I need some wheel time to iron out my shifting style and shift points.
    Dannerr likes this.
  19. Crazydaddyo
    Crazydaddyo
    We use to make a fuel pump lever to adapt a high volume Big block Chevy fuel pump to a big block Ford. We used 1095 steel and had them heat treated and parkerized. The 1095 steel developed a hard skin but the core doesn't get brittle.
  20. Any one looking for a complete 5spd ready to drop in your A? I'm trying to help the widow of the original owner of AC&R sell it. ImageUploadedByH.A.M.B.1467741459.091205.jpg ImageUploadedByH.A.M.B.1467741477.358115.jpg ImageUploadedByH.A.M.B.1467741515.453832.jpg
    PM me and I can give you more details/pics
  21. So if I have one with a corroded body, can I get a different one and switch my good lever over??
  22. 97
    97
    I would, yes. You should probably inspect/compare all the internals , check that the springs are the same or similar, I think that is what decides the pump pressure. However as I said , I would just swap the levers and try it....it will either work or not...if pressure is to high look further.... I know on some cars the thickness of the gasket makes a big difference on the leverage and therefore pump pressure. Thicker gasket shortens effective stroke and lowers pressure..I am talking about a 1/4 inch thick insulator gasket as opposed to a paper gasket..
  23. jerseyboy
    jerseyboy
    97 and Crazydaddeo, thanks for the replies. I was considering 4140 and 4130.
  24. 97
    97
    I think those Moly steels would be a PITA ,they need to be annealed , or at least normalised to be machined , then if you want to harden the whole thing or part of it for wear resistance, it will have to be tempered following the hardening...temperatures and processes are critical to avoid embrittlement.... The 1090 Crazydaddyo suggested is much easier to harden and will still have high strength without being brittle...far fewer critical processes to get to the end goal.
    jerseyboy and Crazydaddyo like this.
  25. edfueler
    edfueler
    Some fun squirting a bit of dirt in my RPU at the Mudrun, Gresford, NSW, Australia.
    cactus1, waxhead and Dannerr like this.
  26. jerseyboy
    jerseyboy
    What is the easy way to harden for the "shade tree mechanic". Can you school me on this, since hardening metals can be pretty involved. Thanks.
  27. Crazydaddyo
    Crazydaddyo
    97 likes this.
  28. Crazydaddyo
    Crazydaddyo
  29. blgitn
    blgitn
    That's a lot of fun!!
  30. BCCHOPIT
    BCCHOPIT
    Jerseyboy why make them out of 3 pcs. ?
    Ford stamped them out by the 1000s almost made sense. Why not make them out of a chunk of tool steel? I know you like to tinker but if you need pump parts stop by I have some good cores
