Reply
Thread Tools Display Modes
Old 07-21-2013, 12:53 PM   #1
32highboy54
Grenade Inspector
32highboy54's Avatar
Default Tail lights problem
Here's my problem. I found some tail lights housing and sockets I want to use on my 32. They are old 6 volt style. I am keeping the the sockets but I switched out from a single contact to a dual contact pigtail. I am getting juice to the pigtail but when I turn on the head lights the tail lights won't go on. Even if I touch one of the contact on the pigtail with the prob tester I get juice.
offline   Reply With Quote
Old 07-21-2013, 01:11 PM   #2
Harvey29
Grenade Inspector
Harvey29's Avatar
Default Re: Tail lights problem
make sure the the housing and the socket are both grounded. When I installed mine I had to use a rat tail file and clean the bore where the socket goes through.
online   Reply With Quote
Old 07-21-2013, 01:14 PM   #3
32highboy54
Grenade Inspector
Thanks will give that a try
Old 07-21-2013, 01:20 PM   #4
Jcox68rt
Grenade Inspector
Jcox68rt's Avatar
Maybe once you sand or rat file it, reassemble with a little di-electric grease where it makes its ground.
Old 07-21-2013, 01:23 PM   #5
jan bogert
jan bogert's Avatar
do u have a 6 volt system, or a 12 volt? I know on my 6 volt system, I had to ground the housing an the more ground the better.
Old 07-21-2013, 01:32 PM   #6
32highboy54
Grenade Inspector
It works just fine now..tank you
Old 07-21-2013, 01:34 PM   #7
GeezersP15
Grenade Inspector
GeezersP15's Avatar
The bulb and the contacts in the socket may not be aligned correctly. If you are using a 1157 bulb, you may have to do a bit of surgery on the socket so that the indexing pins on the bulb ensure that the bulb is firmly seated against the contacts in the socket.
Oh well, I guess I didn't type fast enough. Disregard please.
Old 07-21-2013, 02:55 PM   #8
HOTRODPRIMER
Alliance Member
HOTRODPRIMER's Avatar
Won't work unless one of the wires are grounded. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot
'54 Ranch Wagon build photos
Old 07-21-2013, 03:10 PM   #9
A Rodder
Senior Member
A Rodder's Avatar
Sounds like you got it.
The socket housing always needs grounded wether it is through the light housing or a ground wire coming off the socket housing
6 -12 volts, makes no difference.
__________________
Joe
My 1930 Ford Coupe build thread.
http://jalopyjournal.com/forum/showt...r /> t=626730
Modelajoe on instagram
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
