Reply
Thread Tools Display Modes
Old 05-11-2012, 10:11 PM   #1
1oldtimer
Old School HAMBer
1oldtimer's Avatar
Default Header repair/epoxy question
Has anyone tried Loctite 95724 2000 deg epoxy for header repair.
or this:
http://www.grainger.com/Grainger/BLU...&cm_vc=IDPRRZ1
I had to modify some headers I bought and they're leaking a little bit. They're leaking on the inside of collector where the little plus piece of metal is and I can't get anything in there to weld it. I thought I got it all by melting rods in there and pushing the puddle with the torch. Now they're coated and leaking, so I would rather try this if it works for pin holes and not have to burn off the coating and try to re weld.
Click image for larger version
Name:	header drivers-22b.jpg
__________________
#1 Post killer
offline   Reply With Quote
Old 05-11-2012, 10:28 PM   #2
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Default Re: Header repair/epoxy question
Can't you weld that from inside the collector ?
Never tried that stuff.
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 05-11-2012, 11:00 PM   #3
1oldtimer
Old School HAMBer
1oldtimer's Avatar
The collector is about 3-4" long and necks down pretty good. I was using a light inside to make sure I got it all, but I guess I didn't. I'm trying to save the coating if I can. The picture above is the area it's leaking from, but the leak itself is barely bigger then a pin hole.
__________________
#1 Post killer
Old 05-12-2012, 10:28 AM   #4
Blue One
Alliance Member
Blue One's Avatar
That picture is really confusing and has me wondering just what am I looking at
There appears to be an open pipe in the picture to the right ??
Old 05-12-2012, 10:56 AM   #5
31Vicky with a hemi
Alliance Member
X 2
I was thinking about this some more.
There should a " star " welded to the center of all 4 pipes, that seals the centers where you can't weld it to the collector. That's inside the collector. The better ones come to a point, the cheaper ones are flat. Then the collector is swaged on the pipes for a tight leak proof joint and then welded. You should be able to get in there and weld it with a straight tip torch or straight neck MIG gun.
This pic looks like the collector is flush with the pipes, 1 star and 4 irregular triangles. That setup needs to be welded and still likely to fail/ break the welds.
If you have the pipe out of the collector now, how are you going to keep it in without welding it. Also if one is out, can you get the others out, make your repairs and put it back together ?
That epoxy is worth a shot and doesn't doing like you have much to loose by trying
__________________
Old 05-12-2012, 11:07 AM   #6
tommy
Old School HAMBer
tommy's Avatar
weld it up and hit it with a spray bomb. It will look much better than a repair of built up epoxy. I hate the exhaust repair shit that they used to sell. I'd alway charge more for the repair if they cobbled it all up with some kind of quick fix epoxy shit. Fix it right and be done with it.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 05-12-2012, 12:07 PM   #7
Screamin' Metal
Screamin' Metal's Avatar
Cool Re: Header repair/epoxy question
Hahaha....I like that one Vicky!
Crack in headers? Whats wrong with just welding it? If its too thin, it makes for some good pratice.
Old 05-12-2012, 12:08 PM   #8
Screamin' Metal
You'd be surprised what some determination and a good MIG will accomplish!
Old 05-12-2012, 12:09 PM   #9
Screamin' Metal
Oh, and the right wire and the right polarity!
Old 05-12-2012, 04:37 PM   #10
1oldtimer
Old School HAMBer
1oldtimer's Avatar
The picture I posted was when it was apart, just trying to show the area where it's leaking (hard to see now). It's all welded up and coated now, got about 99% of the inside where the star is with a tig and I tried to get the other 1% with a torch. I used a flashlight to find any leaks and I though I got them all.
I guess I can try the stuff, if it doesn't work I have to burn off the coating anyhow. At least I'll know if it's the only leak or not.
Name:	drivers header done-1a.jpg
ID:	1637210   Click image for larger version
__________________
#1 Post killer
Old 05-12-2012, 05:16 PM   #11
TexasHardcore
Old School HAMBer
TexasHardcore's Avatar
lop the collector off between the flange and the primaries and weld it up from the inside, then weld the collector back together.
__________________
Tune Up or Tune Out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
