Reply
Thread Tools Display Modes
Old 10-19-2010, 01:45 PM   #1
PR51
Grenade Inspector
PR51's Avatar
Default 51 chevy power brake conversion
new guy here...
will be finished paying off our 51 chevy soon and pick it up in December... one of the first things i want to do is a brake conversion.
Any help for a beginner here?
where to go?
best options? etc...
thanks,
Larry
__________________
Gotta live this life, till you die.
offline   Reply With Quote
Old 10-19-2010, 02:07 PM   #2
73super
73super's Avatar
Default Re: 51 chevy power brake conversion
'51 Chev brakes are great! Parts are plentiful. I've switch my '49 over to '51 because you can actually get brake parts.
If it's a stocker (mine isn't).. your brake system is more than adequate.
If you really want to upgrade to a disc system there are various companies that have bolt on kits. Chassis engineering being one. Do a search on this website or a google search for 49-52 brake conversion.
Good luck.
Old 10-19-2010, 02:22 PM   #3
PR51
Grenade Inspector
PR51's Avatar
thnx...
I've driven it and it isn't too bad but people out here drive crazy and I live in the city. All it takes is one girl on her cell phone cutting out in front of me and bam... jail time LOL
I'll check out Chassis Engineering and do more searches.
thnx again,
~ljb
__________________
Old 10-20-2010, 02:35 PM   #4
PR51
Grenade Inspector
PR51's Avatar
Anyoneever use ECI Disc conversion kits? If so some feedback would be cool.
thnx
__________________
Old 10-20-2010, 04:05 PM   #5
Lobucrod
Alliance Member
Lobucrod's Avatar
I just put an ECI set up on my '50 Sedan Delivery. Works great. Drums were ok but I pull a trailer so I went with discs and hung a booster on the firewall. Hated to junk up the engine compartment but with a 401 Nailhead with 2-4's and a trailer behind it I figured I would need all the brakes I could get.
__________________
Makin it Git with Old Shit
Old 10-20-2010, 04:59 PM   #6
tb33anda3rd
Old School HAMBer
tb33anda3rd's Avatar
never had bad advise or a bad part from ECI. been dealing with Ralph and his guys for 20+ years they won't stear you wrong!
__________________
my favorite color is rust!
Old 10-20-2010, 05:16 PM   #7
poboyross
Senior Member
poboyross's Avatar
Put an ECI front end kit on my 50....worked out great. You'll likely have to do a little grinding on the bracket, but I hear that's normal. This was my first build and it wasn't a big deal.
ALSO, consider getting a firewall mounted booster/MC/bracket combo from Walton Fabrication. Todd (the owner) is a great guy and a straight shooter. You can also get the bracket/pedal combo by itself, too. EXTREMELY happy with that one, too.
__________________
Faux'dster Build thread: http://www.jalopyjournal.com/forum/s...d.php?t=615579
Old 10-20-2010, 05:28 PM   #8
James Curl
Alliance Member
Buffalo Enterprises Phone (360) 652-7684 has disc brake kits that do not move the wheels outward. 37-54 Chevys only. They sell dropped spindles, lowering blocks, Saginaw steering kits and rear spring kits. They also sell an adapter to adapt a 235/261 to power glide,Turbo 350 & 400.
Old 10-20-2010, 06:03 PM   #9
lucky53
Alliance Member
lucky53's Avatar
I'm in the middle of putting a disk brake kit from E.C.I. on my 54' Chevy.
So far So good...
Real happy with the products and service from E.C.I.
I wanted to keep the stock look. (No booster on the firewall.) E.C.I. sells a bracket to keep stock pedals and upgrade to a dual master cylinder while keeping everything in the stock location under the floorboard.
A bit of fabrication required...
Is anything really just "Bolt on"?
Click image for larger version
ID:	1124955   Click image for larger version
Old 10-20-2010, 10:32 PM   #10
PR51
Grenade Inspector
PR51's Avatar
Good Stuff... I really appreciate all the feed back and suggestions from everybody.
Glad I found this sight.
thnx
__________________
Old 10-20-2010, 10:38 PM   #11
KOTC
Grenade Inspector
KOTC's Avatar
Scarebird makes excellent products and i believe they are also a hamb vendor
Old 10-21-2010, 12:01 PM   #12
PR51
Grenade Inspector
PR51's Avatar
Thnx,
yeah Gator sent me scarebirds websight but it doesn't look like they have my year... Under pic your make and model it starts Chevy off at 64-70smthing...
thnkx though.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
