Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-26-2009, 03:46 PM   #1
ROADSTERJEFF
ROADSTERJEFF's Avatar
Default 454 engine in a 1951 Chevy truck!
Got chance to pickup a (1982) 454 big block and transmission with only 50,000 miles. Will it fit in a 1951 1/2 ton Chevy truck with out cutting the fire wall.
offline   Reply With Quote
Old 10-26-2009, 03:50 PM   #2
Old School HAMBer
squirrel's Avatar
Default Re: 454 engine in a 1951 Chevy truck!
maybe if you move the radiator forward far enough! short water pump helps
steering clearance is fun too
__________________
Jim Forbes
my shtuff
Old 10-26-2009, 04:01 PM   #3
junk yard kid
Senior Member
junk yard kid's Avatar
my buddy isnt haveing that problem, its headers for him
__________________
Just cause you can, doesnt mean you should
Old 10-26-2009, 04:03 PM   #4
52pickup
52pickup's Avatar
It should fit... making everything else fit around it will be the challenge!
__________________
Bart Parker
Parker Rod 'n' Custom
Old 10-26-2009, 04:16 PM   #5
The Shocker
Old School HAMBer
The Shocker's Avatar
Smile Re: 454 engine in a 1951 Chevy truck!
Not sure about the 55 1st series and down ,but i have seen a 454 in a stock 58 Chevy Apache ,and it fit pretty well and it was mated to the 4 spd granny.I think it would be real close on the firewall ,and radiator on the 51 ...
__________________
Go for an 11.5 ET ride in my Dodge .http://www.youtube.com/watch?v=OAjcsGx6hqo
Old 10-26-2009, 04:20 PM   #6
rainh8r
You can do it with the short pump, small-cap distributor, and custom headers. The steering is right there, so moving it to the left is necessary if you try to use exhaust manifolds. They also need a really good radiator and a way to get the hot air out from under the hood-the engine fills the compartment pretty full, and big blocks don't like to get hot.
Old 10-26-2009, 06:20 PM   #7
OldSub
OldSub's Avatar
I've seen it done very nicely. Here are a couple of pictures I took at Billetproof Chehalis in 2008.
I didn't see anything that looked butchered and in fact this swap was cleaner than some small block swaps I've seen.
This was the steering clearance solution.
This truck was running cast iron exhaust manifolds.
I'd go for it!
Old 10-26-2009, 06:32 PM   #8
Michael_e
Grenade Inspector
Michael_e's Avatar
I've thought a lot about this swap also, but was told it would be really tight. What is that steering setup in the pics above? I really want to keep the truck rated at 3/4 ton so that almost rules out the mustang II option. Going the 1/2 ton route would make things a little bit easier, but i really want the 3/4 or even the 1 ton rating 'cause i seem to end up doing a lot of towing.
Mike
Old 10-26-2009, 06:48 PM   #9
ROADSTERJEFF
Thanks for all the input.
Old 10-26-2009, 07:15 PM   #10
N8B
N8B's Avatar
We are sticking a 89 454 w/ T400 and a Gear Vendor in a 52 Chevy pickup. One option we are looking at is a hurst style front mount. Like everyone else has said, short water pump.
Sorry no pictures as of yet.
Old 10-26-2009, 07:41 PM   #11
MO_JUNK
Grenade Inspector
MO_JUNK's Avatar
Yes, lengthwise it will fit but you have to cut the x-brace rods in the core support and move the radiator forward a couple inches. You can trim the valence and make it neat. Also, you'll need to run the short waterpump. I did it with a 75-79 front steer subframe and used a U.S. Radiator called "the desert cooler". I made sure the valence sealed good around the radiator and the truck ran in the 180-190 degree range even with the a/c on and flat-towing a 26 T tub. The picture in the responses above is of a later model (mid to late 70's) chev. truck (or later)steering box mounted to the outside of the frame in front of the axle(near the core support). You then fabricate a steering arm that fastens to the top spindle/backing plate bolts and steer via the left front wheel. You'll need to make a short drag-link as well. This is a good set-up. There was an article on this set-up in Street-Rodder I believe. It would have appeared in the late 70's or so. Kits for this swap were available if you are not a fabricator. This is a good set-up if you are staying with the original axle and you can use the manual or power box. A later model column can be swapped easily and is hooked up via standard PTO or borgeson joints and double-D shaft. If you Google "Sam KImbrough" you will see the Custom and Classic Trucks article on my truck from 1995. A big block looks good in these trucks. I ran stock exhaust manifolds and had plenty of room to change plugs, etc. Again, my truck had a sub-frame but I have seen the other set-up and it looked clean. Good luck. Sam
Old 10-26-2009, 08:50 PM   #12
Double Caddy
Double Caddy's Avatar
I know its not the same but I am finishing up putting in a 454 in my Cadillac. I used the short water pump and the altenater bracket I used from transdapt requires headers not exhaust manifold.
Click image for larger version
Name:	surge tank 098.jpg
ID:	795821   Click image for larger version
Name:	pic of tony 10-24-09 139.jpg
Old 10-26-2009, 09:02 PM   #13
OldSub
OldSub's Avatar
Quote:
I'm pretty sure the one in my photo is one of the kits.
The trouble with the kits is that they assume you're dealing with a 1/2-ton frame, and the profile of the 3/4- and 1-ton trucks is just enough different you are going to be fabricating that part even if you buy a kit.
I spent a lot of time considering modifying a kit to put power steering on my 1-ton GMC project. I'm running a 500 Cadillac instead of a 454 but many of my challenges are similar.
There are more pictures of that truck and the power steering setup at http://www.oldsub.com/images/2008/06/28/. Be forwarned most are big and located on a slow server. The first picture of this truck is 100_4357.jpg.
Old 10-26-2009, 09:05 PM   #14
fab32
Alliance Member
fab32's Avatar
Go for it. You'll have all the help you could ever want right here on the HAMB
and it would make one hell of a tech thread. I'm gathering parts for something similar but a '48 F1. Mine is going to have a Dakota front end via an Industrial Chassis (Elpolacko) front crossmember, BBC and 4L80E into a 9" rear.
Frank
__________________
"What we got here is failure to communicate"
Old 10-27-2009, 12:25 AM   #15
68 C10
FNG
Hope this might help. Takes some sifting through but I believe there's info on what he did a few pages into the thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=329375
Old 10-27-2009, 01:12 PM   #16
AnimalAin
Old School HAMBer
AnimalAin's Avatar
This swap was covered in one of Petersen's Engine Swapping specials in the mid-70s or so. Like most, it isn't impossible, but a long way from bolt-in.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
