Critique these rearend hangers
Discussion in 'The Hokey Ass Message Board' started by racemad55, Mar 4, 2008.
  1. racemad55
    racemad55
    Cut these out of a4'x8'x1 1/2 " sheet of steel to hang my Frankland rearend in the deuce frame,wanted to look sorta like the 35&36 ones. All done on a manual Bridgeport.
  2. HemiRambler
    HemiRambler
    WOW - are you saying those are SOLID STEEL hangers!!! Way Cool
  3. racemad55
    racemad55
    Thanks, HEMI, going to try to build a triagulated setup.
  4. Vergil
    Vergil
    Looks great and so is the machining. Nice job
    Vergil
  5. Frickin' way cool. That is top notch work!
  6. Flatman
    Flatman
    Mmmmm....... Beefy!:D Great looking piece!
    Flatman
  7. Wow! Those are really steel? At first I thought they were aluminum with just the little tabs made of steel. Holy smokes! Now I know why you put those huge lightening holes in them. Your shop floor must have about 50 pounds of steel curly cues heaped up on it!
  8. racemad55
    racemad55
    Actually the shop floor where I work, About 3 weeks worth of lunch hours!
  9. 30 Buford
    30 Buford
    Real Nice ! They make want throw mine away ar at least get creative with them.
  10. Slag Kustom
    Slag Kustom
    looks great. ton of nice work in them.
    think i would add 2 more holes to the spring hanger area.
    funny how after all the work goes into them that we all can find ways to make it better. the hardest parts look so simple when done.
  11. john56h
    john56h
    Very nice!
    I thought they were aluminum too. Man, that Bridgeport must have worked pretty hard to carve those babies out!
  12. What size bolts attach the axle tabs to the beefy brackets? Those bolts seem like maybe the most stressed out component of all of that, since they're located in pretty close to the axle centerline. If you have tons of power and lots of traction, the axle housing will try to rotate inside those big brackets, and the shear strength of those two bolts is all that will keep it from twisting. They're both in double shear though, so it's probably plenty strong.
    That sure is some nice machining!
  13. jetmek
    jetmek
    damn all im getting are red x's at work confuser
  14. grego31
    grego31
    from Sac, CA
    very nice, you plan to make those on a custom biases?
  15. Wildfire
    Wildfire
    Very nice work. I am really impressed - you obviously know your stuff.
    You could probably mill the center - make it like a drilled I-beam for more weight reduction and still have the strength you need. If that is 1.5", mill 0.5" into each side - leaving a web 0.5" thick. Then again, what's another pound or two...
    Again, awesome work.
  16. FiddyFour
    FiddyFour
    holy shit!
    insane amounts of cool! nice work
  17. TexasHardcore
    TexasHardcore
    from Austin-ish
    Awesome job, looks great, uber strong, simple, effective. Wanna sell em? ;)
  18. racemad55
    racemad55
    Rustybolts, bolts are 1/2", torque will be applied to the upper triagulated bars attached near the center of quickchange.
  19. PollockzRodz
    PollockzRodz
    WoW I like the rusty original brackets way better... HAHAHA Just kiddin those are amazing very nice work. There so simple but yet they look so complicated. I would hope that what ever there going on has an exposed rearend or no rear floor haha just to show these pieces of art off.
  20. Ranunculous
    Ranunculous
    Racemad,
    Take it as a compliment-they look "store bought!"
    Your work is killer! Very nice!
  21. ago
    ago
    from pgh. pa.
    That is really very good work. nice imagination.
    AGO, fellow machinist
    real Hot Rods have 3 pedals
  22. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Just two words......BAD A$$
  23. Bucksnort
    Bucksnort
    Those are sweet pieces.I bet they look even better in person.Excellent work.By the way,what are those cool looking doors under the hangers?
  24. Cool work for sure.
    Question for you:
    If you are running a these on a trianglated suspension on a QC, how are you going to align the spring perches so there are square to each other? Or are the bars going to be run straight in and the top bars triangulated? Or are the ends going to be straight with Heims attached so the bars can run triangulated?
    See what you did now, I am confused.
  25. fonti
    fonti
    looks great, rick!! hope, everything is in the same quality when I'm up there...:)
    peter
  26. racemad55
    racemad55
    JRblack,they are straight for now,might have to angle them a little,planning to attach under the frame.
  27. redlinetoys
    redlinetoys
    from Midwest
    Very, very nice parts indeed. I LOVE details like this. Of course now you have to make lots of other parts to match!
  28. ALindustrial
    ALindustrial
    wow.. nice work! how much do they weigh in relation to the originals?
