Technical SBC Finned Timing Cover Question
Discussion in 'Traditional Hot Rods' started by Ed Wrath, Feb 23, 2021.
  1. Ed Wrath
    Ed Wrath
    Could someone tell me if a finned aluminum Weiand timing cover will fit on a stock SBC engine with a stock water pump? Thanks in advance
  2. TCATTC
    TCATTC
    Maybe with the long pump but most likely not with the short one.
  3. squirrel
    does it look like this? with the hole for the injector pump?
    TFoch, hendrcs and Deuces like this.
  4. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Call Holley, they own Weiand they should be able to tell you.
    KK
    Deuces likes this.
  5. Ed Wrath
    Ed Wrath
    Yes it does...
  6. Ed Wrath
    Ed Wrath
    Thanks, good idea!
  7. squirrel
    Since it has a hole for an injector pump, it's not designed to be used with a water pump, at all. But if you use a long water pump, as suggested earlier, it should clear.
  8. Ed Wrath
    Ed Wrath
    Thanks for the info...
  9. four5four
    four5four
    from omaha
    Resized_20200419_180937001.jpg I have a Enderle cover and a long water pump wouldnt clear. With water pump spacers and a long water pump you could get it to clear but with the injector block off plate on it was another 1/4"or 3/8" taller. Mine was in bad shape, one of the ears broken off so I cut it up to clear a water pump riser but still alot of work. They do look good polished with f.i bed valve cover though. 20200226_201126.jpg
  10. 19Eddy30
    19Eddy30
    from VA
    If NOT using the fuel pump drive , Make sure to use a Cam Button .
    Deuces likes this.
  11. loudbang
  12. squirrel
    if you're using a roller cam, then yes, you need to. But not necessary with a flat tappet cam.
