Projects Modified Build
Discussion in 'The Hokey Ass Message Board' started by Beau, Feb 1, 2012.
  1. Beau
    Beau
    Both sides are in.
  2. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    Have you fired it to see how it sounds yet?
  3. Beau
    Beau
    Made some kick panels.
      82.8 KB
      56.7 KB
      61.1 KB
  4. 4444Design
    4444Design
    like your fab work
    lookin' forward to any updates
  5. Beau
    Beau
    I have not fired it yet. Two exhaust studs broke on the left head, and I'm sure a couple will break on the right. I need to put the oil pump in, a couple gaskets, radiator hoses and little stuff before I fire it. I can't wait though!
  6. patmanta
    patmanta
    from Woburn, MA
    Oof, can you get the broken studs out?
    I also had a question about your pipes. It looks like the hanging brackets are hard mounted; are you gonna put bushings or soft washers in there?
  7. Beau
    Beau
    With the aluminum heads it should be a really fun time getting them out. I welded about 6 nuts on to each of them and they just kept breaking off a bit at a time.
    The rear section of the exhaust will be hard mounted at the crossmember and the frame. I put the stupid braided flex pipes in to take care of the flex from the engine moving.
  8. krusher74
    krusher74
    from uk
    Just found Your thread today, enjoying watching the evolution of the project.:)
    On the snapped studs, if it's broke below flush, just build up a good bead of weld, then weld a nut to that bead.....wait till completely cool. (and possibly heat the head around the stud trying not to get heat in the stud.
    or is his what you have been doing :confused:
  9. Beau
    Beau
    I was welding nut on and doing this I'm a bit hesitant to heat the right right now because they are aluminum. The stud are a 14" below flush. I'm not super worried yet, just a bit of a roadblock on the trip to starting it.
  10. OFT
    OFT
    I like your use of metal for the kick panel's. Look's really good!!!
    Earl
  11. Beau
    Beau
    I wasted some time making a panel for under the dash. It'll never be seen unless someone crawls into the tub head first. :D My lady ran the crank while I guided it through. I need to shape and trim it, then weld it in.
  12. krusher74
    krusher74
    from uk
    Looking good, looks like you have a good grip on the bead roller now.
    One thing I would have done early on would have been a mock up windshield height/pillars would help when deciding or proportions. (I like it just the way i is now)
    Surprised your lady has not penned a drawing of the car yet.
  13. Beau
    Beau
    I need to polish the dies up and learn a bit more on how to use it. I feel like some sort or adjustable table would help a lot. I have a local guy that's gonna show me what he used to convert it into a foot operated electric powered roller.
    I'll get back to the windshield later. I have some ideas for it though. We are gonna do a snap on cover as well.
  14. Beau
    Beau
    Shaped to match the dash and a angle piece welded on for strength.
    Tacked in.
      97.5 KB
      89.5 KB
      191.2 KB
      111.5 KB
  15. Beau
    Beau
    Bump for the morning crew.
  16. patmanta
    patmanta
    from Woburn, MA
    That'll certainly keep you from kicking your wiring harness loose! Looks great!
  17. Beau
    Beau
    Gotta modify the floor a bit more. I like the exhaust so far.
  18. Beau
    Beau
    Maybe some of this?
  19. Ryan
    Ryan
    ADMINISTRATOR
    Loving this little car.
    Beau likes this.
  20. Beau
    Beau
    Thanks! Been loving your build as well.
    Thanks, Ryan. :D
  21. patmanta
    patmanta
    from Woburn, MA
    DO IT!
    I love the look of covered frame horns. I'm covering mine with a 48 F1 piece... eventually.
  22. Beau
    Beau
    Today I met another cool old street rod builder and bought some tools he no longer needed. He made the slip roll and it works pretty damn good. I also got a cheap shrinker/stretcher with a stand he built. I'm real excited to have these around and the price was excellent!
    Fellow HAMB member Alienbaby17 finally pulled his F100 out and is starting his Model A pickup. It's nice to see another Model A in the shop. He is the one that planted the seed and got me thinking about building my car. This is gonna be fun!
    http://www.jalopyjournal.com/forum/showthread.php?t=672741
      38.2 KB
  23. patmanta
    patmanta
    from Woburn, MA
    Lookin good!
    Great score on the tools! You'll be glad to have'em! I'm about to start putting what I've got to use.
  24. This build keeps getting better every time I look at it...
  25. Beau
    Beau
    Pull max fun!
  26. It's all in the little details that count.... Looks great from my end! Keep pluggin' away!
  27. Beau
    Beau
    The start of my hood sides.
    patmanta likes this.
  28. patmanta
    patmanta
    from Woburn, MA
    Oh NICE! I'm envious of your Pullmax access! I'm considering a set of those louver dies for my bead roller. I'm fairly certain the Pullmax is a superior tool however.
