Technical ***May 2019 Banger Meet - May all 4 stay in the block***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 30, 2019.
  1. Crazydaddyo
    Crazydaddyo
    With the engine assembled and no sparkplugs , the engine should not exceed 35-40 ftlbs torque applied to the crank bolt to spin it over. This is with rods, pistons, rings, the rope seal, and the crank pulley instaled.
    Sent from my SM-J320P using The H.A.M.B. mobile app
  2. 97
    97
    Just use the hand crank ! :cool::DIf you have trouble with that , assist the hand crank with the starter motor!
    JT1930 and Jet96 like this.
  3. JT1930
    JT1930
  4. V4F
    V4F
    from middle ca.
    I cant understand why it wont crank with 6-1 head . mine is 7-1 with 126# per cylinder & turns & starts ez . I hope you find the problem …………… steve
  5. With "The 500" over with at Indy! The crowd, cars, equipment and mechanics mostly gone! I can go home!
    2014-06-05 17.47.54 (1).jpg RMMR2015-2.jpg It ain't the" the Real Cup"! But it'll hold Whisky!
    Crazydaddyo, Jet96, winduptoy and 3 others like this.
  6. railcarmover
    railcarmover
    Did number 4 rod set up nice?I tap rods with a dead blow hammer side to side after setting the clearance,make sure it doesn't have any high spots.
    JT1930 likes this.
  7. JT1930
    JT1930
    Yea went in nice. Good clearance on crank. Spun fine.
  8. callcoy
    callcoy
    from Nashville
    Transport to S.F. Bay Area
    I will be pulling an available 16' 7000# open trailer from the Nashville area to Bonneville (Salt Lake City) and down into the San Francisco bay area, leaving early Aug. Could bring out someone's car or ?, if interested please contact me, Steve at seven o seven 4 eight o four 6 zero 6 west coast time till June 1st, after that date same number but Nashville time. Trailer on return will have a rolling chassis, 2 or 3 bangers and misc. items, I will have room for other parts, if we can squeeze them into and around my stuff. If interested and want to discuss contact me at the above number, I will not respond to emails until we talk. My return trip maybe right from El Mirage in mid Sept. if the car is still together from Bonneville, if not may leave closer to the first of the month.
  9. railcarmover
    railcarmover
    Starter..starter cables..are you running a ground strap to the transmission /engine? Ford used the engine splash pans as a ground path.Without them you should run a heavy gauge ground directly to the engine/trans,the clamshell, ujoint and motor mounts are a bad path to ground..
    Dannerr and JT1930 like this.
  10. JT1930
    JT1930
    Car starts fine right now on stock starter and stock head. Got good grounds and power threw out. Big wire. New battery.
    Jet96, Dannerr and waxhead like this.
  11. Jiminy
    Jiminy
  12. Jet96
    Jet96
    from WY
    Railcarmover-I didn't think about the splash pans being another ground, makes sense!
