help 1930 A juice brakes flathead v-8 I have a 30 A Tudor new to the hot rod scene wanting to put juice breaks on. The tudor is stock what are my options? change spindles what year? or change front axle ..Flathead v-8 what year should I be looking for? I have a line on a 50s ford truck could I use the running gear out of that? any help would be appreciated Geald
per the Hamb sunday school , that is brakes...not breaks `39-`48 ford brakes can be adapted to your present spindles with adapter rings , i believe speedway sells them Rod & Custom did a tech article on this in the May 2005 issue also , check this out: http://www.mtcarproducts.com/
Everything you need to know is right here...... http://www.jalopyjournal.com/forum/showthread.php?t=124112
