Go Back   THE H.A.M.B. > Archives > Tech Archive
Reply
Thread Tools Display Modes
Old 08-03-2006, 05:35 PM   #1
Enbloc
Senior Member
Enbloc's Avatar
Default BRAKES, Ultimate Guide To Fitting '39-'48 Hydraulic Brakes To Your 'A'....
This subject seems to come up alot on the HAMB, "How do I fit hydraulics to my Model 'A' ". Hopefully this should show how to fit said brakes the CORRECT way.
My Model 'A' came already fitted with hydraulic brakes, but the more I studied them the more things I noticed were wrong with the way they were fitted. The true horrors weren't discovered until they were actually removed from the car.
I decided the best way forward was to start again with a fresh set of backing plates.
Here is your basic '39-'48 Ford backing plate. In this case they are the later '46-'48 plate as they have the riveted rather than bolted bottom pivots. You will also need the correct hubs and drums as the original 'A' ones will not work with the hydraulic backing plates.
We'll start with the fitting of the front brakes first.
This is the stripped hub. You'll need a front fitting kit which consists of 2 bearing spacers and two backing plate spacer rings. You can see how these are mounted to the hub.
Take care with the backing plate spacers as they are cast iron piston rings and will break easily if forced.
The Model 'A' has a smaller backing plate stud spacing.
There is two ways you can approach this:
1. Elongate the original hole in the backing plate.
2. Plug the original holes and re-drill them for the Model 'A' stud pattern.
I choice the second as I believe this to be the correct way.
You can see in the above picture the now hole-less backing plate. A plug was cut from 3/8" steel rod and then plug welded both sides and ground smooth making sure not to remove material from the mounting surfaces.
Now is time to re-drill the mounting holes.
You can get complicated here and have it all set up on a rotatory table on a mill or do what I done and just mark it from the back!
The backing plate was masked with tape and placed on the hub.
With the backing plate mounted to the hub, making sure that the wheel cylinder is at the very top on the vertical, mark the position of the holes with a 3/8" drill bit, this will be your final hole size.
Use a drill press as this way you will have a nice straight hole. You should find that the backing plate sits flat making it easy to clamp down.
Use a small 1/8" pilot drill hole, double check everything and then keep enlarging the holes until you finish with a 3/8" hole.
If you find that its gone wrong somewhere, simple plug weld the hole and start again.
The finished article. Notice how close the holes are to the edge? Thats just the way it is I'm afraid.
If everything is correct it should all bolt up.
Complete the assembly of the brakes and its job done.
A little tip when assembling the brakes is to cover the shoes in masking tape. This stops the shoes getting covered in grease, oil and God knows what else.
That completes the front brakes and finally an example of how not to do it. Yes these are what were originally fitted to the car.
offline   Reply With Quote
Old 08-03-2006, 05:36 PM   #2
Enbloc
Senior Member
Enbloc's Avatar
Default Re: Tech: Ultimate Guide To Fitting '39-'48 Hydraulic Brakes To Your 'A'....
Moving onto the rear.
This becomes a little more involved and will need machineing to do it properly.
First off is the very outer edge will need 1/8" machined from it.
Also 1/8" will also need to be removed from the back of the rear drum.
The backing plate will sit on the rear axle casings and the holes will line up. You will notice that the backing plate will not sit flat because it will clash with the spring hanger.
The way to remedy this is a small clearance slot in the backing plate, as below.
For best results it will best have these machined on a mill as I had mine done. I would think a similar result could be achived with a angle grinder.
The following is the drawings to show where these slots will be in the backing plates. Remember that they will be handed.
Right rear.
Left rear.
With the slot the backing plate will now sit flat on the axle casing. Notice in the picture how the spring hanger now sits flush with the backing plate.
The second problem your now going to experience is that the wheel cylinders also have clearance problems with the spring hanger.
The way to overcome this is to rotate the backing plate forward. For reference the recommended number of degrees is 16. I found this not to be enough so I just rotated the backing plate until I had adaqate clearance with the wheel cylinder and more importantly enough space for the brake fitting and pipe.
With the backing plates held in position it was the same process as the front in marking the holes.
I used a 1/2" drill bit as this is the final hole size.
I removed the rear wishbones to make it easy to mark the holes.
[img][/img]
Again the backing plates were drilled on drill press. You can plug the original holes but I chose not to.
Your final hole size 1/2".
With the rear backing plate mounted with a wheel cylinder you can see the amount of rotation. I kept the rotation to a minium to try and keep the wheel cylinder as high as possible.
If you look closely you can see how with the extra rotation of the backing plate how the clearance slot has moved round.
A shot from the back.
Before final assembly of the rear brakes you want to put a large chamfer on the outer edge of each brake shoe. This is because the shoe will rub on the inside of the brake drum.
Again some examples of how NOT to do it.
Apart from the obvious poor workmanship here the new mounting holes were actually drilled the wrong way so the backing plates rotated back not forwards. this had cause all sorts of problems with plumbing the brakes
Some final information.
When you tighten everything up you may find the drum binds. This may be due to wear on the tapers.
If this is the case you will need some axle shims. The car came with 2 but I found I needed just the one, the fewer the better in my opinion.
To finish you want to torque the nuts up to 80-90 foot pounds. this is important as its the taper NOT the key that holds the hub to the halfshaft. I find it best to put a wheel on the car and then torque the nut as this stops the drum from spinning.
Old 08-03-2006, 05:46 PM   #3
Baron Von Mike
Baron Von Mike's Avatar
Very nice. I'll be helping a friend do this soon. Great timing.
Mike
Old 08-03-2006, 08:20 PM   #4
Drewfus
Senior Member
Drewfus's Avatar
Thumbs up Re: Tech: Ultimate Guide To Fitting '39-'48 Hydraulic Brakes To Your 'A'....
BTTT, great tech.
Cheers,
Drewfus
__________________
"Sometimes you just need to jump with both feet...."
Old 08-03-2006, 08:39 PM   #5
snortonnorton
snortonnorton's Avatar
excellent
__________________
"There is just one thing I can promise you about the outer-space program - your tax-dollar will go further." ...........................
Wernher von Braun - Sturmbannfuhrer
Old 08-04-2006, 05:55 AM   #6
Enbloc
Senior Member
Enbloc's Avatar
Bttt
Old 08-04-2006, 06:07 AM   #7
Billy the kid
Billy the kid's Avatar
Very cool...That answers a lot of my questions.
Old 08-04-2006, 06:16 AM   #8
continentaljohn
Old School HAMBer
continentaljohn's Avatar
Excellent and thank you, printing this out for a freind..
Quote:
__________________
Wanted 1932 Ford Roadster Please or parts
Old 08-04-2006, 06:53 AM   #9
general gow
Alliance Member
general gow's Avatar
nice work. great info. thank you.
Old 08-04-2006, 07:59 AM   #10
Michael_e
Grenade Inspector
Michael_e's Avatar
This could not have come at a better time. I got a 29 coupe, in real great shape, back in April and got a complete set of 40 ford brakes including the spindles in June. I have been taking the brakes all apart, cleaning all the internal parts and blasting the brums & backing plates. All the parts were in really good shape. It looks like they had done a brake job on the 40, less than 5k miles prior, so even the shoes are in good shape. If i can ever make friends with my newfangled digital camera, will post some pics.
Thanks,
Mike
Old 08-04-2006, 08:14 AM   #11
Roothawg
Old School HAMBer
Roothawg's Avatar
Don't take this the wrong way. It's a great post.
I am concerned about the lack of edge distance between the center of the hub and the mounting holes(which you already mentioned).
I know it is a limiting factor because of the diameter of the spindle, but the way you have your holes drilled is really not much stronger than the ones you showed as the bad example. I wonder if you could add a doubler on the inside to help displace some of the load? Like a circular ring?
__________________
WWW.hungerrun.net
CrossMembers CC EST 2009
Click here for the HAMB Chapel
Old 08-04-2006, 09:06 AM   #12
Enbloc
Senior Member
Enbloc's Avatar
Its a fair comment.
The backing I used actually has the reinforceing spacer ring you mention. They came from the factory like this and I believe they are from an F3 truck.
The difference between mine and the bad ones shown is that mine are securly located. The slots in the bad example are so inaccurate and sloppy that the backing plate had the oppunity to move on its mounting when fitted to the car.
Done properly with a single hole it doesn't matter where you apply a force on the backing plate it can not move.
I don't think there is a stength issue here.
Old 08-04-2006, 09:37 AM   #13
Michael_e
Grenade Inspector
Michael_e's Avatar
Back again, this time, with a question or two. I printed this off and can't wait to get off work & get home.
What did you use for the master cyl portion of the system? Is it a single or dual type of master cyl? Where & how did you mount the MC? Is it directly operated off the brake pedal, asuming you kept the stock pedals? Or it it mounted via the original crossover bar, or whatever it's called, for the original mechanical brakes?
Thanks,
Mike
Old 08-04-2006, 10:21 AM   #14
Mart
Senior Member
Mart's Avatar
Good work.
Three comments/questions. (meant as constructive criticism, not nit-picking.)
1, The 80-90 lbs feet figure is surely too low.
I've read figures of 200-220 quoted, plus regular retightening and further tightening to the next castellation. (dont exceed 275 ft lbs) I think if anyone follows the 80-90 lbs ft figure they'll have trouble.
2, if you knew about the rotation before cutting the clearance slot in the rears, would you have made the cut out slightly different.?
3, Do you think they'll bleed ok with that much rotation? I'm not saying they wont, I just wondered if this is an established method, and people have tried it before and it's ok.
Nice documentation and presentation, glad to see you're doing the car right.
Mart.
__________________
Visit my website: www.martsrods.com
online   Reply With Quote
Old 08-04-2006, 10:26 AM   #15
Mart
Senior Member
Mart's Avatar
Just thought of something else.
Is it not an established technique to use the rear backplates upside down? This just rings a bell from somewhere, I've not tried it myself. That would keep the cylinder and the backplate ridge clear of the spring mount. Anyone else seen it done this way?
You'd have to fit the cylinders the right way up of course so they would bleed ok.
Keep up the good work.
Mart.
__________________
Old 08-04-2006, 10:34 AM   #16
Flathead Youngin'
Old School HAMBer
Flathead Youngin''s Avatar
very good.....nice work.....quality.....
seems like you posted pics of those poorly done backing plates before....
__________________
Yeah, it's mustang 2'd, 350, 350, 9 inch, pro-streeted, mini-tubbed.......pretty cool, huh?
Old 08-04-2006, 11:52 AM   #17
tub in da dirt
Alliance Member
tub in da dirt's Avatar
i have a fixture to offset drill the holes for the rear
i will loan it out to any hambers
as long as i get it back
3 sets of holes
original bolt pattern with dowel pins for location
offset 15deg forward
offset 15deg backwards
let me know (p.m. me)
but i will sick the hamb mafia on you if its not returned
tom
__________________
i need pics of 4 banger rails, FED, altered you name it thanks tjk.fab@gmail.com
Old 08-04-2006, 12:04 PM   #18
Enbloc
Senior Member
Enbloc's Avatar
Quote:
Originally Posted by Mart
Good work.
Mart.
No problem, if there something wrong I would rather know than cause problems to myself or someone else.
I've checked three different publications and now have three different torque settings!
The first is the 80-90 ft lbs the second is a larger 125 ft lbs and the third says tighten well!
I'll look into it further.
Of course if I'd known about the position of the slot I would have done it differently.
They have already been bled and are fine. Even though the backing plates have been rotated the wheel cylinders are still the highest point.
Mart.
Yes, you can mount the backing plates up-side down.
I personnely don't like this way as it puts the wheel cylinder very low, which may cause problems with bleeding the system. Also the brake line will run very low leaving it vunerable to being damaged.
Old 08-04-2006, 02:34 PM   #19
Mart
Senior Member
Mart's Avatar
Fair enuff, Clark.
I got the torque info from the flatheaders techno site, here's a link:
http://groups.msn.com/FordFlathead19...ositelink.msnw
Cheers.
Mart.
__________________
Old 08-04-2006, 03:17 PM   #20
Artiki
Senior Member
Artiki's Avatar
I've got a feeling my A manual mentions 100lb for the rear hub nut. Haven't got it to hand right now, but I'm pretty sure it is and mine has been set up with that figure.
Regarding the backplates, I remember that Simon Watts positioned his rear with the cylinders at the bottom on his RPU. Not sure whether he had any problems with bleeding them.
Another question, Clark. Are your rear radius arms mounted the correct way round or have they been swapped over?
__________________
www.flatheadmeltdown.com - Home of the world's quickest street flatheads and four-bangers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
