Never did a Ford L6 but the Mopars I've done, I've used the head bolts. Seemed about the easiest way to balance hings out.
I used the bolt holes for the cylinder head with the head off. One at each opposite end worked well for me.
An old trick is to take a couple of discarded spark plugs and weld rings on them. Thread into the front and back plug holes connect with a chain and lift on that.
i made this to bolt to the head bolts almost 30 years ago. more ideas here. https://www.jalopyjournal.com/forum/threads/how-did-you-lift-sling-your-engine.1090338/
