Technical 32 Highboy horn
Discussion in 'Traditional Hot Rods' started by qmdv, Nov 24, 2018.
  1. I am getting close to getting a 32 Highboy roadster on the road. I need some ideas on horn options. I will not be using a headlight bar. I will be using F-1 front shock mounts with headlight cups and 4 inches of bar welded to the F-1 shock mounts. Not sure a stock horn (that I do not have) will work in this configuration
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I've used several So-Cal horns on my deuces. Mounted under the car out of site. Horn looks the one that was on my HD springer?
    36-3window likes this.
  3. I have ‘59 Impala High/Low horns mounted to the frame on my ‘34 truck.
  4. F&J
    F&J
    I don't have a horn on anything here. if you need one for inspection at DMV, hide it under the car? Who needs a horn? If you are needing to get someone's attention, just light the tires
    clem and Hurley50 like this.
  5. sloppy jalopies
    sloppy jalopies
    I like a loud horn hidden inside the frame with an easy to hit button, but I also like a beep-beep horn, like older VWs with a hidden button for the just wanna say hi toot... $0.02.
  6. rusty rocket
    rusty rocket
    I have a beep beep vw horn right under the grill shell on my 32.
    Bam.inc likes this.
  7. I used a aftermarket HD horn on my roadster, it was similar to this. HRP
    Bam.inc and chryslerfan55 like this.
  8. DDDenny
    I started my roadster project nearly 20 years ago and planned on using one of these only to passify the DMV inspector.
    I guess with all the idiots on cel phones jamming up the roads nowadays I'll need something a little more persuasive like this guy uses.
    da34guy and chryslerfan55 like this.
  9. The horn on a stock '32 is mounted on the fender shelf with a bracket next to the radiator, is that location/mount an option? FYI here are two horns on my AVATAR. The stock one and one under the car that is loud and sounds like a modern horn.
    Charlie Stephens
  10. TrailerTrashToo
    TrailerTrashToo
    "Can you hear me now?"
    I use a manual air valve, a gentle tug yields a friendly toot. All the way out for "THE LIGHT IS GREEN, PUT DOWN THE CELL PHONE AND START DRIVING!"
  11. sloppy jalopies
    sloppy jalopies
    if you want loud, try a 6v '47 ford trumpet horn on 12v...
    co worker lived 1.5 miles away... he thought is was a train's horn !
  12. I made a bracket that bolts to original fender bracket holes for this flea market horn find.
  13. Here is a picture of the bracket to mount the horn on the fender shelf that I referenced in Post #9. Note they are available at: https://www.earlyfordstore.com
    Charlie Stephens
  14. town sedan
    town sedan
    Now that will get their attention! I like the idea.
    -Dave
    cactus1 likes this.
  15. I googled 'loud motorcycle horn' to get what I wanted. Mounted out of sight but loud enough. I have '40 repro wheel and column front Limeworks, so I use their button kit.
    Phil
  16. Bruce Lancaster
    Bruce Lancaster
    Horns are obsolete. Rig up something that texts "Wake up, you moron!!" to everyone within fifty feet. Better make it all caps, come to think of it.
    Moriarity likes this.
  17. deucetruck
    deucetruck
    from Missouri
    I used an early VW Bug horn. Made a small bracket and mounted it at the bottom of the engine block on the driver side.
  18. Be like the old guys in NASCAR and use the chrome horn! :D HRP
  19. DDDenny
    The "bump and run" model.
  20. Bandit Billy
    Bandit Billy
  21. solidaxle
    solidaxle
    from Upstate,NY
    "32's" deserve a "32" horn. I can close the hood with out moving the horn. 32 horn.jpg
  22. Fogger
    Fogger
    When I built my '32 Roadster in '06 I decided to us a 6V Ford trumpet horn. Simple mount to the radiator support rods with Adel clamps. Ran it through a horn relay and it's plenty loud with the 12V source. SAM_0456.jpg
