Projects 1932 Henry Ford hot rod
Discussion in 'Traditional Hot Rods' started by AULIZ, Feb 2, 2020.
  1. AULIZ
    AULIZ
    Thank You Sirs.
    Tomorrow engine is ready. Today (friday) is nearly over here in Finland. Just drink evening coffee and enjoy on sofa.
    Still need to make some kind of velocity stacks. Maybe I use those old Jr.Fueler stacks....
    Aulis
  2. AULIZ
    AULIZ
    Sorry my english is not so good. What do You mean?
    Aulis
  3. Stogy
    Stogy
    @AULIZ, Dirt Car is wondering if you did a Thread or posts on making and installing the lower quarter panel on the bare metal 32 5window in pic below...
    The yellow arrow is pointing to it...
    Credit to Photographer, Owner
    chryslerfan55 and alfin32 like this.
  4. AULIZ
    AULIZ
    Thanks, Now I understand. I think, I have post some rear quarterpanel pics here...?
    I must check that.
    aulis
    Stogy likes this.
  5. AULIZ
    AULIZ
    chryslerfan55, brEad and Stogy like this.
  6. dirt car
    dirt car
    from nebraska
    Thanks Stogy, appreciate the clarification, & thanks to our Finland friend it's great to see that our car hobby is without borders...the words "hot rod" share a deserving right to the universal language !
    chryslerfan55, mad mikey and Stogy like this.
  7. Stogy
    Stogy
    He is quite accomplished at his craft indeed...and he sure puts out premium product...not to mention pretty darn good seniority as a Hamber...
  8. AULIZ
    AULIZ
    Thanks.
    Today I get engine ready. Still make some carb, linkage adjustment etc.
    Last pics of this engineproject are incresed later today.
    Aulis
    Off topic: if somebody has good 59 -cylinderblock, Im ready to buy it. I have shipping addresses
    - Paramount CA
    - Houston TX
    Also interested real flathead speed parts. I want to built one more engine 4.25stroke and big bore.
    If You have old supercharger, heads,... send me PM or Email : [email protected]
    Supercharger can be100% project, I can fix it.... Also interested 1pc Double Detent syncro tranny.
    A
  9. dirt car
    dirt car
    from nebraska
  10. dirt car
    dirt car
    from nebraska
    I'll try this reply again, seems my post didn't make it, at any rate ,thanks Aulis for the direction on the 32 quarter panels, great work on those projects & nice to see the youngster following in your foot steps !.. And by the way where might I ask are the large posters from ?? are they printed on cloth or canvas ?? Thanks,Ron
  11. AULIZ
    AULIZ
    Thanks.
    Those are printed on cloth. Pics are from old hot rod books. Those two are approx size 2meter (height) x 1.5meter.
    Big one (black and white) is 2.2meter (h) x 6meter (w). Maybe use that again some day.....
    Here ready engine pics.
    Yesterday I was tight head stud nuts right torque. I didn´t like that feeling how I get right torque, so today I opened all nuts and changed washers. HH Flatheads send me Bob Drake 351020-S washers (1932-53 cylinder head washers). Those are 100% junk, shit.... too smooth material. Those are steel (magnetic), maybe Fe37shitsteel ..... or ohter chinese shit.
    I had own bearing shims 12mm x 18mm x 1mm. Not optimal size and thickness, but when thight those, feeling was good. All nuts easy get right 45lbs torque.
    Today I adjust carbs ready and also fixed stromberg progressive linkage. He only need to install electric stromberg distributor, 12v alternator and wirings when engine is installed to the engine room.
    aulis
    Jrs50, Runnin shine, 63fdsnr and 11 others like this.
  12. Boden
    Boden
    Where did you get those lifters from?
  13. AULIZ
    AULIZ
    Lifters are from HH Flatheads. Mike has send me same lifters many engines.
    aulis
    Stogy likes this.
  14. AULIZ
    AULIZ
    leeroy-84.jpg Garage is cleaned after 3week engine project.
    Coupe is waiting for next step (later this year).
    Roadster need to built ready before May.
    Aulis
  15. Japper
    Japper
  16. AULIZ
    AULIZ
    Yesterday I pieced rear axle. Only problem was drv side hub/drum. Today i heat it very much + puller.... finally I get it out. Parts are washed and ready. Tomorrow I install there new 3.25:1 ring and pinion. Earlier I have shorted driveshaft + driveshaft tube. Rear axle is from 1934 ford.
    Aulis
    jukka-239.jpg jukka-242.jpg View attachment 4618811 jukka-243.jpg jukka-244.jpg jukka-245.jpg
    My 5w coupe wheels are next sandblasted.
  17. glad to see you posting once again, and as usual great workmanship!!!
    Stogy, greaser and nunattax like this.
  18. AULIZ
    AULIZ
    Thank You Sir. Learn something new everyday.... Aulis
  19. heavydumper
    heavydumper
    Neat projects!
    Question...
    Why the 3.25 ring and pinion? I'm curious what you hope to gain with such a ratio. Thank you!
    Stogy likes this.
  20. AULIZ
    AULIZ
    Hello
    6.50-16 tire (rear), 3.25:1 ring and pinion is very good. I have used that RP when that kind of "not so high" rear tires. Easy to drive 100km h on highway ..... (60-65mph).
    3.54:1 is ok, when use 7.50-16 tires.
    Here too many are using this kind of combination: Flathead + T56 (T5) tranny , but as we know, those are not hot rods. Not even owner think so.
    Street rods can installed that kind of tranny.
    Old Ford 3speed syncro tranny is very good. Easy on street, nice to shift and very good on highway too, but RP must be lower. If You have this kind of bigger engine (+hp, +torque) , low weight 1932 car.... it´s so easy to drive even have 3.25 RP.......
    Aulis
  21. AULIZ
    AULIZ
    Rear axle is rebuilt and ring & pinion changed. One new bearing only needed.
    Aulis
    jukka-249.jpg jukka-250.jpg jukka-251.jpg jukka-252.jpg jukka-253.jpg jukka-254.jpg jukka-255.jpg jukka-256.jpg jukka-257.jpg
    Runnin shine, bct, 63fdsnr and 4 others like this.
  22. nunattax
    nunattax
    from IRELAND
    nice work auliz
  23. You make it all look easy. Nice work!
  24. AULIZ
    AULIZ
    Thank You Sirs
    I was fight with this rear axle very much. I do not have any pic, when I loose my mind.....:mad:, flying hammers....
    backingplate bolts; 50% need to cut
    Drv side hub; It not loosen. 1st time ever, I need to make special tools, taka axle and drive to my friends car repair company. They helpelped (fast warm).
    pinion nuts; 1st time ever, those not open. I even broken my bigger blue Jaw vice. (china shit). I need o cut out locking washer between nuts. After that I lathe nuts straight because they damage too...
    Good thing is that after +10 rear axle rebuilding have some kind of working order in my head. This axle was not easiest....
    Good things: only one bearing changed, axle tube wheel bearing inner cone surfaces are good. I have sometimes fixed those if those are badly worn. If driven w/o grease, downside where pressure is, is worn. that "neck" need to grind undersize + install needle bearing inner ring (IR -ring) on it. After that grind to right inc dimension....
    Aulis
  25. Mart
    Mart
    Good work Auliz. When people show pictures of the job when finished it is easy to assume that everything went very easily. By explaining what did not go well you prepare people better for what they can expect when doing the job.
  26. AULIZ
    AULIZ
    You are correct. Many times need to do same job many times, nothing fits, tools are broken,.... One good tip is that leave it like it is and continue next day..... then all goes better. Today I just put together driveshaft + small parts belong that (front bearing, speedometer sender gear,... not feel good (maybe sick) so better come in and take easy on sofa and watch from TV American pickers latest part.
    Aulis
  27. AULIZ
    AULIZ
    Bushes, spring.... installed.
    Tomorrow need to open rear spring 2-3times. Need to find right flex...
    Aulis
    jukka-258.jpg jukka-259.jpg jukka-260.jpg jukka-261.jpg jukka-262.jpg jukka-263.jpg
    brEad, 63fdsnr, chryslerfan55 and 6 others like this.
  28. AULIZ
    AULIZ
    brEad, chryslerfan55, alfin32 and 4 others like this.
  29. Stogy
    Stogy
    Great stuff Aulis...
  30. AULIZ
    AULIZ
    Thanks.
    Too hurry with dayjob,.... not spend very much time in garage.
    Today, Saturday, need to continue welding innerfenders etc.
    on Thursday worked little time with brakes, emerg.brake cable, wishbones,....
    Need to find new bolts from own stock, because too many not opened and I cut out. Not too shiny stuff for this project.
    Aulis
    Runnin shine, brEad, 63fdsnr and 3 others like this.
