Projects 1930 Model A Pickup Build (my first build thread)
Discussion in 'The Hokey Ass Message Board' started by Grudge, Jan 4, 2013.
  1. tdylan28
    tdylan28
    Fuel tank came out nice. No surprise there haha.
    Sent from my DROID device using the TJJ mobile app
  2. Grudge
    Grudge
    Thanks. Just one pic, almost done with the floor
    Got a big shipment of parts so I'll be busy over the next few weeks.
    Aaron
    volvobrynk likes this.
  3. zgears
    zgears
    kidcampbell71 and volvobrynk like this.
  4. That floor is amazing.
  5. redstraw
    redstraw
    from tn
    Nice work!!!!!!
  6. Grudge
    Grudge
    Thanks for the compliments, it really is encouraging to hear.
    Did some more work on my tank today, ran around all over town looking for parts, buying fasteners (wrong ones), then going back for more. First few pics are the pickup tube and fuel "bung" I came up with. Made out of junk lying around.
    This is just a 1-1/4" spacer with a 7/16" hole. I tapped 1/4" NPT, drilled a hole in the side and put in a piece of tubing.
    Welded it up, added a 90-degree bend and a hold-down tab.
    Here it is in place
    And the outlet. It's on the bottom of the tank and will go directly to my pre-pump filter (I'm running a Carter P4070)
    Also started installing my sending unit. I don't have a pic but I warped the top a bit even though I was being SUPER careful, cooling with air, etc. not a good way to finish the day but I think it can be muscled into shape when I finish weld it.
    Thanks for watching.
    Aaron
  7. Grudge
    Grudge
    Got a little more done. This is my first attempt at building a fuel tank, it's a pain. Much respect to those of you who do it well or make it look easy.
    I made a little tunnel for my driveline, mostly it's for the yoke. There's unladen clearance but with weight (fuel, bed load, etc.) I think it would have hit. I bent some leftover 16ga over a pipe and iterated the profile until it fit.
    Gotta love plasma cutters :D
    Put the panel in from the bottom and welded from the inside
    Then welded the underside; I don't wan this thing to leak!
    And finally back in position
    So I'm a little tired of fuel tanks, plus I need to figure out my fuel neck before welding it all together, so I thought I'd start on my exhaust. Made a tiny bit of progress on that. I think I'll like this task much more
    Aaron
  8. Grudge
    Grudge
    Welded up my headers today. They came out ok, not too bad for a desk jockey with a mig welder :D
    Dumping the primaries straight into the cone is illegal, so there was lots of tube fitting. Lots of work but was fun.
    Aaron
  9. lorodz
    lorodz
    sweet build
  10. Grudge
    Grudge
    Some of you may have seen my "How horrible are these?" Thread where I asked opinions on some (admittedly hideous) tractor seats. My motivation included knowing space is limited, but I was and still am convinced that a bench seat is best.
    I picked up this seat from the pick-n-pull on Saturday, worked on my F100 and hung around with family. Pesky life things are getting in the way :)
    And good news! It fits great! But I don't!
    I will need something literally on the ground and back wall.
    Sunday I welded up my fuel tank. I think it turned out pretty well, still need to leak test it.
    Here's the driveline clearance.
    The fuel fitting which will go directly into my pre-pump filter.
    I took apart my heater so I can sandblast it. Picked up some VHT paint for my headers, got an ignition switch, starter button and some other small parts. Will try to post some more updates later.
    Aaron
  11. Grudge
    Grudge
    Bump for the morning crowd. If you guys have some examples of extremely low-profile seats I'd appreciate it.
    Aaron
  12. voodoo1
    voodoo1
    Looking good Aaron.
    Mike
  13. pressuredrop
    pressuredrop
    from mesa AZ
    MG bucket seats might work well. I had no luck finding a low profile bench seat for my 34 truck.
  14. Your build is looking great!!! I just got a 30 Model A cab can't wait to start on it. Keep up the awesome work!
  15. TexasSpeed
    TexasSpeed
    from Texas
    You work fast..
    Too fast.
  16. Grudge
    Grudge
    Thanks guys. Small update; I was out of town part of the week so I'm trying to get back at it.
    Pulled it outside for the first time since last fall.
    I think the grille is about 3/4" too high :(
    Painted my headers with VHT black. Looks almost maroon though, maybe because I used their white primer?
    And started modifying my minivan seat frame.
    Going to just do an upholstered seat back and bottom insert. Got to make it low so I can fit :D
    Aaron
  17. draider
    draider
    from Texas
    I agree with Matt, you're making some quick progress. Looking good!
  18. Grudge
    Grudge
    Thanks! Was cool to see it outside and step back a bit. Can't wait to see it chopped and with my bed mounted.
    Aaron
  19. Grudge
    Grudge
    A little photo-chop inspiration, thanks LN7 NUT!
    Aaron
  20. choptvan
    choptvan
    well well well. We were neck and neck with our builds until you finished the floor amd are installing a seat! I will catch up soon... looks good. Keep up the great work!
  21. Grudge
    Grudge
    I managed to get a little done on my seat frame tonight.
    Here's what I started with (from earlier post):
    It's a regular old minivan 2nd row seat frame. The width was ok, but I wanted it to follow the taper of the body and match the seat "riser", including my bump-out for the shifter and trans cover.
    I cut the front part off, pinched the sides and made a new front part that matched the profile.
    Also added flanged holes because, well, they're cool.
    I'm tired of the seat, so tomorrow I might work on the parking brake and/or radiator strut rods. I have a big list to choose from :D
    Aaron
  22. Grudge
    Grudge
    Got some done this morning. Worked on the parking brake handle.
    I started with my original assembly; I took it apart, cleaned it and replaced the detent spring. Next I made a mount that bolts to the frame.
    Bolted up.
    And put the cover back on, made a hole for the boot.
    Off to the hardware store, going to make some strut rods...
    Aaron
  23. Grudge
    Grudge
    More updates.
    Got my strut rods and bracket made.
    Mounted my heater as well
    Still working...
    Aaron
  24. Grudge
    Grudge
    Think I'm using enough bolts? :D
    Made some good progress this weekend. Looking forward to daylight savings, I'm more productive in the spring and summer.
    Aaron
  25. zgears
    zgears
    Nice work. How soon till it's driving?
  26. Grudge
    Grudge
    Targeting May 11th, which I believe is the Portland Transmission show. Trying to get something done basically every day until then. Made a list:
    Fuel pump.
    Josh, will you still be here in April?
    Aaron
  27. Grudge
    Grudge
    New toy. I hope I can make it work. It came with three un-stuck and one stuck 2GC's (for parts). I've also got the original 2GC on my 265.
    It also came with new extended throttle shafts and progressive linkage. The intake is a little rougher than I thought in the coolant-port area, hopefully won't leak. Its too soon to tell if I have remorse.
    This will be my first attempt to convert "non tri-power" carbs. I've read there are thick throttle plates, modified base plates, etc. but I will try to make it work without any of those kits.
    Aaron
  28. Grudge
    Grudge
    Here's my plan for the seat frame.
    I moved the cross bar up above the original wood brace. The seat frame itself will take over this function. I moved it up because any lower and it crushes my spine.
    So the seat back cushion and bottom cushion will literally sit against the back wall and floor, respectively. It's the only way I can fit and operate the pedals. My goal is to finish the frame by the end of the week so I can take I to the upholstery shop. I want to know exactly where I will be positioned before I commit to the chop.
    Sorry if these updates are small and boring, it's good therapy for me :D
    Aaron
  29. 562roadster
    562roadster
    Gorgeous metal work!
  30. Grudge
    Grudge
    Small update. I think I'm finished with my seat frame. I made some brackets for the back that bolt to the body, and follow the profile. The cushion will be formed so that it fits inside the frame and conforms to the shape of the body.
    Ignore the ugly cushion, it's temporary.
    Also got my new steering wheel. I'll hit the junkyard tomorrow for a stub off a GM.
    Working on the battery box for the rest of the day.
    Aaron
