Technical What the hell
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jan 14, 2022.
  1. Ron Brown
    Ron Brown
    Can anyone explain this distributor cap...I would really like to see the rotor? 5A21F477-4065-4A5F-8054-ABB562365CDF.jpeg
  2. Rickybop
    Rickybop
    Looks to me like a hot Wayne 6 cylinder with dual spark plugs, 12 lugs on the cap, and a few spark plug wires not installed.
  3. Rickybop
    Rickybop
    And dual coils.
    stillrunners, loudbang, Stogy and 2 others like this.
  4. SS327
    SS327
    For dual plug 6 cyl head?
    loudbang, Stogy and Deuces like this.
  5. Rickybop
    Rickybop
    I don't know, never saw one with dual plugs. But are there not 6 pairs of lugs on the distributor cap? 12 total?
  6. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
    I want to see the other side of that head
    loudbang, SS327, Stogy and 1 other person like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    that is a piece arrow distributor. It was a common hot rod practice to put those on engines with 2 plugs per cylinder. It is similar to the aftermarket W&H dual coil distributors that were made in the fifties and sixties. there is a spring loaded brush on the rotor that picks up the second coil from the ring inside, see the pic dualcoil.jpg
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    they are probably running one plug per cylinder but using the dist as a dual coil unit. It gives more coil saturation time and thus hotter spark
  9. Rickybop
    Rickybop
    Could it be that there are 6 spark plugs, and each pair of spark plug wires fires each spark plug twice? Actually, maybe an extended single spark.
    loudbang and Stogy like this.
  10. hrm2k
    hrm2k
    That car belongs to HAMBer Cody Walls in Dewlaware,
    jim snow, clem, VANDENPLAS and 7 others like this.
  11. Rickybop
    Rickybop
    Yeah, what Mark said.
    loudbang, Stogy and Moriarity like this.
  12. Cody has a build thread here.
    Mick
    Stogy and wandi harry like this.
  13. Nash distributor??
  14. Rehpotsirhcj
    Rehpotsirhcj
    1) beautiful
    2) Cody knows his shit
    3) I’m still confused as hell.
  15. Ron Brown
    Ron Brown
    I understand the arrangement of the plug wire spacing on the wires around the perimeter of the cap, so, I am assuming the 2 "inboard" wires go to coils? Interested to see a view of the internals without the cap...my flathead has a gennie, crab style distributor that has the strangest rotor i've ever seen, but this one has we scratch'n my head.
    loudbang, chryslerfan55 and Stogy like this.
  16. blowby
    blowby
    from Nicasio Ca
    Must get very hot.
    Stogy likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    look at post 7 above, I posted a picture of a rotor and the inside of a cap
  18. Rehpotsirhcj
    Rehpotsirhcj
    I missed the part about saturation time with a single plug per cylinder, now I get it.
    loudbang, Moriarity and Stogy like this.
  19. Stogy
    Stogy
    hrm2k, Cody Walls, loudbang and 2 others like this.
  20. loudbang, chryslerfan55 and Stogy like this.
  21. Ron Brown
    Ron Brown
    Ah.....I see....didnt notice the ring inside the cap.......pretty cool really
  22. Cody Walls
    Cody Walls
    For those who’s wondering , the distributor is a very early spalding made for the Wayne F Horning company for the Wayne 12 ports back in the early 50s ,
    its a Nash twin-plug distributor cap , with a modified base to fit on a Chevy distributor , every other lobe is grounded off the shaft . it provide 2 distinct 3 cylinder coil circuits . . . doubling dwell time and maximizing coil saturation at high RPM.
    , it’s a very Frankenstein setup but works very well and it was a hotter spark than a mag in the early 50s ,
    ClayMart, Stogy, Tman and 14 others like this.
  23. Cody Walls
    Cody Walls
  24. Cody Walls
    Cody Walls
    also the crazy part of this whole setup is if you switch the coil wires around , it puts the motor 180 out .
    Stogy, kadillackid, Charlie K and 9 others like this.
  25. At the age of 14 ( 1967 ) in Australia my very first vintage car was a free 6 cylinder 1928 NASH . Real big car and i had no idea what i was doing except dismantling . ( learning curve ) The 12 sparkplugs and that big distributor cap where interesting. I remember lifting the cap and there was a extra new cap stuck under it . The automatic chassis lubricating system was interesting as well. Sold the whole car in pieces for $ 50. Anyhow when i moved to The Netherlands in 1978 i took the new cap with me. Sold it years later for good money.
    Stogy, hrm2k and lothiandon1940 like this.
  26. Thanks Cody, for stepping in and giving us further clarification on a very cool and innovative approach to ignition. Outstanding.
    Dino 64, 41 GMC K-18, Stogy and 8 others like this.
  27. jim snow
    jim snow
    X2. Snowman ⛄️
    Dino 64, Stogy, hrm2k and 2 others like this.
  28. now that is a hot rod!
    loudbang, Stogy and lothiandon1940 like this.
  29. Ron Brown
    Ron Brown
    well...it's cooler n shit...fer sure
    lothiandon1940, loudbang and Stogy like this.
  30. Mr48chev
    Add me to that list of folks who say thanks. That's quite a setup. Not far off some of the dual point V8 distributors with 4 lobes on the distributor cam though.
    lothiandon1940, Stogy and loudbang like this.
