Technical Cruising at 65-70mph help
Discussion in 'The Hokey Ass Message Board' started by carothersbs, Oct 11, 2020.
  1. carothersbs
    carothersbs
    Looking at buying a 37 ford cabriolet with 221 with 37 trans. And rear end. I don’t want swap anything but gears. Is it possible to change gearing to drive 65-70 mph at a lower rpm without doing a overdrive?
    Also open to a simple overdrive setup.
    Any photos would be appreciated. Thank you.
    Spent a few days hopping around of the forums but just not getting a clear answer.
    Thank you.
    Brian C.
    Reno NV
  2. lowrd
    lowrd
  3. oldolds
    oldolds
    I had a girlfriend that could curse much faster than that!
    Now seriously, We need more info. What make and model of car, tire size, Things done to engine, ect.
    Thanks for editing your info.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    My 37 ford has original 3 speed with the original rear axle. It was a Nebraska car so I imagine it has highway rear end gearing.
    I imagine it has a 354 ratio. The engine is a 8ba.
    It’s my long distance car and will easily do 65-70 mph all day.
    Don’t forget.
    Lower rpm on the highway will cause a lot of stress on a highly elevated countryside.
    I’ve heard of overheating on cars running overdrives during this instance.
    mgtstumpy and carothersbs like this.
  5. gimpyshotrods
    gimpyshotrods
    That would be functionally easy, and fairly easy to install.
    Finding and funding one, on the other hand, maybe not so easy.
  6. gimpyshotrods
    gimpyshotrods
    As has been mentioned, there would be a trade involved here, and probably not one you are going to like, unless you never leave flat ground.
    Changing to numerically lower (what would be called taller) gears will make it easier to maintain freeway speed, on a flat freeway, that is. If you turn West and head for Donner Pass, it's gonna suck, same as if you turn East and head for Wadsworth. Even the slightest grade will set you back one gear. If you've even been stuck behind an overloaded vehicle headed to Burning Man, that's going to be you.
    The only way around this to do what has been done with modern cars: more gears.
    This can be done via adding an external overdrive, and there were a few designs. That would give you two ranges, for 6-forward gears, and two reverse gears. These are often a bolt-on, but are now fairly uncommon, sought after by many, and often costly.
    The other way would be to retrofit an overdrive transmission from a modern vehicle, and open driveshaft, and a torque arm. This might be cheaper, but would be more work.
    31hotrodguy and 57JoeFoMoPar like this.
  7. v8flat44
    v8flat44
    Even though you don't want overdrive, you should contact Mitchell Mfg. They have a unit just for your car. You may also want to post this on the Ford Barn and try The Early Ford V8 Club...LOTS of info there too.
  8. manyolcars
    manyolcars
    Even better, use an 84-87 F150 3 speed with overdrive. Mine is wonderful.
    firstinsteele likes this.
  9. carothersbs
    carothersbs
    Most definitely I emailed them today just to get more info on there units. Found out about them on ford barn. Mainly for model A stuff. Now I do like how they mount in the driveline.
    My main question with them, is will I see a obvious highway drivability improvement? And will there setup help me achieve my goal.
    Thank you.
    Brian C.
    Reno NV
  10. carothersbs
    carothersbs
    You think if you were running your stock engine you would still be able to cruise 65-70?
    Want to set the car up to really put some miles on it. 65mph is fine for me. I just want to be able to handle some long distance trips
  11. flatford39
    flatford39
    Ever think about putting a quick change rear in it.
    irishsteve likes this.
  12. Like others said only a few options.
    1. Change rear gears to a 3.54 (aftermarket only unless your lucky to find oem for $$$)
    2. Overdrive Columbia rear BIG $$$$
    3. Newer o/d trans either convert to open driveline or use a T5 4x4 trans and stay enclosed.
    4. O/D unit in the torque tube/driveline.
    My '47 car has 3.78 I believe and it runs 65 easy but it's sucking down fuel at 2800-2900 rpms.
    31hotrodguy and carothersbs like this.
  13. Atwater Mike
    Atwater Mike
    My '63-1/2 Galaxie fastback had a nice running 260 in it, w/Cruisomatic automatic transmission.
    Ha! 4200 lb. car with 3.70 rear.
    An engine change was imminent. (would still have been even if it had a 390. 406 was prepared, with a 5 speed)
    Plans changed, however, and the 406 is now going into my '54 Ford coupe.
    Still...221? Mmmm, nope.
  14. carothersbs
    carothersbs
    I’m thinking 1 or 4 will be my route.
    How hard is it to change gears in a banjo rear end?
    Does anyone have photos of a torque tube overdrive in a 37?
  15. Beanscoot
    Beanscoot
    I have a cast iron version of this transmission in my car with a 0.70 overdrive. I am very happy with it, except it sometimes pops out of gear in high, resulting in cursing at whatever speed it's at.
    RMR&C, vtx1800 and carothersbs like this.
  16. manyolcars
    manyolcars
    carothersbs likes this.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Before the 8ba, I ran the original 85 horse 1937 21 bolt.
    It wasn’t quite as comfortable running at 65 but was done. Quite a difference in those two engines. If it were me, I’d concentrate on changing the smaller engine if I was running at highway speeds consistently.
  18. 19Fordy
    19Fordy
    Mitchell overdrive would work.
  19. vtx1800
    vtx1800
    Here is the link to reach Mitchell Overdrive Manufacturing No real info other than Email and phone number. https://mitchelloverdrives.com/
  20. carothersbs
    carothersbs
  21. oldolds
    oldolds
    I understand Mitchell's are quite expensive. Well over $3,000 if my friend is not lying to me.
  22. rusty valley
    rusty valley
    from my understanding the mitchel will require modifications to the floor in most v8 applications. model A's have more room there. columbia's can be found reasonable if you are ok with buying just the rear end and do all your own plumbing to make it work. its all the "correct" gadgets that go with them that add up fast. i have a manual shift in mine.
  23. winduptoy
    winduptoy
    What RPM do you want at 65 MPH?
    It is a math problem but you need to know some things like rear end ratio and rolling diameter of the tire.
    It might be that a tire with a larger rolling diameter would get you where you want to be.
    It could just be a tire and maybe a tire and wheel change but do the math...made easy
    https://www.reillymotorsports.com/speed-tire-rpm-calculator.html
    Hamtown Al likes this.
  24. I wanted highway speeds out of my 36 and went for a set of 3.25 gears and a 28 inch tall tire. I dont know what rpm its turning on the highway but I can and have run my car all day at 70-75 with no trouble. Its great on side roads with speeds around 45-55 miles per hour as well. The flathead sounds good working a little... By far the best $375 I spent building the car...
    winduptoy and carothersbs like this.
  25. jimmy six
    jimmy six
    A friend just finished a Mitchel in his 32 49’s style roadster, turned something he didn’t like to drive on the freeway to something he did.
    kidcampbell71 and carothersbs like this.
  26. Deuce Lover
    Deuce Lover
    Macs Auto has them listed at $3445 for the 32-48 Ford. Here is the link.
    Click on above image to view full picture(s)
    Mitchell Overdrive Kit - Ford
    Part #: 32-65234-1
    Alt Part #: V7000
    Price:
    $3,445.99 Kit
    Availability:
    Ships Direct From Manufacture
    Fitment:
    1932 thru 1948
    See applications below for exact details.
    Shipping Note:
    This item has additional shipping charges due to heavy weight or oversize dimensions.
    To add to cart please select from the options below.
    This is a custom ordered item, please select the following options carefully.
    Vehicle Year
    Body Type
    Vehicle Model
    Rim Size
    Diameter of Tires
    Rear End Ratio
    26% or 36% Overdrive
    Cable or Stick Shift
    Right hand or left hand drive
    Qty:
  27. CME1
    CME1
    This is the one used in my 1947 Ford Coupe. Cable Shift mounted on the dash. Ordered direct from Mitchell Mfg. Worked great! Image (3).jpg
  28. Roothawg
    Roothawg
    I still laugh every time I read the title. Sorry, I don't have anything to add.....:D
    blowby, Turnipseed and ronzmtrwrx like this.
  29. ekimneirbo
    ekimneirbo
    What you really need to consider is what you will have after you invest a lot of time and money to get such a low performance engine geared so it can run 65 mph. Absolutely no acceleration in high gear, and not much in any gear. Is it worth doing? Lots of more satisfactory ways to go.
    I assume you want 65 so you can get on a highway......65 doesn't get you anything but the sight of a lot of semi bumpers in your mirror.
  30. jaracer
    jaracer
    The question I have is have you thought about running 65-70 with mechanical brakes?
    CSPIDY, X38 and Moriarity like this.
