You need lower shock mounts. We offer them for 1935 rear ends. The top of the shock is mounted to the cross member. Check this out https://www.jalopyjournal.com/forum...scopic-shock-mount-kit.1127115/#post-13175642
For the fronts I purchased a kit. I used the original axle bolts instead of the ones provided in the kit. I purchased the kit from Joe’s Antique Auto https://www.joesantiqueauto.com The kit was a bolt on with some minor adjustments. I had to grind the corner of the bracket for clearance. Here is a copy of the original kit instructions 1950’s. Sent from my iPad using Tapatalk
I could not find a kit for 36 original rear end, so I made brackets out of 1/4” steel plate and welded them up. I then had the wishbones drilled. I used shocks from SoCal speed shop and drilled holes in the crossmember for standard shock mounting bolts. Instructions for a 1950’s kit. Example of another 50’s kit. Good luck with your project! Hope this helps? Sent from my iPad using Tapatalk
47/48 used tube shocks,so if you can get parts from one,it is a bolt up by drilling a few hole,but only works with cross steer. 48 had best front shock hook up for base of shock,out near brake on axle, was a hole in axle close to kingpin=better shock control vs inboard more.
That is great I found the front kit form the link you gave me but the rear shocks were did you get them or do you have part #
Joes Antique and C&G carry our bolt on rear shock kit for the 35/36 with the original rear suspension. It is also available directly from us.
I purchased the shocks from SoCal Speed shop. I think I used the short shocks but check your travel distances. Also I had to adjust the cross member to get clearance. If I used non covered shocks I would not have had to modify the frame. https://www.est1946.com/speedshocks.aspx Sent from my iPad using Tapatalk
There is more detailed information on the Ford Barn Forum. The post is titled “1936 Ford Rear Tube Shocks Conversion.” I started the post a couple years ago and received my inspiration for doing my conversion. https://www.fordbarn.com/forum/showthread.php?t=209128 If you have additional questions you can PM me. Good luck! Tony B Sent from my iPad using Tapatalk
