I am looking for pics of the floor area in a 27 t coupe. I am putting a 48 truck flathead with the 48 manual trans from the same truck in it. To get the engine looking somewhat right with the placement, and to get the shifter to clear the dash, I have shoved it back pretty far. Foot clearance is going to be tight for 3 pedals. Thanks Scott Sent from my SM-S367VL using The H.A.M.B. mobile app
May I suggest that you search this thread and contact any individual member who you see could be of help to you... https://www.jalopyjournal.com/forum/threads/whos-building-a-t.645511/
Not the best picture but i made a homebuilt one inspired by Ansen. Ofcourse There is thread on this here on Hamb as inspiration. https://www.jalopyjournal.com/forum/threads/26-27-t-pedals.1046067/#post-11857748
With the engine that far back, you have no room for your steering. I would move the engine further forward. Sent from my SM-T350 using The H.A.M.B. mobile app
46poncho it maybe advisable to post some pic's of where you are upto and so we can all get a clear idea of your situation. I like seeing pic's.
Pic helps. I figure channelling will make things just that little more tricky to fit, but I am sure it has been done before. You could reverse or shave the firewall if that would help you. What are your plans for pedals? Do you prefer to hang then or have them thru the floor?
that is a understatement - just will require a lot of mock up trials using anything you have around to simulate the actual parts to be used- every ride will be different
