Projects 26 Tall T Raked Hotrod Build
Discussion in 'Traditional Hot Rods' started by 27Roadsterguy, May 3, 2018.
  1. 6sally6
    6sally6
    OK 27Roadsterguy......"I gots to know"(Dirty Harry line) How much of a V do you think was cut into the yellow roadster frame? 2...3 inches?
    What are your plans?
    Never knew about V-ing the frame...I just ass-umed the body was kicked up real high in the back.
    Thanx....jus try'in to learn
    6sally6
  2. AndersF
    AndersF
    Yea, right. :p
    dumprat and 27Roadsterguy like this.
  3. 27Roadsterguy
    27Roadsterguy
    ^^^^^That sure is Purdy^^^^^
  4. 27Roadsterguy
    27Roadsterguy
    Being as that car is local, to St. Louis, I'll let ya know. At some point, I'm suppose to go look at it in person. I have a few friends that know the owner.
  5. AndersF
    AndersF
    27Roadsterguy likes this.
  6. Have you thought about building a model of your idea? Might allow you to fine tune it before you try it in steel. Loving the build. Thanks for sharing!
    27Roadsterguy and loudbang like this.
  7. 27Roadsterguy
    27Roadsterguy
    Yes, Years ago. The trick is building it to full scale and not screwing up in the process. :)
  8. banana cognac
    banana cognac
    Any updates on the tall T?
  9. 6sally6
    6sally6
    All you "really smart" HAMB'ers help me out pleeze.
    The fellas that run the radiator in the rear.........how bout some details! In the trunk area(I guess)??!
    Pics would be wonderful
    6sally6
  10. 27Roadsterguy
    27Roadsterguy
    I still have it. I've been collecting sheet metal patch pieces and scrounging for parts. I'm hoping to get to work on it this winter. I had shoulder surgery in the fall, which put me out of commission. Now I have a broken leg that I can't walk on. Let's just say I've had some rotten luck over the last 8 months or so...
    It will get finished, but in the mean time, it's at least stored indoors, out of the weather. :)
    banana cognac likes this.
  11. 27Roadsterguy
    27Roadsterguy
    I'm keeping mine up front where it belongs...
  12. touring20
    touring20
    The orange car has the panel above the windshield shortened and windshield raised for better signal viewing .
    Viewin
    27Roadsterguy and Hombre like this.
  13. Jersey Joe 67
    Jersey Joe 67
    from J Town
    I absolutely love this , as I have dreams of building the same style T , someday.
    The Stoner T has been my screen saver on my computer for a while and certainly an inspiration ... can't wait to see how this one turns out !
  14. 27Roadsterguy
    27Roadsterguy
    Yeah, I hadn't seen that one, so thanks for the info. There are a lot of good photos from that build. You can clearly see how it takes very little frame "V" ing to get a rake that looks perfect.
    Jersey Joe 67 likes this.
  15. 27Roadsterguy
    27Roadsterguy
    I finally got to go see this car in person and you are correct, the body is lifted in the rear. I'm still planning to "V" the frame on mine. I'm still collecting parts at this point, hopefully this build can get moving soon...
    dana barlow and Nailhead A-V8 like this.
  16. Nailhead A-V8
    Nailhead A-V8
    Actually this illustrates my previous point...in my experience V-ing happens at 2 points; in front the firewall and again at the front crossmember... this way the crossmembers are still on the same plane just higher up...with one V you're going to have to build some kind of mondo trans tunnel inside and outside the trans will be sticking out.... not to mention pinion angle
  17. vanherrb
    vanherrb
    just bought me a 27 coupe,
    uncut ,and with the same young man dream from 1970,,raked,,,,
    and i thank you jalopy journal guys
