Technical ***June 2019 Banger Meet - Ready 4 summer/winter?***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 31, 2019.
  1. dmdeaton
    dmdeaton
    Matt took another full time job and told me he was retiring the header line and concentrating on intakes now? I wish he would do some more headers
    I am good on banger but would have liked to have snagged a flat V8 set before he quit
    JT1930 likes this.
  2. The car on the Left has a "Banger" for power! On it's right, the car has a Sturtevant V8 aircraft engine. The third car, the Allard, has a 1950 Cadillac V8. The location is Buttonwillow Raceway (West of Bakersfield CA).
    Dannerr, Jet96 and rwrj like this.
  3. burl
    burl
    from Minnesota
    Talked to him last week.Not making anymore sbc headers but still will take orders for others.He has a set of hemi pipes he just posted on insta yesterday.Yes he is also going strong on casting manifolds.
    Dannerr, Jet96 and JT1930 like this.
  4. denis4x4
    denis4x4
    from Colorado
    A few of the 50 cars at the Speedster Reunion...50/50 split between A’s and T’s
    Dannerr, Jet96, kb9jlo and 3 others like this.
  5. noboD
    noboD
    That pickup is tits!
  6. Dustyp489
    Dustyp489
    Great looking 30 pickup, did you get any info or pictures of it. Would love to see them.
    Thanks for sharing
    Skip
  7. denis4x4
    denis4x4
    from Colorado
  8. denis4x4
    denis4x4
    from Colorado
    Looking for a timing gear cover distributor drive for an A. Charlie Yapp is out of stock. Also would like info on a crank triggered ignition system. Thanks in advance
  9. Crazydaddyo
    Crazydaddyo
    I have a couple, but have plans for them. If he is planning on making more, and you can replace mine before I need it, then we can work something out.
    Sent from my SM-J337P using The H.A.M.B. mobile app
    Dannerr likes this.
  10. Denis,
    There are two different types of crank fired ignition systems, one uses distributor and the other uses multiple coils.
    MSD makes the dist type, will need two magnets on the timing wheel.
    Electromotive and others make the multiple coil types, these typically use a 60-2 trigger wheel.
    Have been using the EM and Haltech for years, the trigger wheel has to be on the large side and the sensor is critical over 5k revs.
    John
  11. ghalperin
    ghalperin
    3A4AFE8D-EEEF-4311-A60E-419C9206ACA5.jpeg 1DD8069E-FD1A-42F7-B093-087A4CDF92FF.jpeg I picked up this throttle for my ‘29. It was sold as a ‘32, but I really don’t know. Can someone confirm if it is? I also don’t know where and how to install it. I would appreciate any guidance. Am I missing something on the pedal end for mounting on the firewall?
  12. nothing super exciting to report.....did buy a original manual for my 9N-2N-8N's I'd like to share.......later
    winduptoy likes this.
  13. Glenn, that is 32 and here is mine mounted in a 31 roadster. There is a small tin cover that covers the one end that mounts it to the firewall. Hard to see in the photo. 20181007_115641.jpg
    Dannerr, Jet96 and Old Dawg like this.
  14. wheeltramp brian
    wheeltramp brian
    Is that intake turned upside down with a custom bolt pattern welded to it?or is it aftermarket?thanks.
  15. Intake is Winfield BB.
  16. ghalperin
    ghalperin
    Thanks for the photo and info. Does the little tin cover actually act as the mount? What does the small hollow oval’ish tube on the pedal end attach to?
  17. The oval end positions the rod against the firewall and the tin cover holds it in place.
  18. wheeltramp brian
    wheeltramp brian
    Hey MJW, what brand intake is on your banger? Looks nice.you running a 94?
  19. ghalperin
    ghalperin
    Does anyone have a lead on finding one of those tin cover?
  20. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    It's a scalded dog intake from Charlie Yapp at secrets of speed society. Yep a 94.
    Sent from my Nexus 6P using The H.A.M.B. mobile app
  21. Hank56
    Hank56
    from NC
    I swapped my tillotson carb out for a model B carb in my banger powered 26 rpu last week...big difference! Cruised it around twice a day for the last few days..plan on cruising it later on today....this is my first bangered power ride..im definately hooked! 20190628_174123.jpeg 20190628_174027.jpeg 20190628_174143.jpeg
    Sent from my LG-M327 using The H.A.M.B. mobile app
  22. Jiminy
    Jiminy
