Hot Rods '37 up Ford spindles . . .
Discussion in 'The Hokey Ass Message Board' started by PetesPonies, Feb 10, 2019.
  1. PetesPonies
    PetesPonies
    from Maryland
    I have a '30 Model A. If using '37 up spindles . . is there a hub/drum brake setup that is 5 X 4 1/2 BP ?
  2. 1946caddy
    1946caddy
    from washington
    The easies and probably cheapest way is to use a disc brake kit.
    If your using 39-48 passenger car brakes or f1 brakes you could have them drilled for 4 1/2 bolt pattern but all 4 1/2 wheels might not fit and some hubs might require machining.
    scrap metal 48 likes this.
  3. alchemy
    alchemy
    I don't see any reason that a redrilled set of F-1 brakes wouldn't let a modern wheel fit. Fairly easy job for a guy with a rotary table on his mill. Or use one of those drilling jigs and your drill press.
    gimpyshotrods and jimgoetz like this.
  4. yep....re-drill some `48-`52 F-1 or `53-`56 F-100 brakes , no big deal
    i have them on all my cars and love them
  5. ramblin dan
    ramblin dan
    wheel bolt 1.jpg wheel bolt 2.jpg wheel bolt 3.jpg wheel bolt 4.jpg When I was a machinist, I built a bolt pattern checker mold. Here's the bolt pattern sizes I used and hope this helps you in your redrilling process.
    thirtytwo and Budget36 like this.
  6. PetesPonies
    PetesPonies
    from Maryland
    I appreciate everything guys. Yeah I knew discs would be easier, but I think I want drums. Is there anything significantly different between the years drums to look for?
  7. scrap metal 48
    scrap metal 48
    39-41 Ford brake backing plates have 4 adjustment points per wheel and 42-48 have just 2 adjustments per wheel.. Sometimes the earlier ones can be hard to get adjusted right....
    jimgoetz likes this.
  8. i use a drilling jig i built on a 5 axis control Mazak CNC machining center. i've used it dozens of times. it will do 5-1/2", 4-1/2" and 4-3/4" bolt circles
    the jigs offered by RottenLeonard on here seam to be a good value if you don't have access to machine tools. then you can do it for others for $$$
  9. jimgoetz
    jimgoetz
    I like the later backing plates better. Just be sure you get the right brake shoes they are different from the early ones.
  10. PetesPonies
    PetesPonies
    from Maryland
    Again, thank you very much. I'll look for some 42-48 setups.
  11. PetesPonies
    PetesPonies
    from Maryland
    Are the hubs the same early and later? So just the backing plate is what is different? And a follow up . . would everything from a 1956 F100 front axle work? Spindles and all?
  12. eaglebeak
    eaglebeak
    There is a difference between '37 to '41 spindles ans '42 to '48.
    I forget what it is though.
    Maybe the radius where the inner bearing goes?
  13. deucemac
    deucemac
    37 to 41 and 42 to 48 spindles are identical except for the backing plaster mounting flange and king pin length. The 37 to 41 spindles have a round flange where as the 42 to 48 have a square flange but use the same bolt pattern and accept any 39 to 48 backing plate. The 42 to 48 spindle uses the same diameter king pin but the pin itself is longer than the 37 to 48.
  14. 1946caddy
    1946caddy
    from washington
    I don't have a mill for drilling the holes but I've used the circle template from Harbor Freight with great success. Place the plastic template over your existing hubs or axles and hand tighten the lug nuts. Then use the correct transfer punch ( centering punch) to lightly mark the hole which is clearly marked for the different bolt patterns. I then re punch the marks using a normal punch after removing the template and drill the punch marks with a 1/8 drill bit in a drill press. I then drill the correct size hole for the stud I'm using.
    https://www.speedwaymotors.com/Bolt-Circle-Template,5951.html
    Just picked this 47 Ford front end off Craigslist for $100 along with the 15" wheels that are on it.
  15. alchemy
    alchemy
    Just my personal opinion, but there's no way in hell I'd trust a plastic gauge to center my wheel studs correctly.
  16. rusty valley
    rusty valley
  17. 1946caddy
    1946caddy
    from washington
    Your not drilling through the plastic template. I tough I made that clear.
  18. chopndrop
    chopndrop
    1956 F100 spindles will not fit Model A axle. 37-41, 42-48, or 48-52 F1 truck will. The brakes from the 1956 F100 can be made to fit the 37-48 spindles and are a good option.
  19. PetesPonies
    PetesPonies
    from Maryland
    OK this is what I needed. So not the spindles, but everything else. So if I buy some aftermarket stock type spindles, I can use the brakes. You say made to fit . .meaning?
    46caddy . . that was a deal!!
    and I want to clarify what I'm doing. I have a Pinto/MII 8" rear axle hosing. That is a perfect fit for a Model A. So I need either both front and back to be 5 x 4 1/2 or 5 x 5 1/2. I could have special axles made with a 5 x 5 1/2, or a wheel adapter for the rear, to match the 5 x 5 1/2 front. And I assume I can use 60s/70/80s etc, Ford steel truck wheels?
  20. chopndrop
    chopndrop
  21. chopndrop
    chopndrop
    40-48 Ford car or truck wheels have 5-1/2"×5 pattern, as well as most Ford trucks up to relatively recent history
  22. PetesPonies
    PetesPonies
    from Maryland
    Thanks. Yes I have many Ford trucks, so I have some wheels. So running the 5 x 5 1/2 wheels would mean no alterations to the front, but still have to do something to the rear for a match. Or go disc on teh front :) Drums would look cooler.
  23. PetesPonies
    PetesPonies
    from Maryland
    Anyone know if these are early or later plates?
  24. PetesPonies
    PetesPonies
    from Maryland
    And also , something I can add . . .I see mentioned using brake drums up to '66 F100s. Well if '66s work, so do '67s. The '67 used the older bodystyle ( '66 ) brake system. It wasn't until 1968 that the suspension and brakes changed. But I guess the hub changed?? The bearings are the same, inner and outer, '66 and '67. So it seems a '67 drum/hub would work?
  25. F-100 front drums are the same from '53 to '62 or so.
    The bearing sizes were changed in '57; so only '53-'56 hubs are usable on early spindles.
    The backing plates in the picture you posted look like '48-'52 F-1 or '53-'56 F-100 plates.
  26. PetesPonies
    PetesPonies
    from Maryland
  27. chopndrop
    chopndrop
    Just checking part numbers, a 53 drum has a different number than 66, although I have seen mention that they are interchangeable, at least with regards to this application. I know the 66 hardware is often used as it is self adjusting.
  28. ramblin dan
    ramblin dan
    Saw these for sale on ebay some time ago. thought it was around hundred bucks for the kit.
    olscrounger likes this.
  29. PetesPonies
    PetesPonies
    from Maryland
    Pretty cool Dan.
    Chopndrop . .right, it is mentioned often. And what I'm saying is, if a '66 works, so does a '67. Anyone ??
  30. chopndrop
    chopndrop
    Looks like front drums have same part numbers 64-67
