I'm sorry, but I have no idea of the proper name for the metal piece that mounts over the front header... Here's the issue. It seems that the design of the piece will not allow complete coverage of the oak header beneath. We did take a sander to the leading edge of the header to see if the profile change would cause it to cover more....decided that we'd have to take a hand wood plane to it to do it better. But, in looking at how the outside is keeping this standoff...I'm guessing that's just the way it is. Comments??? mess with it or heck with it?
a piece of fender welting along the top edge of the steel, and sitting proud of the top of the wood will form a "seal" and finish it off.
Does the visor mount below? I forget... If so, I do think the top mat'l goes on 1st. That being the case, you'd need to have some exposed wood to tack it. I'm a little foggy on the 28-9 details. I know the visors are also covered and none of it really means anything if you're moddin anyway.
Thanks all...makes sence that it could have been used as a nailer. Then the visor riding underneath finishes it all off. While I'm asking questions... What is the choice of material for the seam between the cowl and the body. Or General Model A "how to seal out water" lotsa potential leak points on this car. thanks
fender welting will work, painted the same color so it disappears. you can cut the bead off if you don't like the look, or use seam sealer and tool it smooth.
Mine showed a little wood, but not that much. Keep trimming the wood. Be sure to use a good sealer all along the header. When you drive in rain the air will push the water up and into the seam where it will soak up into the wood and into your headliner. You don't want that wood to rot out again or stain your fabric.
Any pics out there of those that removed this all together...cut it all back and moved the visor up???? thanks
