Go Back   THE H.A.M.B. > General Discussion > The Hokey Ass Message Board > New to the H.A.M.B.? Introduce yourself here!
Reply
Thread Tools Display Modes
Old 02-09-2012, 08:58 PM   #1
shelbro
FNG
Default 1954 f100 rear end swap
I have a 1954 f100 and would like to use a 9" rear end. What donor vehicle could I use for a direct bolt in?
offline   Reply With Quote
Old 02-09-2012, 09:46 PM   #2
chopped51
Senior Member
chopped51's Avatar
Default Re: 1954 f100 rear end swap
No such thing. Figure out what wheel offset and tire combo you want to run and start from there. Keep in mind there is an infinite number of gear ratios as well.
__________________
Relax. I think this should work. www.areafifty1.com
1951 Merc Kustom
1950 Merc M1
1927 STEEL RPU
Old 02-10-2012, 08:21 AM   #3
OLIVER BROS GARAGE
Old School HAMBer
OLIVER BROS GARAGE's Avatar
How about follow directions and post an introduction please.
__________________
Viva Las Vegas
or Bust
April 2014
online   Reply With Quote
Old 02-10-2012, 12:02 PM   #4
Spitbucket
Alliance Member
Shelbro, welcome. I did this swap in the mid 1980s, so details are fading away. However, this is one of the easiest swaps out there. I used a 72 F100 rear. The width was the same, and the spring perches lined up, wheel bolt pattern is the same. As I remember you had to buy larger diameter U bolts because the axle tubes are larger. I think we redrilled the stock spring perch plates and flipped them side to side. Can't remember why, but it made sense at the time. The pinion yoke on the 9 inch is closer to the rear end (shorter "snout") This requires a longer drive shaft. Universal joints can be bought that adapt the pinion yoke to a non stock application. I'm sure someone will chime in and specify the exact years you can use. Research a little, ask around and go for it.
Old 02-10-2012, 12:13 PM   #5
Carbs & Chrome
Old School HAMBer
Carbs & Chrome's Avatar
If you want to keep the 5X5.5 bolt pattern you will need a 57-72 F-100 9" rear. The 57 - 60 will have shock mounts similar to your '54 and is the easiest swap.
If you want to switch to a car bolt pattern you will need a 67 Cougar, 67-73 Torino, 67-73 Ranchero, 67-73 Fairlane, or 71-73 Mustang.
Be sure you know the difference between an 8" and a 9" when sourcing out one.
As stated you will need different U-bolts and some driveline mods.
Old 02-10-2012, 02:15 PM   #6
Spitbucket
Alliance Member
Moser engineering redrilled my 5.5 bolt pattern on the axle shafts and drums to match the Volare fronts. At the time, price was reasonable and may be less of a hassle than using a car housing. Not challenging Carbs & Chrome, just pointing out another option.
Old 02-12-2012, 06:51 PM   #7
shelbro
FNG
I will look into The options you have suggested. Thank you all for your input.
Sense I did not follow directions(I have a hard time doing that) I will introduce myself I am shelbro and live in Vacaville.my 10 year old son and I are building a 54 f100,hope to have it ready for him to drive when he is able. I will post some photos when I figure it out.until then happy trails
Old 02-12-2012, 07:17 PM   #8
mrharley51
FNG
mrharley51's Avatar
Just put an Explorer 8.8 rear end in a 54. Has 3:73 traction lock, disc brakes and sway bar. Great fit with a 235/70/15 on a 15 by 8 with 4" backspaced steelie. The rear end was $225.oo at the local boneyard. Explorer has 31 spline axles and you can get parts on any corner auto store. MHO
Old 02-12-2012, 07:56 PM   #9
60 ford
Senior Member
60 ford's Avatar
Welcome from Indiana.
__________________
My Altered Wheelbase 62 Falcon Build
http://www.jalopyjournal.com/forum/s...d.php?t=474111
Old 02-12-2012, 10:43 PM   #10
shelbro
FNG
Quote:
What year of exploder? and is this a direct bolt in or do I have to move spring perches or any other modifications?
Old 02-13-2012, 08:43 AM   #11
Carbs & Chrome
Old School HAMBer
It is not a direct bolt-in. The over-all width is close and you do get rear disc brakes though.
Nothing is going to be a "direct bolt-in". As far as I know the 57 - 60 1/2 ton 9" will be your closest to a "direct bolt-in".
Is the rest of the trucks suspension stock? What is your end goal with the rear end swap?
Old 02-13-2012, 10:47 PM   #12
shelbro
FNG
I am just looking for an option with the least amount of modifications,I do like the disc brakes with the 8.8 rearend.
I am keeping the front axle original and my thought about using a 9" is to up grade the original rear with another rear that is somewhat in it's time period.
Old 02-14-2012, 09:02 AM   #13
dirtbag13
Old School HAMBer
dirtbag13's Avatar
i used a 72 truck rear in mine , easiest route ! explorer rearend is good too but more modifications required
__________________
One hand on the wheel and one on the bottle one foot in the grave the other the throttle !
Old 02-14-2012, 09:04 AM   #14
dirtbag13
Old School HAMBer
dirtbag13's Avatar
Quote:
yeah i swapped to a 5 on 4 and a half front when i went to discs and had my rear axles redrilled for around 75 dollars
__________________
Old 02-14-2012, 04:06 PM   #15
pakrat
Grenade Inspector
pakrat's Avatar
Welcome.
Old 02-15-2012, 06:50 AM   #16
robleticia
Old School HAMBer
robleticia's Avatar
Welcome from Texas!
__________________
"HEY, WATCH THIS!"
Check it out: www.barxhotrods.com
My build thread:
http://www.jalopyjournal.com/forum/s...d.php?t=525131
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
