Muncie 4 speed vs Saginaw 4 speed?
Discussion in 'The Hokey Ass Message Board' started by ssk875, Jan 18, 2012.
  1. ssk875
    ssk875
    from Buffalo
    Looking for a chevy transmission for my hot rod I dont know much about trannys, anyone have any preferences over the muncie vs the saginaw?
  2. Black Panther
    Black Panther
    from SoCal
    Muncies are stronger...they used them behind all of the highest hp cars GM ever made, LS6 Chevelles, tripower 427 Corvettes etc...the Saginaw was/is a low performance cast iron transmission normally used in base engine cars like 327 2 barrel Camaros...that being said they are popular because they are cheap and in lightweight old cars they hold up ok since there normally isnt enough traction to break them..
    lawman and 54MEB like this.
  3. ssk875
    ssk875
    from Buffalo
    Ok thanks thats what i needed I need something a little stronger then the saginaw
    Thanks
  4. Deadbird
    Deadbird
    Muncie for sure. How can you beat a rock crusher?
    1Nimrod likes this.
  5. Don't rule out the late 70's Borg Warner Super T10 transmission too. They came in the Z28, Trans am and Corvette's ... stronger than a Saginaw and quite possibly cheaper than a Muncie.
    HiHelix likes this.
  6. mgtstumpy
    mgtstumpy
    'Muncie', I had a 'Saginaw' behind my hopped up 6yl and it wasn't up to the task. Plus 'Muncie' is lighter with an alloy case when compared to heavier cast 'Saginaw' case.
  7. carlos
    carlos
    from ohio
    what you going to do with it,go for the muncie if your wallet can stand it but a sag can be bought allot cheaper
    54MEB likes this.
  8. harrys55chevy@bellsouth.n
    [email protected]
    The net top loaders is the best ... None of that linkage to be in the way and no adjusting ...
  9. nwbhotrod
    nwbhotrod
    from wash state
    You can get a lower first gear in the Borg Warner also
    Hudson31 likes this.
  10. 42hotrod
    42hotrod
    from S.E. Idaho
    Also, again if your wallet can handle it, there are several companies out there now building what are being called "Super Muncies". All brand new components, heavier case, iron midplate, beefier M22 geasr sets in a variety of ratios. One brand new with warranty will set you back just under 2G's, but a good friend of mine is running one behind a 511 BBC on spray, has made over 850 HP on a chassis dyno, so over 1K horsepower at the flywheel and he had no problems, even launching it at the dragstrip!!
    Scot
    1Nimrod and mike in tucson like this.
  11. 40Standard
    40Standard
    from Indy
    I like the Muncie better. You can do a search on here. This question has been asked before.
  12. Saginaws offer a lower 1st gear than most Muncies and will hold up pretty well but won't take 1/2 the beating that a Muncie will. I had one in a '66 Nova and it did well even with a hole shot or 12... Gotta have a good shifter on them though.
    Bob
  13. Drive Em
    Drive Em
    The Super T-10 is by far a superior transmission to the Muncie, in all ways. They can still be bought new from Summit as the Richmond 4 speed, and you have a choice of ratios.
    falcongeorge likes this.
  14. Keep in mind, Muncie's are available in close ratio and wide ratio. You should try and get one that will suit your driving needs and the set up you are running. Yes, the T-10 is better than both the forementioned tranny's, TR
  15. Two other items I'd like to mention. If buying a used tranny, pull the side cover and look see inside, dont take someones word it's good. Bring a telescoping magnet and go through the gear lube in the bottom of the case.
    Remember these tranny's use GEAR LUBE, NOT ATF like newer model transmissions. Also, do your homework and learn about the " rings ' on the input shaft, these will help in I.D.ing the trans, TR
    pitman likes this.
  16. 42hotrod
    42hotrod
    from S.E. Idaho
    All really good advice, I would add one thing on the rings on the input shaft though. All replacement shafts since the 60's have no rings cut in them so if you get a shaft without any you will know it has more than likely had a replacement input shaft. No biggie, just means you'll have to do some tooth counting on 1st gear to get your intial ratio to figure out what tranny you have.
    Muncies are a really unique tranny because of parts interchangability. If you decode the average muncie today you may find a pontiac main case, an oldsmobile tailshaft housing and a chevy mid plate all through the numbers. Most rebuilders in the day had big buckets of parts and if they needed a main housing they grabbed one regardless of the part number because they all interchange. Pretty rare to find an all correct muncie in this day and age.
    The one in my 55 chevy was a 66 pontiac main body with unknown input shaft or tailshaft housing. I had to count the teeth to determine internally it was an M-20 wide ratio.
    Good luck, there are a ton of websites out there to help you figure out what parts you need or what your looking at if your buying used complete. If it is an actual M22 (everyone says they have a "rockcrusher", I've only seen two actually turn out to be real M22's) They are worth a good chunk of change and worth repairing. If you've got a real M22, you'll know it by driving it, with the angle of the gears they howl like a sum bitch going down the road. as in LOUD. And changes pitch with every shift.
    My .02 if my opinion is worth that today, for a good all around street car, i'll take an M20 any day of the week. The closeness of of the 2-3 shift in a close ratio means most of the time you end up skipping second anyway and shifting 1st, 3rd, 4th on the street.
    Scot
    lurker mick likes this.
  17. Thanks Scot for that info on the input shaft rings, good to know, TR
  18. derbydad276
    derbydad276
    if your building a lite medium horsepower car a saginaw will work fine also they cost a hell of a lot less than a muncie
  19. davidbistolas
    davidbistolas
    Saginaw: $
    Muncie: $$$$$$$$$$$$$$$$$$$$$
  20. Hdonlybob
    Hdonlybob
    Saginaw's come in three or four different gear ratios, making it a great medium HP trans in my opinion....also as said here .....very low cost compared to others.
    I am using a two ring shaft which is a 3.11 first gear with a 3.36 rear end that gives mg good performance for my little warmed up 283.
    Here are the gear ratios available:
    Saginaw 4 speed
    1st 2nd 3rd 4th
    3.50-2.48-1.65-1.00
    3.11-2.20-1.47-1.00
    2.85-2.01-1.47-1.00
    2.54-1.80-1.44-1.00
    Good luck on your choice.
    Cheers........
  21. mike hohnstein
    mike hohnstein
    from wisconsin
    I own a medium sized trans reman facility www.AutoTransDesign.com we do a lot of vintage work. The notion of finding a usable Muncie in this day and age seems a stretch at best, had a hard time finding good parts 25 years ago. Now before the flames, I ran a stick shift mid 9 second 2800# drag car for a long time and Doug Nash 5 sp 2.80 first gear ratio was the tool of choice so I have a pretty good idea about how powershifting and clutches and shit like that work.
    My present personal toy is a Hamb unfriendly 70 Monte w/oval port 496, 3.55 and a Super T-10 because I had one. I never get a used trans through the shop that is usable when inspected and I can afford not to screw customers. Had a Mopar guy send three different units he had been sitting on for years, in dry storage, however gears were pitted from moisture over the years, don't see that until disassembled and run through the hot water washer. 90 weight can hide a lot. I've posted this before but it bears repeating, ALL PARTS are made in fucking India or some other overseas place and that calls into question all sorts of things, like rockwell hardness, metalurgy etc etc. I get a kick out of how long legends last, like the 'unbreakable' M-22s, and how Ford ATF is the only thing to use.
    mike in tucson and lawman like this.
  22. I have an M-22 (confirmed when rebuilt) and a Saginaw and like them both. The rebuild parts for my rock crusher cost more than what I paid for the Saginaw. I like the Saginaw for everyday driving because it is quieter and as someone said earlier I skip second quite often on the M-22. Unless you are planning on flogging your transmission a lot, I would go with the Saginaw for an everyday driver just because of the cost. Having said that, I would not dream of putting the Saginaw behind my 454.
    hydroshawn likes this.
  23. cheepsk8
    cheepsk8
    from west ky
    Not to mention, reverse on a Muncie is up and out of the way, lots better if you have a tight seating issue. They are better in every way I can think of.
  24. teddyp
    teddyp
    was there ever a saginaw 4 speed with other then a cast iron base?
  25. davidbistolas
    davidbistolas
    up and out of the way? what do you mean?
  26. SLCK64
    SLCK64
    Thank god I have a FoMoCo product! Only need one choice....Toploader!
  27. Halfdozen
    Halfdozen
    I recall reading somewhere that someone makes an overdrive gearset for the later Muncie case with the 1" cluster shaft. Original 1:1 fourth becomes third, original third gear is an overdrive. Shift pattern remains the same by turning the 3-4 lever on the side of the case down. Anyone know more about this?
  28. some good info here I was looking at a Muncie to sit behind my 235 but man the price is crazy may just go with a Saginaw 4 speed instead
  29. DDDenny
    Yep
    The M-20 I had built for my 67 Nova in 1983 was built out of parts out of a 55 gal drum.
    If your car has high rearend gears ( low numerically), you will want an M20, has a lower first gear, much easier to get a car moving, especially if it's a heavy car.
    Agreed
    $=hamburger
    $$$$$$$$$$$$$$$$$$$$$$$$$= steak
    I'm not going to tell you that Muncie 4 speeds are the worlds strongest transmission, but if there is ANY chance of going to a V/8 with ANY amount of horsepower you would be wise to go with the Muncie at a minimum.
  30. no I'm sticking with my 235
