Projects 53 Chevy 3100 ..Now my Project!!
Discussion in 'The Hokey Ass Message Board' started by 53inSD, Aug 25, 2011.
  1. 53inSD
    53inSD
    This truck Has been in my family since 1958, When My Grandfather purchased property for his business, and this came with it. So the truck became mine the beginning of August 2011. Here is what I have done so far, with much reading on H.A.M.B to decide what to do. I Completely stripped the air cleaner , primed and painted, was thinking about going paper , but love the look of the oil bath. Was not ready to cut it up and try and shove a paper filter in it. So today I did some WWW's with the Krylon Method, that I read on the H.A.M.B. I sanded the sides with a flap disk, wiped with mineral spirits and taped. I used Dover White Krylon Fusion. Was hoping it was not going to be as bright, it was. Could not find "bone white" that I saw in another post. But still looks great. Love it! Just need to do a little light sanding on some over spray. The second tire I did, the tape popped up , and it will take a more effort to clean and tighten up. But still So cool. I will be doing the rears tomorrow. Will keep everyone updated on yellowing and such!
  2. 53inSD
    53inSD
    A couple pics with hub caps back on. The hubcaps used to be white . I am thinking I may change them back to white with black lettering.
  3. Orange54
    Orange54
    from Missouri
    Nice truck. Have fun with it.
  4. 53inSD
    53inSD
    Thanks. So far I am having so much fun. What does your 53 look like?
  5. 53inSD
    53inSD
    Got the rear wheels done today. Made sure I cleaned where the tape was going to be super good. Turned out great. Mineral spirits a rag and q-tip did great for cleanup on the tires from the day before.
  6. Dave K
    Dave K
  7. 53inSD
    53inSD
    Thanks Dave
  8. 53inSD
    53inSD
    I wanted to show a before and after of the air cleaner. I cleaned it out, removed a couple layers of paint from the outside, primed and painted it. Turned out Good. Lovin the 53!
  9. leroys85coupe
    leroys85coupe
    from usa
  10. Danimal
    Danimal
    1. A-D Truckers
    Need more ideas, join the AD Truckers Social Group. Love these trucks!!
  11. waldo53
    waldo53
    from ID
    Very nice '53!! Good job on the Krylon WWW's.
  12. 53inSD
    53inSD
    Joined it, Thanks..It is perfect Did not know about the seperat AD posts and being able to search them...Awesome
  13. 53inSD
    53inSD
    Thanks, I have admired your Truck, Need that lower stance for mine!
  14. 53inSD
    53inSD
    Thanks Leroy
  15. 53inSD
    53inSD
    Could not keep my hands off the truck today, was going to mount the front lic plate differently so it would not cover up grill. Think i have my solution, but I need a new center bolt for my front bumper, to finish it up. SO, I tore off the front turn signals. Wow looks way better. Love the lines of these trucks. Beautiful! Will fill in holes tomorrow. Going to order the turn signal conversion from lmc, and some other small stuff. Also under the turn signal, I may have discovered the original color. I always thought it was a darker green.
  16. waldo53
    waldo53
    from ID
    My truck had those aftermarket turn signals on them too - they had to go!
    Just FYI, the hood badging on your truck is 1952. In '53 they did away with the Chevrolet markings and only used the 3100 markings. Doesn't really mean anything, someone could have added the markings, hood could've been changed at some point, or it could be a '52 registered as a '53.
    It might be interesting to look at the engine serial number (a stamped number located on a flat ledge just aft of the distributor) and see what comes up. Post the number on here and I or someone else can determine the year of the engine.
  17. 53inSD
    53inSD
    Found it
  18. 53inSD
    53inSD
    Engine ID
  19. matthew mcglothin
    matthew mcglothin
    Very cool pickup! Looks like your havin a ball!
  20. 53inSD
    53inSD
    What i can tell by the number is that it is a 216 and does the GM mean it was made at the Tonawanda engine plant in NY. And I was looking at 52 chart, so now you have me super curious about this 52/53 mystery.
  21. Great photo documentation on your whitewalls! I hope they hold up. I was wondering about the fusion paints. I used regular flat white krylon in thin coats, but they only last a year or two against scuffs and cracks.
  22. 53inSD
    53inSD
    I am! pretty much cannot believe it!
  23. 53inSD
    53inSD
    I used the fusion, because of a post I read. And it made sense to use it because it bonds to "plastic". I mean the tires are rubber, buuut. I hope they last a while. I used one can for 2 tires, and 2 pretty good coats and 1 last little coat on each with that. They look so sweet right now, made it a whole new truck. So we will see I will definetly be posting pics of them.
  24. waldo53
    waldo53
    from ID
    That's the casting no. and it tells us it's a 216 block used from '42 - '53. What we need is the ID number, a STAMPED number on a flat ledge just behind the ignition distributor. Post that no. and we can tell what year the engine is.
  25. 53inSD
    53inSD
    Well Found it, man its pretty greasy in there, I had been looking , anyways that was easy.
  26. 53inSD
    53inSD
    here it is
      189.7 KB
  27. 53inSD
    53inSD
    K, so L is its a 53, and BA is it is a 216 truck. Built in Flint. But what is the rest (I635), and is that correct? Is the I for september?
  28. waldo53
    waldo53
    from ID
    Yup, it's a '53 216 truck engine. The "I635" is the production number or serial number. Since they started the serial numbers at 1001 I'm guessing the "I" is actually a "
    "1".
    If you want more info there should also be a date code cast into the block just above the starter. It will be a letter, followed by 2 or 3 numbers.
    Interesting that the engine is a '53 and the hood a '52.
  29. 53inSD
    53inSD
    Yeah that is interesting, I am guessing the emblem mounting holes would be different. Do i have my side mirror bracket upside down, or does it go either way?
  30. last g-man
    last g-man
    ......cool. hey, what the heck are those 'lil "spurs" on the ends of the front bumper?
