Reply
Thread Tools Display Modes
Old 03-20-2011, 09:47 PM   #1
fosheezie
Newbie
fosheezie's Avatar
Default f100 with camaro subframe.. wrong way to do it
how it goin fellas, ive got a quick question that hopefully someone can shed some light on..
ive got a buddy with a 54 f100 that he is wanting to get rid of, i went and looked at it today and the thing needs work but overall is pretty solid, the truck has a camaro front subframe installed in it, with power disc and a chevy 350, little interior but runs and drives down the road just fine.. the question that i had is there a wrong way to graft a camaro front subframe to one of these trucks.. ive actually never seen one that has been done before and know there are far better ways to have ifs (mustang 2 or aftermarket) or to just leave the stock solid axle in it like i did in mine... but the fella that set this up actually welded the camaro front subframe underneath the stock ford frame... he sectioned it a bit but basically looks like the subframe was rolled underneath the factory frame then welded, and i thought the right way to do is was to butt weld the frames together then brace on both sides... before i bought this truck i wanted to know if this is something i should totally stay away from or not... (ps i can get the truck pretty cheap)
offline   Reply With Quote
Old 03-20-2011, 09:56 PM   #2
chillywilly
Grenade Inspector
chillywilly's Avatar
Default Re: f100 with camaro subframe.. wrong way to do it
I had a 55 with a camaro clip... drove the sh!t out of it for about 4 years or so... I did not butt weld the frame - rather slid the two together and reinforced the heck out of it with some serious plate. The higher the subframe is mounted the lower the truck will be ... mine was this ride height always.. no bags or lifts. just a lot of cracked and bent running boards!!!! cant locate a pic now - of course
__________________
Polishing a turd doesn't give you gold....
just shiny shit
Old 03-20-2011, 10:07 PM   #3
chillywilly
Grenade Inspector
found pic
Click image for larger version
ID:	1273886   Click image for larger version
__________________
just shiny shit
Old 03-20-2011, 10:08 PM   #4
chaddilac
Old School HAMBer
chaddilac's Avatar
Dang Chilly!! that looks slick!!
__________________
Specializing in Custom Logos and Design
Old 03-20-2011, 10:12 PM   #5
Carbs & Chrome
Old School HAMBer
Carbs & Chrome's Avatar
Doesn't sound right if I am envisioning it correctly.
Old 03-20-2011, 10:17 PM   #6
Larry T
Old School HAMBer
Larry T's Avatar
I've seen the Ford frame "stacked" on a Camaro frame before. It doesn't look very professional. On one of them, the owner went back in and tied the Camaro frame into the pickup frame where they butted together and cut the rest of the Camaro clip off. It still ended up looking pretty shadetree.
Larry T
__________________
Goldchainers CC
Old 03-20-2011, 10:22 PM   #7
fosheezie
Newbie
fosheezie's Avatar
i guess something like this can always be fixed but that definately puts a dampner on the purchase right off the bat knowing im gonna have to do frame surgery... truck is lowered from stock but nothing drastic... sick truck chilly by the way.. do you have any frame pics close by... ill see if i can take a pic and post tomorrow
Old 03-20-2011, 10:27 PM   #8
chillywilly
Grenade Inspector
Quote:
you posted a pic of this truck before when it was light blue and black...
__________________
just shiny shit
Old 03-20-2011, 10:29 PM   #9
chillywilly
Grenade Inspector
i dont have a pic of the frame work... if memory serves i slid the clip into the stock frame and boxed it all up... was pretty straight forward .. tracked beautifully
__________________
just shiny shit
Old 03-20-2011, 10:35 PM   #10
fosheezie
Newbie
fosheezie's Avatar
i know than anything can be fixed with a plasma cutter and a welder but would something like this be a deal breaker for one of you guys looking for a project .. you cant see it from the side of the truck ( because of the running boards) but it does look like a little peice of hell underneath.. i jujst didnt know if they were all done like that.. guess not
Old 03-20-2011, 10:37 PM   #11
chillywilly
Grenade Inspector
i personally love these trucks... had a few ... if you don't want it and it's cheap lemme know!
__________________
just shiny shit
Old 03-20-2011, 10:54 PM   #12
Sean Allen
Alliance Member
Sean Allen's Avatar
Do you know what the radiator came out of? My buddy is doing something similar with a 52 F1 and a 73 Trans Am and doesn't have room for a radiator?
__________________
By His grace, for His glory
Old 03-21-2011, 06:21 AM   #13
chopolds
Old School HAMBer
chopolds's Avatar
I've subbed a lot of cars in my time (yeah, I know it's not popular here, but if done right, it WORKS). I've never done one like that, though I've seen them. Someone took the easy way out.
I like to splice them is, so they are not so blatently "subframed". Fish plates, and reinforcements make them safe and strong, and blend them inot the existing chassis.
By welding the new sub in, higher up into the stock frame, you also effectively lower thte car quite a bit.
So if I was to get a car like you mentioned, I would change it, for safety, asthetic, and height reasons. If paying someone else to do it....it would cost a bunch, so you'd have to get the car pretty cheap!
__________________
Finished The Kart
Proud Member: Gold Chainers CC
Old 03-21-2011, 06:45 AM   #14
bonez
Old School HAMBer
bonez's Avatar
If you can do the work your self and its reallycheap and the rest is as nice as you describe it go for it. i would.
__________________
Sent from my ouiji board with black magic
Old 03-21-2011, 07:33 AM   #15
meatball
Old School HAMBer
meatball's Avatar
this has worked for decades,last one I did I bought a 69 camaro sub for about $100 with the power steering and brakes,and like has been said they track and work great if boxed and made strong,just kinda uglly sometimes,we ended up spliting my rails open some and tried to make it look more blended..I would still do it this way over a mustang two ....their damn near bullet proof!
__________________
Be nice to strangers.......They may sit on your jury! Street Freaks RULE!
online   Reply With Quote
Old 03-21-2011, 07:44 AM   #16
Voodoofire1
FNG
Well my cousin Brad had his neighbor clip his 53, and they welded it under the existing frame, doesn't look to bad.........I did my 67 truck myself with a WS6 clip, and grafted it in 19 years ago, never had a problem then, and haven't had a problem since, sits great, rides great, no body roll and corners like you wouldn't believe... best thing I ever did to it, and I use to drive it everyday...... and will be again soon as the facelift is done..... for myself, I wouldn't trade my clip for a mustang II if you paid me and my trucks a ford...... built ford tough, with better chevy stuff...
Old 03-21-2011, 07:51 AM   #17
chevyshack
chevyshack's Avatar
Damn chillywilly! That truck looks great snow white. It just pops. As for the clip welded under the fram id buy it anyways if its cheap. You could always redo it. Just make sure you keep that in mind with the price.
Old 03-21-2011, 07:52 AM   #18
coupe man
Grenade Inspector
coupe man's Avatar
I did my 41 ply this way.Been driving it for 15 yrs and no problems.I agree its not the nicest looking way to do it but it's safe if its done right and it does handle well
Old 03-21-2011, 08:02 AM   #19
oldolds
oldolds's Avatar
With the frame butted together you only have the welds around the frame holding it together, (maybe 15 inches on each frame rail) which is all the factory uses.
If you lay the one on top of the other You will have over 4 foot of weld on each frame rail. You will also have less problems with correct caster angle.
It mostly depends on how much you trust your welds
Old 03-21-2011, 08:04 AM   #20
42 chevy
42 chevy's Avatar
Isn't there a thread by Luxblue on here that did it like that? I think it was how to subframe a '58 Chevy truck in a day or some title like that. I think it is Camaro clip in your '58 Chevy in one day, I found it in a search. It looks like it was done just as you describe that one. I have seen several done this way and never heard of any trouble. My '42 Chevy has a '74 Nova clip butt welded and fish plated and it handles amazingly well and is low as well.
Last edited by 42 chevy; 03-21-2011 at 08:10 AM. Reason: Added name of thread by Luxblue
Old 03-21-2011, 08:26 AM   #21
dodored
Alliance Member
dodored's Avatar
If the truck is cheap enough why not buy it? You can always find another stock frame, build it the way you want, and swap the body out. I have a fat man MII under mine, but I would have preferred a chevelle clip that I had on the previous truck. Camaro is too wide for the F100 and you have to fix it will wheel offset.
__________________
"I told my dad I stopped raising hell and he called me a quitter!"
~~ Rodney Dangerfield
coolbreezesurf.com / Buy Sell Trade Surfboards
Old 03-21-2011, 08:33 AM   #22
Paul Y
Paul Y's Avatar
Have a look at Lux's 'How to guide'
http://www.jalopyjournal.com/forum/s...d.php?t=148978
I used this to redo the butchered clip on my 56, great advice and easy to follow.
P.
__________________
Oh, Cock.
Old 03-21-2011, 08:44 AM   #23
octobeak
Grenade Inspector
octobeak's Avatar
I bought a 46 ford with a 1971 f-body subframe butted up against the ford frame with a funky looking graft. I ended up cutting it all out and placing new rails beneath the subframe and running it back behind the cab. This lowered the cab about 6".
Name:	3 stock frame front.jpg
ID:	1274153   Click image for larger version
Name:	11 reinforcement bracing front.jpg
__________________
*something clever
http://www.jalopyjournal.com/forum/s...d.php?t=538122-1946 Ford truck build
Old 03-21-2011, 08:47 AM   #24
octobeak
Grenade Inspector
octobeak's Avatar
oh yeah, you can get shortened control arms for the camaro clip if the wheel fitment looks weird.
__________________
*something clever
Old 03-21-2011, 08:53 AM   #25
aerocolor
aerocolor's Avatar
80 Camaro clip with no issues. 17x7 w/4" backspacing wheel works perfect.
I have trucks with GM. Volare and Heidt(Mustang II) and the Gm front always drives the best.
ID:	1274156   Click image for larger version
ID:	1274157   Click image for larger version
Old 03-21-2011, 08:57 AM   #26
Sonny48
Grenade Inspector
Sonny48's Avatar
I did my 48 chevy 1/2 ton with a 75 nova subframe and it worked perfect. I made a cardboard template of the subframe and cut the original frame to match it and set the original frame on top of the sub, then boxed the inside back to the bed, and plated the out side top to bottom. The front bumper sits even with the top of a beer can. Rides good...runs straight at any speed. Just check it out and make sure it was installed correctly..and enjoy it.
Old 03-21-2011, 09:10 AM   #27
Left Turn
Left Turn's Avatar
we've got a '53 F100 in here with a 73 or so Olds 88 or 98 clip... fits pretty good... rides really nice.. has a built 455 and an olds rear that might not last after the new engine gets fired...
__________________
I built her with what I had layin' around... Didn't find no cash in that ol' barn though...
Old 03-21-2011, 09:44 AM   #28
hustlinhillbilly
Grenade Inspector
hustlinhillbilly's Avatar
Back when the magazines still had "How To" articles, instead of "Here's what to buy", I think it was Street Rodder that did a pretty good article on clipping a car.
It was essentially get the measurements of the stock wheel base, chop off the old front, hollow out the insides of the frame rails and slide the clip inside, get it positioned right and weld it up. Some splitting of the outer rail was sometimes necessary, but it didn't look too bad. You have more structural support than a butt weld, with the clip sleeved inside the old frame rails, plus it dropped the nose a bunch. Did it on my 40 Chevy and drove it for over 10 years with no problems.
Old 03-21-2011, 11:09 AM   #29
Carbs & Chrome
Old School HAMBer
Quote:
I meant they way the OP was done. I always liked your truck.
Old 03-21-2011, 12:39 PM   #30
Ranunculous
Senior Member
Ranunculous's Avatar
chillywilly is right.Be sure to check how far up into the curve of the sub rails you're cutting!
You can always lower em but raising a front end is a bear! I swapped coils and am in the process of looking for a 29" front runner tire to bring the snoot of mine up a bit.
Road grading ain't fun...
Camaro/Nova sub swaps were all the rage back in the late 80's when we swapped mine on,now NAPA and the parts houses call them antique cars? Buy extra parts when you can!
Old 03-21-2011, 12:50 PM   #31
derpr
Grenade Inspector
derpr's Avatar
I 've seen it done on a chevy truck before. we did it to get the ride height right.
Old 03-21-2011, 05:16 PM   #32
mickeyc
Alliance Member
mickeyc's Avatar
Hello fosheeze, I used a 76 firebird sub frame under a 56 f-100 many years ago. (same as camaro). I think using the entire sub frame is the best way to go. The centerlines of the ford and the subframe are the same, with the subframe being wider by a total of an inch or so this makes a very easy match up and gives good welding points to work with. I made a template of the sub frame and transfered that to the truck chassis. I found that by increasing the wheel base one inch it centered the wheels nicely in the fender. after cutting the truck chassis, to match the template I simply rolled the assembly under the truck chassis. with careful measurements and a few gussets it worked well for me. I did have to modify the fire wall because I used the stock pontiac motor and sway bar.
If you move or make your own mounts, this will not be necessary. There is plenty of room in an f-100 engine bay. Hope this helps. MickeyC
Old 03-21-2011, 07:54 PM   #33
fosheezie
Newbie
fosheezie's Avatar
thanks for all the replies fellas, i took a good look at it this morning and ended up buying the truck.. all the welds look solid, and basically what the guy did was chop the ford frame about 5 inches shy of the firewall, roll the camaro clip under it, and welded it up where the camaro clip "downslope" matches up to the ford frame, then just left the rest of he clip to make mounting the front of the running boards easier.. im not sure how many post i have to make before i can post some pictures but i will give it a go here in a minute... the truck is by no means nice in any form of the word, but i got it for a song and drove it 5 miles to my house and it rides and handles wayyy better than i imagined one of these trucks could, i know cllipping a truck isnt very popular on here for for the price that ride quality was pretty hard to beat..
and for what its worth i apprectiate all the feedback from everyone.. 31 replies in 24 hours... it used to take me 2 months to get that on steves nova site lol... pics comin soon, along with some front clip questions
Old 03-21-2011, 08:05 PM   #34
Carbs & Chrome
Old School HAMBer
Quote:
That's how I've seen it done. I pictured something different in your original post.
You can post pics right away.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
