Reply
Thread Tools Display Modes
Old 03-01-2011, 10:46 AM   #1
grits
Old School HAMBer
grits's Avatar
Default Connecting Two Batteries together
This is a question for you electical gurus, I dont have a lot of room in the trunk of my coupe for the battery and a friend suggested I use two 6 volt batteries, one on either side of the trunk and tie them together to make a 12 volt system, seems like it would still be 6 volts, am I an idiot or what?
So help me I'm just not sure.
__________________
offline   Reply With Quote
Old 03-01-2011, 10:47 AM   #2
HOTRODPRIMER
Alliance Member
HOTRODPRIMER's Avatar
Default Re: Connecting Two Batteries together
2 - 6 volt batteries is still 6 volt. HRP
__________________
Tradition without intelligence is not worth having. T.S. Eliot
'54 Ranch Wagon build photos
online   Reply With Quote
Old 03-01-2011, 10:49 AM   #3
maniac
Alliance Member
maniac's Avatar
If you wire them in series, all you will have is 6 volts.
If you can't fit a 12 volt battery how you gonna fit 2 6's, last time I looked they were around the same size.
__________________
"If you can't fix it with a hammer, it's an electrical problem".
Old 03-01-2011, 10:49 AM   #4
seventhirteen
seventhirteen's Avatar
still 6 volts and why would you do that anyways?
Old 03-01-2011, 10:50 AM   #5
flacoman
Newbie
Wire them in series ' + term to - of the other . The two remaining terminals will be 12V
Old 03-01-2011, 10:50 AM   #6
pitman
Old School HAMBer
pitman's Avatar
In series, the voltage is cumulative. In parallel its current is cumulative.
Add 'em up!
Measure w/your VOM/multimeter and it will be obvious. If you wanted to have 24 volts, buy two more batts.
Old 03-01-2011, 10:51 AM   #7
grits
Old School HAMBer
grits's Avatar
Thanks HRP, I have thought this over several times and have argued that point with him.
__________________
Old 03-01-2011, 10:55 AM   #8
Dreddybear
Old School HAMBer
Dreddybear's Avatar
I disagree..
Wire in series will produce 12 volts.
Wired Parallel will produce 6 volts with more capacity.
Ground to - battery A.
+ Battery A to - Battery B
+ Battery B 12 Volts
Old 03-01-2011, 10:55 AM   #9
seventhirteen
i stand corrected, learn something new everyday, read this, your friend is correct
Quote:
There are two basic ways to wire multiple batteries together, in "Parallel" or in "Series".
PARALLEL
Wiring two batteries which have the same output voltage in "Parallel", the output voltage of the combination stays the same but the amp/hour capacity of the combination is equal to the sum of their individual amp/hour capacities.
Wiring: Battery 1 Positive to Battery 2 Positive and Battery 1 Negative to Battery 2 Negative is Parallel wiring, retaining the voltage rating of either one of the batteries.
WARNING
It is not a good idea to wire two batteries which have different voltage ratings in parallel because the one with the higher voltage will immediately send current to the other one with the lower voltage to try to make their voltages both the same. The very high current which will flow between the two batteries is likely to make the batteries get very hot. IF THEY ARE CAR BATTERIES THEY COULD EXPLODE!
SERIES
Wiring two batteries which have the same output voltage in "Series" makes their combined output voltage equal to the sum of their individual voltages but the amp/hour capacity of the combination will be no greater than the amp/hour capacity of the smallest battery of the two.
Wiring: Bat 1 Positive to Load, and Bat 1 Negative to Bat 2 Positive, then Bat 2 Negative to the other side of the Load is Series wiring and the total voltage of the combined batteries is the sum of both individual voltage ratings.
So, assuming you want to get 24 volts out of two similar batteries, you could wire two 12 volt batteries in series.
NEVER OPERATE A 12 VOLT ELECTRICAL SYSTEM as in CARS or most BOATS with 24 VOLTS. YOU WILL BURN UP YOUR COMPONENTS AND SOME WIRING.
Common Flashlights are simple examples of series wiring. Flashlight batteries are usually 1.5 volts whether they are AAA, AA, C or D size. So flashlights with with 1 battery are operating at 1.5 volts, 2 batteries are 3 volts, 3 batteries are 4.5 volts, etc.
Read more: http://wiki.answers.com/Q/How_do_you...#ixzz1FMrelK6W
course i still wonder why you would want to do this...
Old 03-01-2011, 10:56 AM   #10
porknbeaner
Alliance Member
porknbeaner's Avatar
They make very small batteries for the street rod crowd. Get one of those. More often than not a 6V is the same size or bigger than a 12V battery anyway.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 03-01-2011, 10:56 AM   #11
pitman
Old School HAMBer
pitman's Avatar
Quote:
Originally Posted by Dreddybear View Post
I disagree..
Hold your cards...we may have a winner!
Old 03-01-2011, 10:56 AM   #12
Timbo from Mempho
FNG
Timbo from Mempho's Avatar
Optima 6 V batteries are really small, bout like 3 tall boys standing side by side. When hooked in series (Positive from batt 1 to Negative on batt 2) you will get 12 volts. When hooked parrallel (Pos to Pos and Neg to Neg) you would only get 6 volts.
Old 03-01-2011, 10:56 AM   #13
Alliance Member
Mr48chev's Avatar
Quote:
Add 'em up!
Correct he is. A lot of Cat loaders use six volt batteries wired in series to get higher voltage. Among other rigs. Wired parallel would just create a bigger 6 volt though.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 03-01-2011, 10:58 AM   #14
justford
Grenade Inspector
I think it would be 12v as that is the way golf carts are wired to make 36 or 48v
Some info here
http://wiki.answers.com/Q/How_do_you...equal_12_volts
Old 03-01-2011, 10:59 AM   #15
grits
Old School HAMBer
grits's Avatar
Quote:
That is what he is telling me.
Add 'em up!
I dont want or need 24 volts, the question is can I use two smaller 6 volt batteries wired in a fashion to get the 12 volts needed.
I thought of one smaller on each side of the trunk kinda tucked behind the quarter panels,
that would give me a little more room.
__________________
Old 03-01-2011, 10:59 AM   #16
Dreddybear
Old School HAMBer
Dreddybear's Avatar
I meant I disagree with the other couple guys
Old 03-01-2011, 11:02 AM   #17
35desoto
35desoto's Avatar
If you join the positive terminal of one battery to the negative terminal of the second battery the two remaining terminals will give you a 12 volt system. Thats not a silly idea if room is your problem.
__________________
Are we there yet?
Old 03-01-2011, 11:03 AM   #18
maniac
Alliance Member
maniac's Avatar
Mostly to get higher amperage, My KW has 4-12 volt batts, 12 volt starter, originally came with 3, I aded one for the amps here for the cold weather.
__________________
Old 03-01-2011, 11:05 AM   #19
belyea_david
Grenade Inspector
It should work just fine - Remember for 12V from 2 x 6V to connect the '+' terminal from battery 1 to the '-' terminal from battery 2 with the largest gauge wire you can locate. I would suggest 0 (zero) or 0/0 gauge wire with soldered terminals.
The '-' terminal from Battery 1 will be '-' ground and the '+' terminal from battery two will be your normal '+' battery terminal.
It will be tough to jump start if needed, but it should work fine.
Old 03-01-2011, 11:06 AM   #20
westex_rat
FNG
westex_rat's Avatar
I say do it, and take a picture. sounds very practical
Old 03-01-2011, 11:09 AM   #21
grits
Old School HAMBer
grits's Avatar
Quote:
BINGO!
Thanks for all the quick replies, you guys are great.
__________________
Old 03-01-2011, 11:12 AM   #22
theHIGHLANDER
Old School HAMBer
theHIGHLANDER's Avatar
It all sounds like re-inventing the wheel to me. Extra wire, extra battery, 2 mounts, double the related electrical hardware, vs finding a heavy duty small battery. I won't bother to repeat how to get 12 from 6...
__________________
"There can be only one..."
www.singlefingerspeedshop.com
Old 03-01-2011, 11:12 AM   #23
seventhirteen
makes sense now, like i said learn something new everyday
Old 03-01-2011, 11:18 AM   #24
Marshall Metal Shaping
Grenade Inspector
Marshall Metal Shaping's Avatar
Have a look at Odessey batteries....they are a dry cell. I put one in my smallblock powered A with a high torque starter. A p680 I believe, works great!
__________________
Automatic?,That's gotta be your momma's car!
Old 03-01-2011, 11:19 AM   #25
1950ChevySuburban
1950ChevySuburban's Avatar
Let me throw this out there.......
When I worked in the RV industry, most RVs had room for two 6-volt batteries next to each other for the coach side (Not the engine starter). It's a known fact that two 6-volt batteries at 800cca each in series will outperform two 12-volt batteries at 800cca each in parallel.
__________________
My '29 Sedan build thread can be viewed here:
/showthread.php?t=635145
Old 03-01-2011, 11:33 AM   #26
1950coronet600hp
Senior Member
1950coronet600hp's Avatar
yeah 2 6v in series will give you 12v with no bump in amp supply.. now.. unless you run an optima most of those series 1 batts will only supply 450cca.. that isnt much.. what are ya cranking over? also you might want to think about an optima or some other sealed battery, the reason for this is you can mount em in any posistion you like.. might be able to mount it sideways somewhere and make a 12v battery fit.. all this reminds me of my friends time on the R+D team at vector, there wasn't enough room for an adequate size battery at the time to crank that high compression v8. so Jerry's thought was to get one of those batteries at the time that had a lever on top you could flip for a little extra amps, and one of my friends jobs was to make a cable pull system so you could do this from the dash. ahh vectors.. but thats a story for a different board...
__________________
No trees were killed to send this note but a large number of electrons were terribly inconvenienced
Old 03-01-2011, 11:48 AM   #27
Dale Fairfax
Old School HAMBer
Have you priced a 6 volt battery lately? It's a damned expensive way to get 12 volts. And I'm sure you can find a 12 v. battery that's near the same size as a 6 v.
Old 03-01-2011, 11:57 AM   #28
Da Tinman
Alliance Member
Da Tinman's Avatar
I helped a guy do a 12 volt conversion, he used a 6 volt under the hood so it looked stock and another 6 volt in the trunk, wired in series to get the 12 volts.
if you really want to confuse yourself you can wire them in series/parrallel and get 12 volts and twice the amperage.
__________________
"They just pissed off the angriest guy in Wayland!" From the lovable Dumb Whore.
http://datinmanspeaks.blogspot.com/
Old 03-01-2011, 12:02 PM   #29
Vimtage Iron
Grenade Inspector
Yes you can wire two 6 volt batterys and make 12 volts, but you need to run large cable from one battery to the other and up to the starter, and that starts to get pricey, minuim 2 ought cable for batt to batt and should do the same up to the starter.
Group 31 12 volt batterys get you about 850 to 900 cranking amps they cost about $113.00 the large 6 volts run 900 to 1000 amps but they run about 100.00 also.
Old 03-01-2011, 12:02 PM   #30
davidbistolas
Alliance Member
davidbistolas's Avatar
Quote:
Agree - 2 x 6 = 12. But 2 6 Volt batteries is NOT equal to one 12 volt battery. The cranking amps is not the same.
Old 03-01-2011, 12:04 PM   #31
Gahrajmahal
Grenade Inspector
Gahrajmahal's Avatar
The 1970 MGB I recently acquired has two small wells just behind the seats for two six volt batteries and a 12 volt system. I suppose back then 12 volt batteries couldn't be that small. It now has a single 12 volt that fits in a single well. It is 7 years old I am told, and still cranks it over just fine.
Old 03-01-2011, 12:06 PM   #32
grits
Old School HAMBer
grits's Avatar
I realize the cost envolved with the 2 batteries, it was just thinking in and out of the box to use the space I have the best way possible, honestly, the only thing that I would ever use the trunk for is just a small tool pack or something like that, but thanks for all the input, I really appreciate it.
That's what to me is the best about this place, ask a question and within minutes you have all the answers you need.
Have a great day everyone.
Vival La H.A.M.B.
__________________
Old 03-01-2011, 12:06 PM   #33
53sled
Old School HAMBer
53sled's Avatar
Beats me.
__________________
If only the good die young. I'll be here when you're gone.
Old 03-01-2011, 12:11 PM   #34
George/Maine
George/Maine's Avatar
Oh let add to the bull.Back in the day when 12 volts was un heard of,when a 6 volt car didn,t turn over fast enought you could take 2 6s in series get it going that way.The way batterys are made they are joined together + -+- , so +-+- is 12 volts
Old 03-01-2011, 12:12 PM   #35
Pete1930
Grenade Inspector
Pete1930's Avatar
MG used (2) 6-volt batteries in the MGB up to, I think, 1974. Car was still 12V negative ground.
Pete
__________________
If it's too old, you're too loud.
1930 Model A flathead coupe.
Old 03-01-2011, 12:14 PM   #36
junk yard kid
Senior Member
junk yard kid's Avatar
This is very common in motor homes. You have to make sure the batteries are the same size, quality, age, rating, and charge otherwise one will drain into the other one and eventually they will just both go dead.
__________________
Just cause you can, doesnt mean you should
Old 03-01-2011, 12:21 PM   #37
shoprat
shoprat's Avatar
Did it a boat. Worked great. We sure get a lot of folks answering questions
on here that don't know the answers
__________________
A Ranchero is not an El Camino!
Old 03-01-2011, 12:35 PM   #38
zibo
Senior Member
zibo's Avatar
If you put batteries in a long flashlight,
they all go in + to -,
and only use the first and last +/- contacts
which basically adds up all the voltage.
Old Morgans used 2 6-volt batteries to make up 12 volts.
TP
Old 03-01-2011, 12:37 PM   #39
zibo
Senior Member
zibo's Avatar
Oh yeah,
I'm running a 6volt system,
and just have an extra battery in case the generator dies.
However,
I can double them up to 12v in the future.
TP
Old 03-01-2011, 12:40 PM   #40
smiffy6four
Grenade Inspector
smiffy6four's Avatar
Sorry dude, but 2x 6 volts in series =12v
If they were connected in parallel, then you would have 6v.
Old 03-01-2011, 12:41 PM   #41
CGkidd
Alliance Member
CGkidd's Avatar
A saying I learned from a crusty Senior Chief electrician when I first got out of EM school in the CG. Save Pay = Series adds voltage and Parallel adds amps I am actually going to go with the same set up of two 6volt optima's under the bed of my project in series.
__________________
Long Live Rocketeers.... COFFINS HOT ROD GANG
Old 03-01-2011, 12:47 PM   #42
amodel25
Grenade Inspector
amodel25's Avatar
MGA's from the late 50's came that way from the factory (space reasons behind the seat). Two 6 volts wired in series = 12 volts.
Old 03-01-2011, 01:00 PM   #43
nolly
Grenade Inspector
nolly's Avatar
Here's George Poteets 32 Delivery with 2-6v batteries!
__________________
Those who do not want to imitate anything,produce nothing!!-Salvador Dali
Old 03-01-2011, 01:13 PM   #44
Dale Fairfax
Old School HAMBer
One thing not touched on here(maybe irrelevant) is the old "Orpin" switch sold by J.C Whitney, It was a system that (when wired correctly) connected two 6 volt batteries in series for cranking (switch was energized by starter button) but reverted to parallel as soon as you released the starter button. Crank with 12-run on 6. Had one in my F-100 for years.
Old 03-01-2011, 08:14 PM   #45
terrarodder
Senior Member
terrarodder's Avatar
Did this back in the 50s, my budy had a 40 Ford with a hemi that started hard. Hooked two 6 volt battrys in series to starter, one 6 V. to the lights the the other one for ign., a wire from the gen. to each of them to keep the charge up.
Old 03-01-2011, 08:50 PM   #46
Jeff J
Alliance Member
Jeff J's Avatar
I've ran those in 6 of my 32 roadster's that I've built . Put them on there side in the trunk area between the outside metal and the lid above the tank then covererd with a panel . to hide them . Used the Gel Batterys red top ones !
__________________
If it's not HAMERD then it's to high!!
Now I have a Mercury body again! Ready to Chop ! Turn right no the other Right !!!!
www.jjsrods.com
Old 01-17-2012, 03:48 PM   #47
40FordGuy
Old School HAMBer
Using 2 6v batteries was the way GM built some early 50's 12 volt Cadillacs...They had a long, narrow 6 volt battery in each front fenderwell, just ahead of the firewall. Yes, a real PIA to get to ! Two of our customers had them.
4TTRUK
Old 01-17-2012, 04:05 PM   #48
Mike51Merc
Senior Member
Mike51Merc's Avatar
You know those caps on the top of batterys where we used to put water in? Well each of those caps represents a battery that puts out about 2.2 volts and they're all internally connected (in series) inside the case.
Three caps = 6 volt battery
Four caps = 8 volt battery
Six caps = 12 volt battery
and so on.
You can add batteries in series to add up the voltages, or you can add them in parallel to add up the current (amps).
Old 01-17-2012, 04:10 PM   #49
R Pope
Old School HAMBer
Dang, Mike, ya beat me to that one!
Old 01-17-2012, 04:15 PM   #50
Willy301
Senior Member
Willy301's Avatar
Add 'em up!
They cannot both be cumulative. In series, (+) of one hooked to (-) of the other is cumulative. (+) to (+) and (-) to (-) remains 6 volts but gives more amperage.
__________________
Fire Fighters find them Hot and leave 'em Wet
NSMC Life member
www.smallscalecreations.org
Old 01-17-2012, 04:27 PM   #51
aaggie
Alliance Member
A little off topic but the 1960 MGA I used to have had two 6 volt batteries from the factory. There was a battery box in the floor behind the seats with one battery in each and the connecting cables run under the carpet to connect them.
The Brits had a unique take on all things electrical.
Old 01-17-2012, 04:42 PM   #52
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Quote:
More amperage and cumulative current are the same thing, aren't they? That's what he said.
See post #42 above......
Old 01-17-2012, 04:42 PM   #53
Atwater Mike
Old School HAMBer
Quote:
Back in the day...Love that one. My son's 1925 Dodge Bros. Coupe came from the Dodge factory with 12 volts!
12 volt systems have been around since before then. Do a google search.
__________________
Mike in Atwater
Old 01-17-2012, 04:47 PM   #54
Atwater Mike
Old School HAMBer
Quote:
Not irrelevant at all, just a great post script. With that switch, you could get a 12 volt hot start and when switched back to parallel you charged both batteries with a 6 volt generator!
Nice addition, Dale.
__________________
Mike in Atwater
Old 01-17-2012, 05:15 PM   #55
davey
Newbie
My motor home has 2, count them 2, 6 volt batteries wired positive to negative making `12 volts to the house
Old 01-17-2012, 06:12 PM   #56
Carl La Fong
Senior Member
Carl La Fong's Avatar
Quote:
4TTRUK
No. Early 50s Cads were 6 volt and used one BCI Group 2, long skinny, battery
Old 01-17-2012, 08:55 PM   #57
rainhater1
Three pages to say the same thing?
Old 01-17-2012, 09:02 PM   #58
woodypecker
Grenade Inspector
woodypecker's Avatar
If you need a cheap small battery that will work get one of those cheap jump start battery packs take it apart and there is one of those expensive glass mat batteries inside.
Old 01-18-2012, 08:21 AM   #59
djust
djust's Avatar
I think I am going to go that same route Grits.
I want to put 2 6 volt batteries in series under my sedan to get more clearance, the 12 volt one I have now is just to big.
Hell I'v got close to a 1000 batteries that I take care of and have several strings of 40 12 volt batteries wired in series to make up 480 volts and some strings that have 60 8 volt batteries to make 480 volts and one that has 80 6 volt batteries that make up 480 volts but the beauty of the optimas is that when laid on there side like pics above there is a ton of room saved.
Not a lot of room in an A to start with.
Old 01-18-2012, 08:44 AM   #60
sunbeam
Senior Member
sunbeam's Avatar
One advantage of 2 sixes in series if you have a car that was 6v to start with you can tap into the cable between the 2 and run the 6v accessories.
Old 01-18-2012, 08:46 AM   #61
stealthcruiser
Old School HAMBer
stealthcruiser's Avatar
I like batteries.........................
__________________
Chuck
Old 01-18-2012, 09:15 AM   #62
djust
djust's Avatar
Heres some batteries for ya 8 volt 750 pounds, $1000.00 each.
Just noticed this thread is almost a year old.
Click image for larger version
ID:	1539791   Click image for larger version
Old 01-18-2012, 12:51 PM   #63
mrconcdid
Senior Member
mrconcdid's Avatar
yes 2 - 6 volts wired in series will give you 12 volts the problem is you have a 12 volt charging system . You cant charge batteries in series only in parrell.
MrC.
__________________
Check out my Artwork!
http://www.etsy.com/shop/DesignsbyLA..._shop_redirect
Old 01-18-2012, 01:10 PM   #64
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Quote:
MrC.
If the two 6-volt batteries are the same A/H rating, and in the same condition (not one new and one 10 years old) you can charge them in series.
Old 01-18-2012, 03:52 PM   #65
djust
djust's Avatar
MrC.
We do it everyday 24 7
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
