Reply
Thread Tools Display Modes
Old 01-29-2010, 01:24 PM   #1
D Reed
Alliance Member
D Reed's Avatar
Default '32 Ford pictures
Does anyone have any pictures of a stock '32 Ford 3 window seat showing the curved side wood supports?
offline   Reply With Quote
Old 01-29-2010, 03:18 PM   #2
Deuce Roadster
Deuce Roadster's Avatar
Default Re: '32 Ford pictures
The above photos are of my 32 3W. The ones below are of someone else's 3W.
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 01-29-2010, 03:31 PM   #3
Deuce Roadster
Here are the specs for the bottom seat pan.
the following measurements from an original 32 3-window seat pan: front overall width = 37"; rear overall width = 39 7/8"; front to back overall length = about 22"; side-to-side distance between bolt holes for the two pan-mounted seat tracks = 31". .
When the back board on mine was redone ... cabinet grade birch plywood was used. The entire back panel was made to be the same size but just one board, not a series of 7 pieces made into one back rest. I believe my version is stronger and was easier to duplicate.
__________________
Old 01-29-2010, 06:17 PM   #4
D Reed
Alliance Member
D Reed's Avatar
Thanks for the reply and great pictures. Did you happen to save the patterns?
Old 01-29-2010, 10:19 PM   #5
Deuce Roadster
Quote:
I actually made the patterns OFF mine for a HAMBer ... I mailed them to him at least ... 2 or 3 years ago
My interior is finished now ...
... I could TRY and another trace a set ... for you if that would help.
__________________
Old 01-31-2010, 06:11 PM   #6
D Reed
Alliance Member
D Reed's Avatar
Thanks for the offer but I'll take care of making a pattern. Very nice job on that beautiful coupe.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
