Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 11-20-2009, 06:57 PM   #1
cgascompression
Alliance Member
cgascompression's Avatar
Default hemi casting numbers..need help identifing
This should be a 354. bores a little under 4".
havent put a set of mics on it yet.
block casting# 1819829-6
head casting # 1733463-1
intake casting# 1537726
con rod # DF 40MS3049XO
Need yalls help identifing.
What is the most yall have bored these blocks.
New to the hemi scene guys. Yall will get tired of the questions. haha
Click image for larger version
ID:	820900   Click image for larger version
ID:	820901   Click image for larger version
ID:	820903   Click image for larger version
ID:	820904   Click image for larger version
offline   Reply With Quote
Old 11-20-2009, 07:12 PM   #2
Skirv
Alliance Member
Skirv's Avatar
Default Re: hemi casting numbers..need help identifing
Are you sure that 1819829 number is not actually 1619829? 1619829 should be a 354 block from a Dodge truck. I don't shoe the 181 number listed. Post the STAMPED, not cast number at the top front center of the block, right in front of the valley pan.
Old 11-20-2009, 07:20 PM   #3
Skirv
Alliance Member
Skirv's Avatar
1733463 = 354 Dodge truck cylinder head
1537726 = 2bbl intake, truck manifold
That connecting rod part number doesn't seem right.
Old 11-20-2009, 07:49 PM   #4
cgascompression
Alliance Member
could be a six. casting number pretty rough. i'll check in the am on the stamped one. How bout bore size and how much can they be. I'm gona have to go .060
Old 11-20-2009, 08:07 PM   #5
checkedgoldtop
Grenade Inspector
checkedgoldtop's Avatar
That is a truck or industrial block, the "heat riser" passage on the intake is taller than the intake ports. I'm pretty sure the heat riser passage is actually for coolant in industrial marine and truck motors. Also, the water pump housing is different in passenger blocks. The local hemi guru I get stuff off of told me that those W blocks are even better than A-1's. As for overboring, I know a guy that went 110 over in a truck block. I wouldn't suggest it but there's a lot of meat in those cylinder walls. I couldn't tell ya 354 or 331 though. Good luck.
Old 11-20-2009, 08:15 PM   #6
silent rick
Alliance Member
did you get the exhaust manifolds?
__________________
selfish disgusting anti-social bad influence friend of the devil seeks an intelligent young hard belly with large breasts to dance naked for my amusement.
must ride on fender.
Old 11-20-2009, 08:41 PM   #7
George
Old School HAMBer
George's Avatar
"Ws are better than A1s" All the foundrys had the same specs.
__________________
Confucious say Tennis elbow better than Tennis balls
Old 11-20-2009, 09:23 PM   #8
cgascompression
Alliance Member
no, exhaust manifolds. Will be running lake headers
Old 11-20-2009, 09:29 PM   #9
silent rick
Alliance Member
all the truck motors seem to be missing the exhaust manifolds. they bring good money on ebay.
__________________
Old 11-20-2009, 09:58 PM   #10
krooser
Old School HAMBer
krooser's Avatar
Here's damn near everything you need to know about the early Hemi....
http://www.jalopyjournal.com/forum/s...d.php?t=118764
Bookmark it for future refererence.
That IS a truck motor... the short block will be good to use as-is with a rebuild. the heads, as mentioned before, are equipped witha "tall" heatriser which will have to blocked off or welded shut to use with any other intake manifold... but it's been done many times.
Keep your eyes and mind open when building a Hemi... you DON'T need every fancy pice of billet bling and accessory to build one... you'll save lots of $$$, too.
__________________
www.rumblefest.net
www.facebook.com\rumblefestshow
www.facebook.com\amherstspeedway
Old 11-22-2009, 12:36 PM   #11
checkedgoldtop
Grenade Inspector
Quote:
Relax man, this is just what has been passed down guy to guy since the 50's. Some blocks supposedly had a higher nickel content. I don't really care, I don't plan on running nitro.
Old 11-22-2009, 12:43 PM   #12
checkedgoldtop
Grenade Inspector
Those non-script valve covers are rare pieces, they only came on power giant truck motors.
Old 11-22-2009, 12:58 PM   #13
George
Old School HAMBer
George's Avatar
Quote:
always heard it the other way & the "they're all the same" responce posted.
without core shift you should be able to go 4" bore. If you use std bore 392 pistons you'll get 1 point lower compression that what the box says. What is the use code, should be on a flat in front of valley cover. There are blocks with 354 casting #s, but bored to 331 instead.
__________________
Old 11-22-2009, 09:37 PM   #14
cgascompression
Alliance Member
Block stamped with L8-D-8 1213. Is there any after market intake manifolds for this truck engine
Old 11-22-2009, 09:46 PM   #15
George
Old School HAMBer
George's Avatar
Quote:
354 You can use the '54 4 bl intake, or you have to drill between the front & next runners & put in fittings for a remote thermostat on a dry intake.
__________________
Old 11-23-2009, 07:56 AM   #16
345 DeSoto
Senior Member
345 DeSoto's Avatar
Location: Summer Skaneateles,NY/Winter Port St.Lucie, FL
What KROOSER said...
Old 11-23-2009, 07:07 PM   #17
checkedgoldtop
Grenade Inspector
Good call, I agree.
Old 11-23-2009, 08:08 PM   #18
73RR
Old School HAMBer
73RR's Avatar
The L8D8 is in the ID chart in HemiTech...
All (Chrysler) truck engines have the pattern drilled in the front of the block that is the same as the 51-54 pass car water pump/t-chain housing pattern. All (Chrysler) truck engine intake manifolds, (and all 51-54 pass cars) have a t-stat. All (Chrysler) truck engine intakes have the tall water port at the centre.
Although possible, it is a major job to redrill the block. It would be cheaper to pay the usual $400 for a 54 4-bbl intake. You can shrink the centre port or switch to 54 pass heads. The truck head is servicable as is or you can install pass car guides and valves.
Pass car manifolds, 55-58, can be used but as George said you will then need a remote t-stat. I have yet to see one that looks good....
If you shop around, you might find one of the oem 2x1 or 2x2 intakes that were used on the trucks. There was a 2x1 and a 4-bbl manifold on ebay yesterday...
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 11-23-2009, 08:38 PM   #19
George
Old School HAMBer
George's Avatar
1 of mine is a '55 block with 55 timing cover pattern. solid front heads with fat valve stems & rotators & the square crossover. The intake was a wet 2X1 with a '57 cast date.
__________________
Old 11-23-2009, 08:54 PM   #20
73RR
Old School HAMBer
73RR's Avatar
Thats gotta be the oddest package yet. What water pump was used over the tin cover?
Never say 'never' with MotherMopar.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
