Reply
Thread Tools Display Modes
Old 09-01-2008, 07:23 PM   #1
n1gzd
Grenade Inspector
n1gzd's Avatar
Default help identifying mopar flathead 6 in my 1936 Plymouth
It appears that the serial number is stamped on the left side of the block (toward the front on the side of the engine on the left side).
The number appears to read:
T3IO-25305
It is clearly a Mopar flathead 6. However, I would like to figure out exactly which one.
Is it possible that I read the number wrong. I looked at it several times.
There is also a raised "D" on the top of the head.
On the left side towards the rear of the engine there are raised numbers that appear to read: 1326306-4
It appears that the intake manifold casting number is: 651259-6
Does anyone have any info?
Rebecca
offline   Reply With Quote
Old 09-01-2008, 08:11 PM   #2
gwhite
Alliance Member
gwhite's Avatar
Default Re: help identifying mopar flathead 6 in my 1936 Plymouth
Rebecca,
Sounds like you have a mid-50's Dodge truck engine;
T-Truck
3I0 (310) - 1951-1953 Dodge Truck (230 cu in.) (Ply/Dodge 23" 'small block')
Generally speaking, 132xxxx part/casting #'s correspond to 1951-1954 production.
Intake casting # matches 1936-1938 production range...probably stock for your car.
"D" on the head indicates that it's a dodge...if you can give me the casting # I can date it for you.
My 50 Plymouth has a '47 218 motor with the stock '50 intake manifold. Seems that intakes varied somewhat from the 30's to the late 50's, so swapping the 'long block' while retaining the stock intake/exhaust was quite common. Perhaps the donor intake wouldn't fit this application, thus the use of the early intake. Aftermarket intakes seem to follow this general trend...my early Edmunds 2x2 will not clear my firewall, while later Edmunds intakes fit without any trouble...
Hope this helps!
Old 09-01-2008, 08:12 PM   #3
n1gzd
Grenade Inspector
n1gzd's Avatar
Are you talking about the casting number that I gave above: 1326306-4?
Rebecca
Old 09-01-2008, 08:19 PM   #4
n1gzd
Grenade Inspector
n1gzd's Avatar
My carburetor is BBR-1. Is that the part number. I also think that it says 6-293.
Rebecca
Old 09-01-2008, 08:20 PM   #5
gwhite
Alliance Member
gwhite's Avatar
Quote:
Rebecca
Yes, your engine serial # (T3I0xxxxx) breaks down to 1951-1953 Dodge Truck; casting or part numbers in the 132xxxx range correspond to 1951-1954 production, so, generally speaking, any casting/part # in the 132xxxx range dates from 1951-1954 (might be a handy way to id other parts for future reference).
Old 09-01-2008, 08:26 PM   #6
n1gzd
Grenade Inspector
n1gzd's Avatar
I guess I need to get a 50's Dodge truck manual so I can get the specifications and other engine data. I have not checked the casting number on the rear end yet. I was told that it was a 41 plymouth rear end but I have seen no proof yet.
Rebecca
Old 09-01-2008, 08:30 PM   #7
gwhite
Alliance Member
gwhite's Avatar
What specs do you need?
Also, check the id plate on the side of your distributor...would be interesting to see if they used the stock one or if they swapped that out too.
Old 09-01-2008, 08:38 PM   #8
n1gzd
Grenade Inspector
n1gzd's Avatar
Valve clearances, hot/cold, and other tuneup specs (probably the same as the stock engine but I should find out), ignition timing, etc.
I have been looking at this web page:
http://townwagon.com/pgpws/pgengines/230fh.htm
It seems that I should check to see if my block is 23" or 25" just to be sure.
Rebecca
Old 09-01-2008, 08:41 PM   #9
n1gzd
Grenade Inspector
n1gzd's Avatar
I drove this car on the street for the first time this weekend. It was really fun. I could really feel the low rpm torque. Very fun to drive even in it's stock configuration.
Rebecca
Old 09-01-2008, 08:44 PM   #10
gwhite
Alliance Member
gwhite's Avatar
It's a 23" block. Same as all US production dodge/plymouth flatheads.
Old 09-01-2008, 08:51 PM   #11
n1gzd
Grenade Inspector
n1gzd's Avatar
Thanks for the info. I will post any further questions related to this thread. I am very impressed how quickly I could get intelligent answers. The HAMB rocks!!
Thanks again.
Rebecca
Old 09-01-2008, 08:53 PM   #12
gwhite
Alliance Member
gwhite's Avatar
The HAMB rocks!!
indeed!
Old 10-03-2008, 07:38 PM   #13
PurplePearl50
PurplePearl50's Avatar
I have a 59 dodge pickup d100
On the serial pad P26*I9887*
The date is 9-28-55
on flat plate on head it has a large P then 616823-5
on the rear of the block at the bottom on the left side 48492-32
Is that a 55 Plymouth 230?
did they put those in pickup trucks in 59?
__________________
-Dane
Tire Irons CC
Sedalia,Mo
Old 10-04-2008, 01:49 AM   #14
FinnishFireball
Grenade Inspector
FinnishFireball's Avatar
P26 is 230cid from '55 correct
__________________
- Life is a bitch and then you marry one -
Old 10-04-2008, 09:38 AM   #15
Old School HAMBer
squirrel's Avatar
No, but junkyards have been selling used engines for a very long time, and people have been putting whatever engine they can find in whatever vehicle they have for a very long time.
__________________
Jim Forbes
my shtuff
Old 10-04-2008, 10:07 AM   #16
Topolino Kid
Senior Member
Topolino Kid's Avatar
i have a p23 i just recently picked up...still looking to find a cheap ( yeah i know!!) bell housing to try and get it fired up...it rolls over fine, was a runner when pulled, guy is my best freinds b/inlaw...so i trust him...been wondering how well they run with daul carbs and split headers..........
Old 10-04-2008, 02:48 PM   #17
FinnishFireball
Grenade Inspector
Well, they run like marbel, they are Mopars afterall... Seriously that flatty is quite surprising engine, doesn't look that stout on paper, but it really gets your stuff moving with ease.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
