Reply
Thread Tools Display Modes
Old 09-16-2007, 09:48 AM   #1
falconwagon62
Alliance Member
falconwagon62's Avatar
Default How to unlock a locked up motor? FLATHEAD
Ok guys, I am going to keep my flathead in my 59 Rambler, Super Station Wagon (maybe) the motor is locked up...prior owner said it used to spin over, now nothing, whats the best way to free it up? I don't want to bust a ring. Tranny Fluid in the Cly's? Blaster, what worked for you??
online   Reply With Quote
Old 09-16-2007, 09:57 AM   #2
Flatman
Senior Member
Flatman's Avatar
Default Re: How to unlock a locked up motor? FLATHEAD
Pull the plugs and drizzle in some Marvel Mystery Oil. Walk away and let it soak everything good. After a couple of days, try bumping over the engine with a johnson bar on the crank a little bit at a time. If you get a bit of motion, work it back and fourth as it frees up. Don't force it too much, patience is the key.
Flatman
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
offline   Reply With Quote
Old 09-16-2007, 10:03 AM   #3
foolthrottle
foolthrottle's Avatar
fill the cylinders with transmission fluid and let set for a day or two, then put a wrench or socket on the front balancer and gently tap back and forth untill its free. It dosen't take much rust to stick an engine. were they still useing a flat head in 59? I would think it was an old 258 inline ohv?
Old 09-16-2007, 10:14 AM   #4
Paul Windshield
Grenade Inspector
Paul Windshield's Avatar
If it's a stick after soaking put it in second and rock back and forth.
Paul
Old 09-16-2007, 10:56 AM   #5
falconwagon62
Alliance Member
Thanks, and YES AMC used a Flatty into the 60's! now we know why they are no longer around Lead the pack or be left behind! or be bought out by MOpar.....Thanks guys.....John
Old 09-16-2007, 11:31 AM   #6
Scarebird
Alliance Vendor
Scarebird's Avatar
Get a can of Kano Labs "AeroKroil". I do not go to the boneyard without a can of this stuff, make 3n1 oil look lame.
__________________
http://www.scarebird.com
'Hey Fox, that woke 'em up"
"I say we give them another shot"
Old 09-16-2007, 11:41 AM   #7
budd
Old School HAMBer
budd's Avatar
i use combustion chamber cleaner.
Old 09-16-2007, 11:59 AM   #8
Boynamedsue
Grenade Inspector
tranny fluid seems to work the best, it has better detergants in it.
__________________
When I gun my engine, I want the whole world to think its coming to an end.
Old 09-16-2007, 12:42 PM   #9
falconwagon62
Alliance Member
just filled it with Tranny fluid! now WAIT....
Old 09-16-2007, 06:50 PM   #10
falconwagon62
Alliance Member
pulled the head tonight, insides NASTY.....still can't flip it over, guess I got to let it sit, DAM I hate to wait!!!!!!!!!!
Old 09-16-2007, 06:54 PM   #11
GlenC
GlenC's Avatar
I remember using kerosene to unstick a T truck engine in the 60's. Just kept filling the cylinder heads and letting it run through into the sump for a week, then drained the sump, oiled her up and she fired!
Cheers, Glen.
Old 09-16-2007, 09:09 PM   #12
overkillphil
Grenade Inspector
overkillphil's Avatar
Quote:
Kroil is the best penetrant on earth! I practically soaked my 'stude flattie in it, and had no problems breaking anything free. Plus, it kinda smells like hopp's nitro solvent!
__________________
Drive it like you STOLE IT!
Old 09-16-2007, 09:49 PM   #13
Don Lyon
Grenade Inspector
Ditto to what Scarebird and Overkillphil said. Aerokroil or plain old "Kroil" as it's known in aviation circles is the BEST unfreezing, unlocking,bustin' loose product there is. even use it in all my air tools.
Old 09-16-2007, 10:07 PM   #14
7&7
Grenade Inspector
I will agree that Kroil is the best. We take apart 100 year old steam lines with the stuff. Yea let it soak too, but for about half the time of others. I love it the next thing you know you are using the stuff on everything. Shit I have a can in the shower.
__________________
I'm just a typical hot rodder full of shit and beer..
Old 09-16-2007, 10:35 PM   #15
Mockie
Alliance Member
Mockie's Avatar
Marvel mystery oil down the plug holes worked fine for me, let her set 3 days before trying and broke loose easily after that. Motor was a 235 that had been sitting for 50 + years.
__________________
Jeremiah was a Bullfrog
Old 09-16-2007, 11:09 PM   #16
Goztrider
Old School HAMBer
Goztrider's Avatar
My uncle is a retired diesel and tractor mechanic. Whenever he buys an old tractor to fix that has a locked up motor, he'll load it on his trailer, throw a big safety chain on that he can secure loose enough so the tractor can't roll off the back of the bed, and take off down the back country roads - starting and stopping the whole way with the tractor in gear. After about a good hour or two of this, he'll often be able to get the starter to turn the motor over on its own.
__________________
Subtlety is saying what you mean, and getting out of the way before it is understood.
My '29 Dubble A build progress thread.
Old 12-08-2010, 05:48 PM   #17
ccrain
FNG
Quote:
Okay i have a 74 pinto and the motors stuck solid i have filled the spark plug holes with transmission oil if i do get the motor un stuck do i have to worry about all the tranny fluid i put in it,if so how do i get it out?Drain the oil
Old 12-08-2010, 05:51 PM   #18
adjustablejohnsons
Old School HAMBer
adjustablejohnsons's Avatar
Location: I bounce around. SouThe Villages, FL..Key West..New Orleans.
Seems like everytime someone has a stuck flathead all the advice assumes the pistons are stuck. Don't overlook the valve train.
__________________
The HAMB...teaching thousands what high school kids figured out by themselves 70 years ago.
Old 12-08-2010, 06:04 PM   #19
J'st Wandering
Alliance Member
Quote:
It doesn't matter. You can drain the oil but it will still be a pinto.
Neal
Old 12-08-2010, 06:14 PM   #20
flthd
Grenade Inspector
flthd's Avatar
Anybody messin around with rusty or seized parts should try that kroil oil that stuff works freakin awesome.Ive worked on mechanically f'd up stuff for years.
__________________
Wile E Coyote Super Genius
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
