Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#41 |
Alliance Member
#42 |
Senior Member
As far as looks to cubic inch goes the year caddy mills to find is the '59-62 390. They look identical to the earlier 331 (except they don't have the bellhousing as part of the block like the 331), and like they always say, There's no substitution for cubic inches! '59 was the last year of the canister oil filter, so if you really want it to look like a 331 but want the bigger cubes, go for the '59 mill.
__________________
"Tie him to the car and drag him" www.jazzorgy.com http://mikezenor.home.comcast.net/Primates/ |
#43 |
I love my Caddy motor, 472 out of a 73. Did you know Cadillacs have the highest nickel content of all the engines out there even the bowties don't measure up. Also you can bore and stroke a 472 to a 518 ci. and that is max tourque and a lot of horsepower to the rear wheels. I put mine into my 50 Buick and it launches that big motha' like you would not believe. It sounds bad to the bone with little glass packs on it through operational lakes pipes. Rags
#44 | |
Old School HAMBer
Quote:
I'm looking for a 59 390 now !!!
__________________
If it dont have 3 pedals it aint no HOT ROD ! If you didnt build it " Shut Up " " I'm to old to get what I want and to young to give up trying " me " www.texasnostalgianationals.com |
#45 |
Old School HAMBer
Just got mine a 331 with a 3 speed
should be pretty looking by fall |
#46 |
Grenade Inspector
I have a question for someone knowledgeable about 331 Cads. I put a 500 cube Cad in my '49 Fastback. But I have a four door parts car ('49) that has the original engine. The valve covers on that engine are held on by 2 bolts down through the center like an Oldsmobile. It appears that Cadillac made a change from this design to the four bolt valve covers like an early small block Chevy about halfway through the '49 model year. Does anyone here know why the change and if there were other changes made at the same time?
I don't know if this is the right way to ask this question, or if I should have started a new thread. Thanks Alden |
#47 |
Old School HAMBer
What a timely entry (for me anyways) Although my '51 Caddy is powered by a BBC, I just bought a '53 more-door that is was supposedly running quite recently. I haven't tried to start it yet, but it will be set aside for a later hot rod project - I've been jonesing for a little modified style roadster.
__________________
If you're gonna be dumb, you better be tough... |
#48 |
Senior Member
Swing low sweet cadillac comming to carry me home...............
thanks Ryan cool thread........................... |
#49 |
Grenade Inspector
Thanks for a great thread Ryan.
This is my 51 more-door with a 500 (now 506) from a 73 Eldo.Sure scares the little ricers around here. We also have a pair of 331s a 425 & a pair of 500s (1 for the 47 hearse) just waitin' for something to push. Al
__________________
51 Caddy 62 series 4dr sdn Earth Angel Foundation of Ohio |
#50 |
Always love the caddy engine threads. Diggin those speed parts fellas. Green with envy here. Here's mine. Need to get some more recent shots.
__________________
And that's how I got my eye patch |
#51 |
Alliance Member
I've always loved the earlier caddy engines, especially the ones used in the 58 eldorados. I thought those were really neat for some reason
__________________
"What is truly traditional is doing what you want with your own stuff without asking permission." --hotrod1940 |
#52 |
Old School HAMBer
#53 |
Grenade Inspector
What are the major differences between the 62 and 63 390's.
#54 |
Grenade Inspector
Anybody make or build a multicarb intake for 472/500 Caddys?
#55 |
Senior Member
They are completely different engines. The only thing they have in common are cubic inches, and you can put a log manifold from an earlier 390 onto the 63 engine.
#56 |
Senior Member
I love this thread. The video is awesome.
__________________
Take me drunk, I'm home. |
#57 |
Alliance Member
When I started building my A roadster in early 2002, I was working on a very limited budget. Once I realized how much it would cost to build and hop up a flathead, that was out the window. The only other early V8 choice for me was Buick, Cad, or Olds. Nailhead was cool, but hard to run trannys behind the early motors. Olds had the starter on the "wrong side". Cadillac 331 was the ticket! They run super cool, built to withstand abuse, and hop up parts are out there in every configuration.
An ad in the Recycler led me to an East LA house where a guy was building a bagged Sedan deVille that would run SBC-- (Why? I don't know! Its like people are afraid of any motor but a small block!!) Anyway, after a test drive around the block, I said- I'll take it! The next morning I got the motor and trans for $450 loaded in my truck! Thousands of Miles and tons of car events later, I'm still running it today...
#58 |
Alliance Member
You do have to give the firewall some room to retain your original Model A radiator position on the front crossmember, but it can be done-- I think the stock hood length looks best, IMO.
#59 |
Old School HAMBer
This is still a cool thread . Thanks for bringing it back up.
__________________
#60 |
Alliance Member
there is nothing better than a Cadillac 331, like the one in my 33 five window. They have nostalgia, history, power, available speed parts, fit most engine compartments, and look great dressed up.
| Thread Tools | |
| Display Modes | |
