TECH: Fitting A 31 Cowl To A 32 Frame
Discussion in 'The Hokey Ass Message Board' started by D-Russ, Jan 24, 2007.
  1. To mount my 31 A body onto my 32 frame, I had to channel the body slightly so the body's flat subrails would fit the graceful curve of the frame. Once I did this, the bottom front corner of the cowl hung down over the frame about 3/4 of an inch, and I thought it conflicted with the flowing lines of the deuce frame. Since I needed to put patch panels in the lower cowl anyway, I decided to address both issues at the same time.
    I made a simple pattern that flowed upward with the shape of the frame.
    Next, I transferred the new shape to the patch panel and made a few cuts.
    After a little welding and grinding, I had a new curved patch panel.
    I then fit the panel to the cowl and welded it in. Here you can see how much the lower body line will be moved up.
    Next, I cut off the remainder of the lower cowl and moved it up to align with the patch. You can see how the original body line is cut and bent down to line up with the new body line on the patch panel.
    A little more welding and grinding (plus a future skim coat of filler) and it's done.
    DylanHill1931 and 29EHV8 like this.
  2. abonecoupe31
    abonecoupe31
    from Michigan
    I saw this done years ago, but they usee a patch panel from a 32 Ford to get the curved section...
    29EHV8 likes this.
  3. RodLand
    RodLand
    Very good, I will use this trick on my 30 coupe when I find my Round Tuit.:eek:
  4. Kevin Lee
    Kevin Lee
    Super Moderator
    Yup, one of the first cars I really looked at up close had the same thing done with a '32 patch panel. And sodbuster, if you're reading this it is your boss' roadster I'm talking about.
  5. Mike Paul
    Mike Paul
    Did you pinch the rails? Do you have any pics of the cowl foot from the inside? Thanks.....Mike
  6. Ryan
    Ryan
    ADMINISTRATOR
    great post.
  7. Rolf
    Rolf
    Druss, looks great, love the curved part. Looks like Henry did it.
    I had to clean up my server, the pix should be back now.
  8. sololobo
    sololobo
    Love those Vicky cars. I have a neighbor with a minty 31 that makes me drool when I drive by it. Really nice work on this dandy. Rock on dude. ~sololobo~
  9. Sky Pilot
    Sky Pilot
    a real craftsman br:cool:ther !
  10. charlieb66
    charlieb66
    In the last photo, the patch panel bead appears to be somewhat wider than the door bead. How will you address this? Also, if you are working on a Coupe, the door bottoms are not straight. Replacement cowl panels are mostly crap.
