Technical 40 Ford Question
Discussion in 'The Hokey Ass Message Board' started by MercDeuceMan, Mar 19, 2014.
  1. Does anyone know much longer is a 40 Ford Sedan door is than a 40 Ford Coupe door?
  2. hotrod40coupe
    hotrod40coupe
    I believe the door off of the fordoor is the same as the coupe.
  3. verde742
    verde742
    he meant two door sedan !! Betcha ?
  4. olscrounger
    olscrounger
    don't have a sedan handy but I recall about 4"-convert door is longer than coupe also.
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Fordor doors can be used but require some modification at the top rear corners.
  6. Wanting to put the longest sedan/convert door on a coupe.
  7. okiedokie
    okiedokie
    from Ok
    6 inches longer.
  8. okiedokie
    okiedokie
    from Ok
    Seems like Sam Foose did that once, sedan doors on a coupe.
  9. 50Fraud
    50Fraud
    6" is very close. Tudor sedan doors and convertible doors are ALMOST the same length, but the Tudor is longer than the convert by .21", and both are about 6" longer than coupe or Fordor front doors.
  10. 40fordtudor
    40fordtudor
    Grinding works well---did that back in 1959 on #1.
