Welcome to the THE H.A.M.B. forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-06-2012, 05:07 PM   #1
stromberg
Grenade Inspector
stromberg's Avatar
Default 65 bird steering column wiring
I'm helping a friend re-wire his bird, but the wire harness is a gm connector at the column, I need to see a diagram for the ford side connector so we can make the two work. Any body have a link or a color picture of the ford wiring diagram? I have looked all over the web and can not find anything. Thanks.
offline   Reply With Quote
Old 10-07-2012, 08:56 AM   #2
62rebel
Senior Member
62rebel's Avatar
Default Re: 65 bird steering column wiring
Ford side: white/blue, right front turn signal. white/red, emergency flasher. green/white, left front turn signal. green/orange, left rear turn signal. green, brake light switch. orange/blue, right rear turn and brake light switch. blue, turn signal flasher. black/green, accessory. black, fuse box. brown/purple, starter solenoid (column ignition). white/red, coil (column ignition). grey, switched hot. yellow, 12v from the battery.
closest i can do with Ford wiring. hope it helps.
__________________
i hate to see her leave, but i love to watch her GO....
Old 10-08-2012, 10:01 AM   #3
stromberg
Grenade Inspector
stromberg's Avatar
Thank you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
