65 bird steering column wiring
Discussion in 'The Hokey Ass Message Board' started by stromberg, Oct 6, 2012.
  1. stromberg
    stromberg
    I'm helping a friend re-wire his bird, but the wire harness is a gm connector at the column, I need to see a diagram for the ford side connector so we can make the two work. Any body have a link or a color picture of the ford wiring diagram? I have looked all over the web and can not find anything. Thanks.
  2. 62rebel
    62rebel
    Ford side: white/blue, right front turn signal. white/red, emergency flasher. green/white, left front turn signal. green/orange, left rear turn signal. green, brake light switch. orange/blue, right rear turn and brake light switch. blue, turn signal flasher. black/green, accessory. black, fuse box. brown/purple, starter solenoid (column ignition). white/red, coil (column ignition). grey, switched hot. yellow, 12v from the battery.
    closest i can do with Ford wiring. hope it helps.
  3. stromberg
    stromberg
