Technical Zip’s riser pump question
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Nov 4, 2018.
  1. Dino 64
    Dino 64
    from Virginia
    Using a Zip’s riser on my SBC.
    Looking for advice on which pump to use.
    Should I use a high volume pump or a good quality stock replacement ?
    Thanks in advance:)
    lothiandon1940 and chryslerfan55 like this.
  2. I purchased my water pump at NAPA and it's never given me a problem. HRP
    Dino 64 likes this.
  3. Dino 64
    Dino 64
    from Virginia
    So a stock replacement is good ?
    What application is it ?
    Thanks
  4. I used the 1969 Nova 6 cylinder water pump. HRP
    lothiandon1940 and Dino 64 like this.
  5. Dino 64
    Dino 64
    from Virginia
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    As often as this question comes up. How many used risers are being resold that instructions and donor vehicles list are not supplied? Does this happen as well with new risers?
    Dino 64 likes this.
  7. perk30
    perk30
  8. Rarely have I ever seen a used riser for sale, I have a list of what a user will need and try to post when the questions are ask. HRP
    Dino 64 and Johnny Gee like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    XXL__, 56shoebox and Dino 64 like this.
  10. Dino 64
    Dino 64
    from Virginia
    Part of the problem is the instructions are poorly printed and is eligible.
    Ok I got the part numbers for the pulleys, but they are double groove and I’m just running and alternator, so will stock SBC single pulleys work too ?
    Thanks
    Fordor Ron likes this.
  11. Fordors
    Fordors
    It might be the belt and suspenders approach but I prefer to have a belt from the crank pulley to the water pump just in case I lose the alternator belt.
    XXL__, lothiandon1940 and Dino 64 like this.
  12. Dino 64
    Dino 64
    from Virginia
    Good point ! Thanks
    lothiandon1940 likes this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes. Some complain that water pump doesn't spin fast enough. In that case after market SBC short pump pulley's offer different diameters than stock. Run your stock SBC pulleys first and see what happens before swapping things. Also be sure to bleed all the air out or it will run hot.
    Dino 64, Chucky and lothiandon1940 like this.
  14. Deucedreamer
    Deucedreamer
    from BC Canada
    Speedway sells single or double groove SBC short water pump pulleys in chrome for a really decent price. That’s where I got mine from.
    Dino 64 likes this.
  15. Joe Blow
    Joe Blow
  16. Dino 64
    Dino 64
    from Virginia
    Thanks guys, I’m running a crate 350 so I don’t have any “original” parts like pulleys. I can’t find the lower pulley listed on zip’s instructions new, just used ones on eBay. I got a pump from my local Napa and the water pump pulley is touching the the pump. It’s a very cheap casting so I ordered a better on from Summit, we’ll see if that clears. Ordered an alternato, see if things line up. The pulleys I have are from Summit replacement stock pump and crank. Jason Slover at Pete&Jakes told me they should work( bought the riser from him). He’s been a tremendous help, his advice and experience is worth a few extra buck getting parts from him. IMHO
    Thanks !!
  17. Dean, I'm sure you know that Moroso (and maybe Mr. Gasket as well) make water pump pulley shims to help get your alignment right.
    lothianwilly71 and Dino 64 like this.
  18. big duece
    big duece
    from kansas
    If you get in a pinch I have a pair of pulleys that will work for you. Duplicate to what I have already mocked up on mine.
    Dino 64 and lothiandon1940 like this.
  19. eberhama
    eberhama
    BWP-386HDA from Autozone is the one recommended to me on the hamb. Its an aluminum casting with the closed back impeller. It's supposed to be the "HD" version of the water pump.
  20. Dino 64
    Dino 64
    from Virginia
    Thanks Don, want to get as close as possible before shims. Appreciate the advice
  21. Dino 64
    Dino 64
    from Virginia
    Thanks!! Very generous of you, I’ll see how they line up with the Summit pump, I may take you up on that offer, thanks again
  22. Dino 64
    Dino 64
    from Virginia
    Thanks for the info, we’ll see how the one I’m getting from Summit works out, appreciate it
  23. jbon64
    jbon64
    hey i'm using a zips riser as well . i had pulleys on my junk shelf that work fine . to answer your original question , i bought a water pump from flow cooler . they even state in their item descriptions that they are perfect for a zips riser. and looking back i see you have one coming from summit . i'll go ahead and post for future search
  24. Dino 64
    Dino 64
    from Virginia
  25. jbon64
    jbon64
  26. jbon64
    jbon64
    woops . we walked on each other ,sorry. consider my link for future searchs. i figure a high flow cant hurt . kind of a pre-emptive strike ??
  27. ..............High flow may or may not be the best approach.
  28. jbon64
    jbon64
    i'll cross that bridge when i get there.
  29. Dino 64
    Dino 64
    from Virginia
    Jason told me the high volume pumps work too well in this situation, circulating the hot water back into the engine before it has a chance to cool off in the radiator.
