Y block tri power carbs
Discussion in 'The Hokey Ass Message Board' started by oldnuts, Jun 25, 2013.
  1. oldnuts
    oldnuts
    from nebraska
    I've got a line on 3 Holley 94s. I'd like to use them on my 292 y block if they will flow enough air. Will they work fine for a 3x2 on a y block or should I wait till I can afford strombergs or use Rochester 2gs. I'm not going for power more for looks a d drivability
  2. dickster27
    dickster27
    from Texas
    The 94's will flow more than the Strombergs. And they are your best choice for your little Y block.
  3. I guess I was told the wrong info the whole time. I was told the stromberg would flow more and over all better.
  4. I ran 3 stromberg 97s on my 312 before I went with a 2x4 se up they flowed more then enough air even with the worked heads.
    The holleys will be fine in the 292, unless it is cammed up they may acually be more carb then is necessary. But once dialed in they will work just fine.
  5. choptvan
    choptvan
    Thats all I have ran on both of my tri-carb set-ups. Once dialed in, they work near perfect. NO complaints out of me.
  6. Not trying to hijack but on the tri power for my 56. Its just going to be a cruiser so I thought. Strombergs would be cool. The 6X2 for my rod not sure what carbs to run
  7. TERPU
    TERPU
    Use your 94's. They are the best for a Y-block. I ran the same thing on my 292 hooked up progressively. Block off the outer power valves and use a stiffer one in the middle carb. turn and a half on the screws seemed to be the best for mine. Ran like scalded dog and sounded great.
    All the best,
    Tim
  8. I guess ill run 94's on everything
  9. oldnuts
    oldnuts
    from nebraska
    Nice guys. Thanks for the help. Ill grab them tonight.
  10. The stock carb that came on a y block was a version of the Holley 94. An ECG-5 in 1955 and an ECG-6 in 1956.
    I was actually speaking with Dickster last night regarding the ECG-6's and he gave me an education. I'll be running three of them on my Edelbrock tri-power manifold for an Olds...the reason being that in the 1957 Edelbrock catalogue, it actually states that the manifold was designed for the Holley 94s instead of the Stromberg 97s.
    If they're good enough for Vic, I'm sure they'll be good enough for us!
  11. Wow! Well thats what ill be doing aswell. He knows what hes doing.
  12. hoop98
    hoop98
    from Texas
    The 3 Carbs will flow about 510 CFM at 3 inches of vacuum.
    That's the equivalent of a 361 CFM at the 4bbl standard of 1.5 inches.
    A 500 Holley 2 BBL flows 353 when you use the 4bbl standard.
    So it should run well but will be restricted on power.
    The 94 means .94 venturi, There are related carbs in the Holley AA seriecs which have larger venturis and flow more.
    There is an ECW (may also be a 2110) 1 1/16 Venturi, 1 3/8 butterflies, 2 1/4 choke throat - 205 cfm. ECG- 185.
    A 3 210 CFM would equal a 445 CFM 4bbl which would be about right for what you describe.
    Hoop
  13. I'm running three 94s on a 350ci Y-Block, it will rev quickly and run a 1/4 mile just under 10 sec. (see avitar) I think they work fine, even with a "big" cam. (only saw a minimal advantage with a 750 four bbl)
  14. oldnuts
    oldnuts
    from nebraska
    Any one know of a good source for rebuild kits and extended throttle shafts of the 94s?
  15. Yeah, Dickster. He posted earlier in this thread. He's got what you need.
    Posted via telegraph.
  16. 39 Ford
    39 Ford
    I can not help but wonder why no one ever uses Rochester 2CG's on Y blocks. They are from the same era and are in my opinion anyway a much better carb. Y blocks are not that different in ci. than early Chevrolets. All you would need are 3 to 4 bolt adapters or drill the manifolds.
  17. oldnuts
    oldnuts
    from nebraska
    I have 3 Rochester 2gs that I was planning on using but my offy manifold is for 3 bolt carbs. I would need the adapters to run the Rochs. I don't really like the look of the adapters. That's the only reason I decided against using them. I've heard they are great carbs.
  18. 32Tudor396
    32Tudor396
    I am not sure about 94's but I read in an old 348/409 book that although the 97's flowed less air they mixed better than rochesters and dyno proven for more power.
  19. A Rodder
    A Rodder
    They don't look as vintage, I think.
    I have 3 chromed 97's waiting to go onto my edelbrock intake for the 292 in my f100. Pretty excited about it.
  20. The 97s look better than the 94s IMO and even if they don't flow as much they do fine.
  21. A Rodder
    A Rodder
    I agree, hell, if there good enough for the y block guru I should be fine!
    To the op, do you have any pictures of your setup?
  22. oldnuts
    oldnuts
    from nebraska
    Ill post pics when I get back in town of the 3x2 setup. This is the y block out of a 64 f 100 ImageUploadedByH.A.M.B.1372359512.109273.jpg
  23. oldnuts
    oldnuts
    from nebraska
    ImageUploadedByH.A.M.B.1372359650.333887.jpg this is her with the 4 speed tranny.
  24. Following up on this, here's my proof... :)
  25. 1954fordkustom
    1954fordkustom
    Porkandbeaner how does the 2x4 perform? I have this set up that I plan on putting on my built 292.
