Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. More photos the bottom photo is the test plug valve cut to 85 percent of the finished valve size. I use these to keep the runners uniform in size and they also keep the port on center as it is ported.
    some more before and after shots 20210122_111440.jpg 20210122_111452.jpg 20210122_141713.jpg 20210122_141851.jpg 20210122_142015.jpg
    Stogy, loudbang, fegsta and 2 others like this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Polishing the combustion chambers to as close to a mirror finish as possible will add 1% - 2% power.
  3. So true thinking about ceramick heat shield coatings on the combustion chamber and the valves depends on cost.
  4. fegsta
    fegsta
    Hello John. I'm liking your work and following all what you and your team are doing. Best wishes. Tim.
    Sent from my KOB-L09 using The H.A.M.B. mobile app
    Stogy, loudbang and chryslerfan55 like this.
  5. saltflats
    saltflats
    from Missouri
    Ford sure had some rough castings finish but then again they also had some nice ones.
    Stogy and loudbang like this.
  6. Some say a rough casting in the runners help keep the fuel vaporized.
    I have seen port runners with golf ball like surfaces
    ( little divots all over them)..
    Years ago we would take a carbide bur and grind one side off and alow it to jump around in the port and it would leave a rough surface somewhat like they are doing with CNC machines doing the divots.
    We did it Old skool lol
  7. Great work day with some of the crew got lots done, pulled the mock up engine and tranny, worked some more on the rear spring height, second coat of paint on the roll cage.
    Boy does the salt rust things. I find we have to pull the whole truck down to clean up the rust. Mostly the chassis and underside of the body.. sorry no photos today as the ones I took were in the wrong format and would not download.
    Stogy, sidevalve8ba, loudbang and 2 others like this.
  8. jimmy six
    jimmy six
    Yep...... now think of your newer pickup with all its electronics and the rear door of your trailer. I had to re build a lower trailer door plate and drilled for grease fittings on the 3 hinges...just sitting on the salt for a week even when you think it’s dry the vapor it going up into everything. 2 years ago I had to replace 4” of aluminum siding around my trailer wheel openings. It was turning to Alka-Selzer and I cut out 2” extra before replacing.... no more.
  9. Been porting for a couple days now, flow bench next and then more porting 20210125_164401.jpg 20210125_164433.jpg 20210125_164440.jpg 20210125_164449.jpg
    Stogy, loudbang, D-Russ and 2 others like this.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Looks good so far.
    In addition to mirror polishing the chambers I would "skinny up" the valve guides and form a "shark fin" lead-in on the port roof .
    [I couldn't help noticing the rust on your air compressor tank. How old is it? I recently checked out some alarming air tank failures on youtube and plan to upgrade to a new air compressor myself. Mine has started to bleed down pressure overnight - a sign of internal rust-out. Stay safe.]
  11. I plan to trim down the valve guides but want to flow the head and see whats up so far.
    Trying to raise the roof of the ports and then look at the guides. I will be replacing the guides with bronze guides and taper them down on the port ends
  12. I ordered the valve and spring assembly today.
    4 to 6 weeks to get them.
    Another hold up but thats how it goes with one off parts. Cant really flow test the head without them..
    Stogy, loudbang, pprather and 2 others like this.
  13. 20210129_145637.jpg 20210129_145656.jpg Opening up the shrouded areas around the valves.
    Then a fine polishing of the chambers and exhaust ports comes next
    Stogy, saltflats, D-Russ and 5 others like this.
  14. RacingRoger
    RacingRoger
    Hi John!!!!
    I finally started flipping through my latest Ol' Skool Rodz magazine, and lo and behold, in a Bonneville Speed Week 2020 article, on page 59, this caught my eye...
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
  15. RacingRoger
    RacingRoger
  16. RacingRoger
    RacingRoger
  17. RacingRoger
    RacingRoger
    Stogy, sidevalve8ba, loudbang and 4 others like this.
  18. Looking for a copy of this issue. Can you give me a date for this issue.
    Thanks john
    Stogy, chryslerfan55 and loudbang like this.
  19. April/May 2021, issue #105
  20. Thanks Dave,
    Stogy, D-Russ and loudbang like this.
  21. Just want to recognize
    A very special friend to the XO/PP 640 BONNEVILLE
    project and team and a very special friend to me personally. Thank you Ted,
    You are an awesome and generous friend and are appreciated beyond words.
    Thank You
    Stogy, chryslerfan55, D-Russ and 2 others like this.
  22. RacingRoger
    RacingRoger
    John, if push comes to shove, you may be able to buy a copy straight from Ol' Skool Rods (Murpho Publishing). Their number is 1-877-655-6423.
  23. Thank You Randy Mooney from Lyons Falls N.Y.
    for the T Shirt purchase
    Your support is greatly appreciated
    Thanks
    Team 640
  24. loudbang and Stogy like this.
  25. Done, thanks for the link
  26. Good turnout for today's work day, the whole crew was present.
    We didn't have much to do as I'm waiting on parts again. But we did finish some small things and did a much needed shop clean up.
  27. A big shout out to Fellow H.A.M.Ber 28Phonebooth
    For supporting the Virginia H.A.M.B. Special
    With a cash donation.
    You are most appreciated.
    Thank You
    TEAM 640
  28. Finally getting some progress on the cylinder head for the truck been waiting for valve guides for 10 days now. Hope to finish it up next week. 20210312_155938.jpg 20210312_160147.jpg 20210312_162633.jpg 20210312_163433.jpg
  29. 20210125_164401.jpg 20210312_162633.jpg Before and after shots of the center exhaust ports
