I am installing a It's A Snap wire harness. So far, I guess it has been a snap, but now I have a problem and they are closed for vacation ? The indicator light for the high beams is on all the time. It has 11 volts to it when on High and 6 when on low. I unplugged one headlight to see if the wires were crossed and it was feeding back through the bulb, but it is still the same. Any ideas? Where do I look for this? THANKS in advance for any help.
Its Chinese new year....must be their vacation. (I did buy a Helix IFS, and it's good stuff, but it is chinese).
Sounds like it may be a bad hi beam switch. Are the hi and lo beams working correctly? Disconnect the switch (take it out of the circuit) and jump a wire from the pwr wire to lo, and then pwr to hi and see what the indicator lite does
as said check the grounds. but i like what groucho said remove the dimmer and run a jump to try and eliminate that problem
ONE of the headlights has the ground and low beam wires swapped in the connector. What's happening is that with the dimmer switch in the low beam position, these swapped wires are grounding the high beam filament for that bulb through the high beam indicator bulb. Unplug all the headlights and the indicator should go off. If it doesn't you have a bad dimmer switch. If it does go off, plug the headlights back in one at at time and see which one causes the indicator to illuminate with the dimmer in low beam. That's the one with the wires swapped.
Thanks so much everyone. I will be in the shop early tomorrow and will find the issue for sure. THANKS Again............to all
Headlights ground through a SIDE connector, NOT the center. It's kinda counter-intuitive, and caught me out the first time. It's my bet. Cosmo
Damn, if the Hamb isn't amazing! I was struggling with this issue for two nights, replaced the dimmer switch tonight with no improvement. Then I did a search and, BAM, I'm back in business. Thanks
