Technical wiring help
Discussion in 'The Hokey Ass Message Board' started by rockin562, Sep 27, 2015.
  1. rockin562
    rockin562
    ok so its been awhile since i have wired a car but i am rewiring a 49 chevy with the ez wiring harness. it has a mustand gas tank with sending unit. with the key off the wire thats suppose to go to the sending unit is dead. with key on my test light is showing a very dim light. so there is some power going to it. my question is does that seem right?
  2. 29moonshine
    29moonshine
    the gas tank wire should be dead with the key off
  3. aaggie
    aaggie
    Sending units are a variable resistor that read Ohms through them The applied voltage goes through the resistance to ground so your test light will be brighter/dimmer with the level of gas in the tank.
  4. rfraze
    rfraze
    Gauge gets power. Ground comes thru sender to gauge. Sender flange MUST have good ground, which passes thru sender kind of like a dimmer switch affects a bulb.
    cosmo likes this.
  5. rockin562
    rockin562
    ok so the wire coming from the gauge and going to the sending unit should have power with the key on correct?
  6. squirrel
    it should have some power, but not full power. It's not something you should be testing with a test light.
    also, the sending unit needs to match the gauge. If you're having issues with how the gauge works, they might be mismatched.
  7. rockin562
    rockin562
    ok i undertand now. thank you so much for everyones help. i just didnt want to hook it up and have a major problem or have a fire on my hands. again thank you so much
  8. Not really 'power'. The light WILL light, but only because you are completing a circuit with the resistance of the light bulb. You will notice, too, that the gauge will register slightly as well.
    Cosmo
  9. rfraze
    rfraze
    No.
    If disconnected from gauge, there should be NO voltage coming thru wire from sender. That wire provides ground thru a variable resistor to the sender pole of the gauge.
    You can measure what is coming thru sender and wire, but it will not be volts or "power".
  10. MORRISGAUGE
    MORRISGAUGE
    Your gauge is a V coil style AC brand magnetic gauge. There is a ground connection through the gauge to the mount plate and one through the secondary coil to the sending unit. It is the balance between these two paths that determine the amount of electromagnetism that is created and thus, how far the pointer deflects. You should have continuity through the system at those points, but a test light tells you very little. Be sure that you have a 30 ohm sending unit in good condition and obviously that it is well grounded.
