Wire wheels
Discussion in 'The Hokey Ass Message Board' started by potter142, Jun 30, 2012.
  1. potter142
    potter142
    from Tn
    I have wire wheels all around my 1935 Ford. Not sure of the manufacture
    But I thought they were damn nice. Now I find that the frond wheels wobble.
    Does anyone know of a shop in Tennessee that can straighten them? Hmmm?
  2. Potter: One thing to watch for is where the wires seat on the drums. Assuming you have 40-48 style hydraulic brakes, the area where the wheel meets the drum has a factory weight welded to the drum. The wheel will contact the weight on one side and then seat on the drum itself on the other. This causes the wheel to be "offset" or crooked. Steelies of course don't since they were part of the design. I ran into this on my truck and used spacers behind the wheels. I had wires on a 34 sedan once but can't recall what we did then to overcome the issue, that was in the mid 70's. PM me if you need more info. Tim
  3. potter142
    potter142
    from Tn
    Thanks for the information Tim, but I have a Mustang II front suspension.
  4. Dale Fairfax
    Dale Fairfax
    OK, but what kind of brakes? Discs?Drums? The 35 wire wheel is fussy as to what it seats on and if its been mounted and tightened on the woing surface it may already be distorted around the lug holes.
  5. Cerberus
    Cerberus
    Dale is dead on. Mustg II had 4 x 108 lug pattern. I have a custom build that uses Mustg II 4-lug bolt pattern frt and rear, disc brakes up frt and drums in the rear, and pwr rack and pinion steering. Had to use wheel spacers to bolt the 14" 4-lug Tru-Spoke wire wheels on.....or the wheel went on crooked.
  6. potter142
    potter142
    from Tn
    Lots of good advise here. I believe my wheels are from Wheel Smith they are 15". I have
    Disks up front and drums in the back. I thought the problem was crumby front tires so I
    Bought new ones. When the installer was balancing them he made it a point to show me
    The wheel wobble. Still need someone to try to straighten them. Thanks y'all.
  7. potter142
    potter142
    from Tn
  8. jazzbum
    jazzbum
    maybe try an american motorcycle shop? harley shops lace and true a lot of wire wheels
  9. You say wheelsmith built them. Get in touch with them. I'm pretty sure they can fix them.
  10. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    I can fix them for you, Give me a call at 559-322-2128. I fix theirs all the time.
  11. chris sage
    chris sage
    from CA
    Yea right Jimmy
  12. Damn Jimmy, he called you out :rolleyes:
  13. BigEd
    BigEd
  14. iammarvin
    iammarvin
    from Tulare, Ca
    Well, he is a Master Wheel Builder.
