wire edging a panel
Discussion in 'The Hokey Ass Message Board' started by tfr1, Aug 19, 2013.
  1. tfr1
    tfr1
    After much seaching, I still do not know what type of wire to use to edge the panels I am making.
    I am building a 20ga steel body withe 1/8" wire in the edges.
    Any wire will probably work. I just want to know what you have used and how it worked. Also, do I use welding wire in 3' pieces and butt weld them together?
    Several edges are more than 6 feet in length.
    Thanks
    TFR1
  2. 1971BB427
    1971BB427
    from Oregon
    I used mild steel 1/8" rod to trim the radius on my wheelwells. It bends and welds easily, and worked great.
  3. tfr1
    tfr1
    1977BB427
    Thanks for giving me such an obvious answer!
    I have been focused on finding 1/8" wire. I had not even considered 1/8" rod.
    TFR1
  4. tfr1
    tfr1
    1971BB427
    Forgive the typo!
  5. The37Kid
    The37Kid
    The tool that is used to bend the metal looks somewhat like an old beer/soda cap remover. A Google or HAMB search should turn up a vedio of how it is done. Bob
  6. heatnbeat
    heatnbeat
    from Madera,Ca.
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Henry used high carbon wire in his fenders to resist flexing.
    A tipping wheel in your beading/swage machine makes for a good/clean start for the placement of a wire, in the flange of an edged panel.
    " Meanwhyle, back aboard The Tainted Pork "
  8. fleet-master
    fleet-master
    I use the appropriate thickness of fencing wire (normally 1/8"). Its usually zinc coated too ,so it won't rust quickly, is stiff enough to hold whatever shape I bend it to and doesn't cost the earth. just my .02
  9. The37Kid
    The37Kid
  10. Irrational Metalworks
    Alliance Vendor
    from DFW
    X2 on this. Galvanized fencing wire comes in a few different sizes. I used 3/16 fence wire when I re bodied the 33 Morgan. It had 72 feet of 3/16 wire edge in that body. I got pretty good at wire edging when I was done with that job!!!
  11. El Caballo
    El Caballo
    Don't weld on galvanized anything if you can help it.
  12. Mindover
    Mindover
    from England
    You don't need to weld the wire.
    I also use fencing wire. I don't tip the edge first because there is no need and many panels would be just about impossible to pick up and feed into a jenny (bead roller). I show a little of how I do it on my youtube footage.
    Here is a '33 fender that I made and wire edged. Too big to feed through a bead roller, for me anyway.
    David
  13. tfr1
    tfr1
    Tim,
    My project is a 1927 Morgan Aero.
    I intended to use 1/8" wire, but pictures of your morgan project with 3/16" looks great.
    TFR1
  14. Irrational Metalworks
    Alliance Vendor
    from DFW
    The original panels all had 3/16 wire in them. The only 1/8 wire on the 33 is in the openings on the hood. I had the luxury of having what was left of an original body to get all my info from! I think they used 3/16 to keep rigidity in the long one piece side panels. I'm still trying to figure out why they made them that way. They were a PITA!!!
  15. tfr1
    tfr1
    Thanks Tim
    Where do you source the wire?
  16. Irrational Metalworks
    Alliance Vendor
    from DFW
    Any fence supply or maybe Home Depot or Lowes. It's very common!
    Nice looking start you have there! Keep us posted as you go!
  17. Roger Walling
    Roger Walling
    After finishing your wire edge, squeegee in some structural adhesive for steel and fill all voids to prevent rust. Finish with a good sanding and you will never know it is there.
    It is available at body shop supply stores for bonding steel to fiberglass.
  18. fleet-master
    fleet-master
    ^^^ you could do that..or run fishoiline in around the edge.
  19. tfr1
    tfr1
    I have a new Metalshaper god to worship.
    Tim @ Irrational Metalworks provided the advice and support I needed at this point in my project.
    Thanks again
    I have decided to take his advice, back up a step and redo some things.
    As I regroup, thought it might be of interest to look at where I started, and where I am trying to go.
    I am going to start a thread describing my 1927 Morgan Three Wheel Car build.
    TFR1
