This is a magnesium Winters Champ shifter quick change. Its had a small repair on the bottom of the case that doesn't effect its use. If you want to run this without the shifter, you can remove it and run a block off plate to cover the hole, The shafts are in great shape and what you see in the pictures is what it comes with . $400 and includes shipping in the continental US.
